Bem-vindo: Sáb Out 17, 2026 10:32 pm
MensagemEnviado: Sex Abr 27, 2012 12:11 pm
Novo modelo do inferno chegou em estoque na amain,valor U$899 :blink:
http://www.amainhobbies.com/product_inf ... -MP9-TKI-3
Melhoras em relação ao passado :
TKI 3 Features:
HD Universals: 3.5mm thick swing shafts, much stronger than the previous version.
Heavy Duty Shock Tower: Strengthened front shock tower features thicker construction giving you the ability to handle what ever your local track can dish out. Similar to what was used during the IFMAR 2011 Worlds.
Redesigned Battery & Receiver Box: Redesigned molded battery and receiver box, which is compatible with KO Propo switch.
Redesigned Servo Tray: Servo tray allows for precise, effective and linear linkage movement.
Move Up: The radio tray has also undergone change which now allows for easy servo maintenance and replacement
Quanto será que vai custar a versão elétrica desse carro?
MensagemEnviado: Sex Abr 27, 2012 7:06 pm
Registrado em: Qui Set 22, 2011 3:18 am
1200 dolares??? preço de um baja! kkkkkkkkkkkkkkkkkkkkkkkkkkk
MensagemEnviado: Dom Jun 23, 2013 8:22 pm
Registrado em: Sáb Jan 26, 2013 8:49 pm
