Bem-vindo: Ter Out 13, 2026 11:11 am
Criar novo tópico Responder  [ 257 mensagens ]  Ir para página Anterior  1 ... 7, 8, 9, 10, 11, 12, 13 ... 18  Próximo
MensagemEnviado: Dom Fev 05, 2012 1:50 am
sera?! duvido... barato demais para um motor 2T a gasolina...
MensagemEnviado: Dom Fev 05, 2012 1:51 am
Registrado em: Dom Abr 17, 2011 2:20 am
Rumores daquele site.
Slash 4x4 VXL
Slash 4x4 VXL
Slash 4x2 SideWinder SC
Axial Wraith
Axial Wraith
Troller 35"
MensagemEnviado: Dom Fev 05, 2012 6:59 am
Images: 18
Mais detalhes durante a feira 'SPIELWARENMESSE International Toy Fair Nurnberg':
Think of a standard nitro engine...and now imagine:
More than double the runtime...
Cheaper fuel costs...
Widely available fuel...
Easier starting...
No tuning hassle...
Quieter running...
Cleaner running...
The brand new HPI 1/8th scale Gasoline Engine engine combines these fantastic properties with all the excitement of an all-new petrol engine!
The HPI 1/8th scale Gasoline Engine engine is a gasoline 2-stroke engine with outer dimensions only slightly larger than a big block nitro car or truck engine. This revolutionary size will allow the HPI 1/8th scale Gasoline Engine to fit in RC cars where gasoline engines never could before.
So what are the advantages of this engine over the standard nitro methane-powered engines you're used to?
Increased Runtimes
The HPI 1/8th scale Gasoline Engine will get at least double the runtime per tank of fuel, meaning you get more fun before refuelling and more bang for your buck!
Hugely Reduced Running Costs
Standard gasoline is much cheaper than Nitro fuel, plus spark plugs lasting much longer than glow plugs, so the HPI 1/8th scale Gasoline Engine engine allows the RC hobbyist to have extremely reduced running costs.
With the HPI 1/8th scale Gasoline Engine engine, it's now much easier to find fuel at any full-size car service station, anywhere in the world. Simply fill up a fuel can and grab a bottle of 2-stroke oil and away you go to enjoy your car or truck!
Easier to Start
Just like the engine in the Baja buggies and trucks, the HPI 1/8th scale Gasoline Engine is extremely easy to start and there's NO fussing with carb settings. Pull the starter cord and off you go!
No Tuning Hassle
Instead of worrying about things like temperature and humidity to fine tune a nitro engine every time you run your car the HPI 1/8th scale Gasoline Engine engine is much more tolerant with its carburetor settings. The on-board electronics provide fine control and do all the tuning work for you.
Much Cleaner
With the 1/8th scale Gasoline Engine engine, you no longer have to deal with the "nitro goop" that covers your car after running a nitro engine. With a lower oil-to-fuel mixture compared to nitro methane fuels, the HPI 1/8th scale Gasoline Engine engine will run much cleaner making it easy to clean up your vehicle after running.
A Complete Engine System
The eXtreme Gas engine system isn't just an engine - it includes the engine itself, electronics to keep the engine running smoothly and cables to connect everything. It's a complete drop-in solution to adding loads of extra, usable power with a low running cost and maximum impact!
HPI SAVAGE XL FLUX 2350
Minhas Qualificações
MensagemEnviado: Dom Fev 05, 2012 9:03 am
FMB07 escreveu:
sergipe escreveu:
tuliogolgher escreveu:
Motor HPI 1/8 gasolina, um show de motor!...
...XÔ NITRO!!!!
amigo já ví que vc entende do assunto :D
me tira uma dúvida, o que vai manter a corrente na vela?
vai ter um CDI?
