Bem-vindo: Sáb Nov 07, 2026 2:35 pm
Criar novo tópico Responder  [ 53 mensagens ]  Ir para página 1, 2, 3, 4  Próximo
MensagemEnviado: Ter Abr 21, 2009 1:25 pm
We are extremely proud to debut a fantastic new kit designed to replicate the thrills and excitement of the fastest car racing series in the world: the Formula Ten! Since the release of the original Super F1, HPI's first-ever car kit, we've been waiting for the ideal opportunity to release an all-new chassis designed around the most exciting and glamourous racing cars the world has ever seen! With the full-size cars piloted by determined racers, managed by flamboyant team principals and driven around glamourous tracks in exotic locales, we couldn't think of a better type of car kit to challenge our chassis and body designers!
The Formula Ten is an easy to drive, fun to watch, simple to build racing-level replica of the cars that millions of racing fans around the world love to watch in action, and it's the ideal starting point for motorsports fan of any age or ability level, whether it's your first car or your twentieth.
Fantastic Scale Looks
The Formula Ten features realistically scaled dimensions such as wheelbase, width, tyre size and more, allowing you to faithfully recreate your favorite team's livery and do battle with rivals out on the track. There is truly nothing like the excitement of seeing a full grid of cars painted in replica colours, waiting for the lights to go out!
The first thing you'll notice are the realistic front and rear wings with all the fantastic shapes and curves of the hotly contested 2007 and 2008 racing seasons. These are injection-moulded, high-impact plastic pieces that work ideally as bumpers and as funtional aerodynamic devices. They definitely won't come off as easily as the wings on the real cars! Optional nose pieces will be available to replicate low-nose Formula One cars, and other types are on the way.
The tyres included with the Formula Ten kit will be the grooved tires to complete the look of the cars from 1998-2008, and the slick tyres shown will be available as options to complete the look of the vintage cars.
Completing the amazing scale detail is the awesome 5-piece polycarbonate bodyshell, which features a variety of scoops, winglets and barge boards that allow you to make it into your favourite racing team from the 'winglet and chimney' era! Soon, you'll also be able to easily replicate the design and total look of your favourite Formula One car, team or driver from other classic eras of Formula One!
The look and feel of the Formula Ten is enhanced by its authentic scale size - the Formula Ten is almost exactly 1/10th the size of the real thing!
Easy to Tune and Upgrade
The Formula Ten is a 'T-bar' style 'pan car', which is very easy to set up and highly resistant to damage, so it's perfect for beginners, club racers and fun running.
Imagem]
A selection of great standard parts are included in the kit to make the Formula Ten easy to set up and drive for nearly every driver, regardless of skill or experience level. Precision aluminium rear hubs are included for minimal rear axle vibration, and they're both anodized in bright HPI orange for cool looks. A strong steel axle adds strength to the rear end and makes it extra-durable. The front suspension uses a simple ball-connect and coil spring design for easy tuning - just use softer springs to add more front grip, or stiffer springs for less grip. The rear suspension is designed around the FRP T-bar and friction shock for simple and rugged operation, and the 3-gear bevel rear differential makes basic rear grip tuning an easy matter.
All this durable construction and simple design doesn't mean you won't be able to hop up the Formula Ten and add options, however! If you're an advanced driver or dedicated racer you'll be able to fine-tune the handling of the chassis, just like a real Formula One team!
Whether you want to add corning grip, more speed, faster acceleration or just a bit of style to the chassis, we'll have an array of options that could turn any back-of-the-grid monster into a pole-sitting beast! Graphite chassis parts add chassis stiffness, option tuning springs allow you to add grip, a tuned centre shock will enhance rear grip, an aluminium motor mount will keep your motor cool, a ball differential will enhance rear grip, and many more option parts will be available to totally customize and tune your own F1 racing car.
Build It Yourself
The Formula Ten will be available in kit form only, so you can add your own electronics. A complete assembly manual will be included, plus the exclusive HPI RC Cars DVD.
A radio transmitter, steering servo, receiver, electronic speed controller (ESC), standard-size 540 motor, 4-cell 4.8v stick-pack battery with charger, and finally your choice of paint colour. Standard-size electronic components will fit easy in the chassis, so no expensive micro electronics are needed.
Dimensions
Overall length: 436mm
Width: F 176mm, R 180mm
Wheelbase: 283mm
Weight: 1050g
Camber: F 2° R 0°
Caster: F 6° R 0°
bom, se alguem tiver com tempo de traduzir e mandar pra min, eu vou refazendo o post. hj ta foda.. não da pra min..
MensagemEnviado: Qua Abr 22, 2009 6:30 am
Registrado em: Qui Jul 24, 2008 6:37 pm
Nossa........o diferencial será exposto daquele jeito......qualquer pedrinha vai zuar tudo......
O chassi esta bem parecido com os F1 do ano passado.....bonito mesmo!!
TOMITA MUGEN I
TAMIYA
YOKOMO
SPEC-R
LRP
FUTABA
Website http://tomitamugen.forumeiros.com/
MensagemEnviado: Qua Abr 22, 2009 9:07 am
Fora essa do diferencial de planetarias exposto e colocarem o de esferas como opcional, tem ainda que o carro é todo de "plástico" e que, de acordo com a descrição acima, ele é feito para usar packs stick de 4 células! Mancada....
Continuo com o meu Tamiya e não abro.
MensagemEnviado: Qui Abr 23, 2009 7:44 pm
Registrado em: Dom Nov 30, 2008 12:51 pm
rpompeu escreveu:
concordo com o rponpeu ,o carro e muito bonito e tal...,mais esse diferencial esposto e o pack de 4 celulas foi macada..., eu acho que hpi tinha que fazer um carro para usar um pack de 6 celulas ou ate lipo..., um diferencial de esferas para vir no kit e menos peças de plastico!!!!
eu achei ele meio largo quando a bolha ta pintada e cortada , comparado com as da tamiya , as tamiya são melhores!!!
so a minha opinião!!!
MensagemEnviado: Qui Abr 23, 2009 8:45 pm
Não tem difusores, hehehehe
GRK 2+/ ARC R10 /Slash 4x4
FUTABA 4PX + HK 310 + GT2
viewtopic.php?f=3&t=8083
MensagemEnviado: Ter Mai 19, 2009 12:16 am
mais fotos desse que provavelmente sera meu proximo chassi de estante.
e parece que o carro não é da mesma categoria que o F104Pró. pois o F10 da HPI usa bateria de 4 celulas. 4.8v
MensagemEnviado: Qui Ago 06, 2009 4:59 pm
ums videozinho promocionais
http://www.youtube.com/watch?v=NK-T-nJ6DuA
MensagemEnviado: Qui Ago 06, 2009 5:42 pm
Cold Fusion escreveu:
Muito bonito o chassis e bolha, parece ser leve, derrepente deve andar bem com esses 4.8v do pack, mas os caras da hpi é foda :pedala: , em vez de fazer um auto para brigar :bruce: com as formulas da tamiya. :blink:
Imagem Alexandre
MensagemEnviado: Sex Ago 07, 2009 12:36 pm
riopretomusic escreveu:
o chassi tem opção de colocar baterias de 7.2v vai com uma peça aparte. Mas acredito que por enquanto ele não seja mesmo para competir com os tamiya. ainda não tem peças de hop-up a venda, e a contrução dele é bem simples. nessa versão ainda vem com amortecedores sem óleo.
MensagemEnviado: Sáb Ago 08, 2009 6:17 pm
Será que dá pra colocar asa e bolha do modelo 2009?
MensagemEnviado: Dom Ago 09, 2009 7:01 pm
Registrado em: Ter Nov 28, 2006 10:18 pm
mas já tem bolhas dos modelos 2009??? onde?
Marcelo Trindade
Carros em manutenção!
MensagemEnviado: Ter Ago 11, 2009 9:04 am
achei bem bonito o chassi, mas pra estante, pois parece ser bem frágil mesmo e mal acabado. A ideia do diff é legal, mas não exposto...
(Ajudando o Fernando)
MensagemEnviado: Ter Ago 11, 2009 5:23 pm
Galera, blz? Recebi agora a tarde meu kit do formula ten:
viewtopic.php?f=57&t=13062
Abraços!!!
_______________________
AXIAL SXC10 F350
BUGGY TT XB 9T 4300KV
RC4WD TRAIL FINDER 2 TOYOTA
MensagemEnviado: Qua Ago 12, 2009 8:28 pm
koruja escreveu:
Frágil é a frente do F103 ehauheauhe, e Mal acabado eu não acho que seja, sendo HPI....
Não apostaria nesse HPI pra correr aqui, no campeonato de Formulinha, não por ser ruim, mas pelo Peso =S provavelmente um F103 com eletronica deve pesar o mesmo que só o Chassi desse HPI.... e sendo motor latinha, faz Muitaaaaaaa diferença =/
MensagemEnviado: Ter Set 15, 2009 9:48 am
videozinho..
http://www.youtube.com/watch?v=USgf6XRk0Iw
agora, o cara deve ter limitado no radio o EPA do volante, pq o carro ta virando muito pouco.. não é possível ser assim de fabrica.