Foto do bicho ai o
quando eu tinha Mobilete(acho que muitos aqui nem sabe o que é isso :lol: ) ela tinha platinado, ai surgiram os CDIs e coloquei um na minha junto com outra vela melhor
vixi, a Mobi ficou o Cão!!!!
o motorzinho com suas 50cc arrastava além do peso da própria Mobi(uns 60kg) o meu peso(86kg na época + o peso de Dona encrenca uns 50kg)
então o motorzinho HPI com suas 8cc pra arrastar um carrinho que vai variar entra uns 4~6kg, é proporcionalmente mais potente que minha Mobilete :lol:
MensagemEnviado: Dom Fev 05, 2012 9:47 am
O Sergipe, estamos ficando velhos mesmo, tbm tive uma mobile e fiz a mesma coisa, além de usar avigás com uma mistura mais rica de óleo, subia morro forte e nem precisava ajudar com os pedals, mas voltando ao tópico, alguém já tem alguma informação concreta?
Tá nervoso? Vai pilotar!
MensagemEnviado: Dom Fev 05, 2012 1:59 pm
Registrado em: Dom Out 02, 2011 7:29 pm
Renan_Saenz escreveu:
1/5
A era do nitro pode estar acabando, pois cada litro de nitrometano custa em torno de 35 reais, e a gasolina em torno de 3 reais.
XÔ NITRO!!!!
Com esse lançamento....daqui alguns meses aposto que a thunder tiger ou associated vai aparecer com um motor para 1/10 - 1/8 gasolina kkk
Mais é claro, se a concorrência não levantar com toda certeza irá falir.
Concerteza! acho que os concorrentes estão tremendo e ja pensando como projetar um motor 1/8 gasolina,pois como voce falou,se a concorrencia não agir concerteza vai cair.
Alias hot bodies é da hpi?
MensagemEnviado: Dom Fev 05, 2012 2:14 pm
sim, a HB é da HPI... a HB seria a marca de competição da HPI...
MensagemEnviado: Sex Fev 10, 2012 9:18 pm
Ê março que num chega viu!
MensagemEnviado: Qua Fev 15, 2012 4:19 pm
Registrado em: Qui Jun 30, 2011 1:40 am
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
Em maio vou estar indo a Miami, e com TODA certeza irei estar trazendo comigo uma Hpi Savage XL Gasoline Power!!!!!!!!!!!!!!!!!!!!!
Quando tiver ela na mão faço um vídeo para vcs!
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
E-Revo Mamba Monster 6s
Revo 3.3 (Mofando)
Traxxas XO-1
HPI Vorza Flux 6s!
MensagemEnviado: Qua Fev 15, 2012 7:14 pm
Images: 125
HAHAHAHAH
Não se eu for primeiro e fizer o video! HEHEHEHEHEHE!
Brincadeira, vai firme, eu tenho que esperar chegar na gaba no paraguai para pegar, a viajem internacional mais longa que já fiz! :rip: :rip: :rip: :rip:
MensagemEnviado: Qua Fev 15, 2012 8:11 pm
:mrgreen2: :mrgreen2: :mrgreen2: :mrgreen2: :mrgreen2:
Revo 3.3 (Mofando)
Traxxas XO-1
HPI Vorza Flux 6s!
MensagemEnviado: Qua Fev 15, 2012 9:26 pm
Não se esqueçam! Se tem uma pessoa que está anciosa pra ver um bixo desse rodando sou eu. Agora mudando de lançamento, eu vou juntar minhas economias para pegar um HPI Super 5SC Flux. Foi paixão a primeira vista. Eu gostava muito da Flux HP, agora com esse, meu amor mudou, rs.
MensagemEnviado: Qua Fev 15, 2012 9:39 pm
Machado escreveu:
Será que ele n vai ficar frouxo com esse motor?
Revo 3.3 (Mofando)
Traxxas XO-1
HPI Vorza Flux 6s!
MensagemEnviado: Qua Fev 15, 2012 9:56 pm
Images: 72
Cara so sei que vou comprar uma pode acreditar kkkkkkkkkkkkkkkkk
MensagemEnviado: Qua Fev 15, 2012 9:57 pm
Eu tambem! :D
Estou esperando chegar na Tower ou na Amain.
Mas so que eu vou comprar só o motorzinho e as peças nescessarias, pois vou converter minha Savage XL.
Himoto Bowie 1/10
Maisto Rock Crawer
