Bem-vindo: Seg Out 12, 2026 10:11 am
MensagemEnviado: Seg Abr 18, 2011 11:28 am
aí povo...
como a primeira pista indoor crawler está prestes a ser inaugurada, já podemos pensar em estabelecer algumas regras e metodoligias de pontuaçao para um torneiro/campeonato
peguei um PDF com as regras de um campeonato americano e claro, nem tudo que eles usam poderá ser aplicado em nossas regras, mas precisamos de pelo menos uma base de por onde e como começar.
Official R/C Rock Crawling Competition Rules
(2010)
Introduction:
This rulebook is intended to standardize the remote control rock crawling competitions that are held at
various locations throughout the United States.
SECTION 1: Penalties
1.1-Points
Reverse: 1 point Gate Marker: 10 points
Rollover: 5 points Boundary Marker: 10 points
Vehicle Touch (Repair & Repositions): 10 points Course Direction: 10 points
1.2
- Back Up/ Reverse: (1 pt)
point is given when a vehicle reverses course after making forward progress.
Reversing is defined as at any time if any of the tires move the vehicle backward or spin in the reverse direction,
whether engaged or in freewheel and/or whether intentional or not. Once a reverse penalty is given, no further
reverse penalty can be given until the vehicle makes forward progress. No penalty is given if the backward
movement is part of a penalized rollover. If a driver begins a course in reverse, a reverse penalty will occur
immediately. (See Reverse examples and explanations Sec. 7.1.)
1.3
- Rollover: (5 pts)
points are given when vehicles rollover, and cannot be corrected without touching. Once
the vehicle has stopped it may be rolled over and the 5 point penalty shall be given.
Vehicles that land back on their wheels are not penalized. No reverse penalties are given until vehicle is back on 4
wheels. A vehicle can only be pushed back on to its wheels from the side. Anything else is a Vehicle Touch.
1.4
- Ve hicle Touch: (10 pts)
All vehicle touches excluding “Rollovers” (See Rollover rule, sec 1.3), intentional or
unintentional, are given an automatic 10 points. The judge then will stop time when either the driver calls for a
vehicle touch or the judge calls a driver touch. The vehicle is then moved back by the driver to the previously
cleared gate with the rear axle aligned to that gate. If the vehicle cannot be aligned to the gate due to course
design, the judge will reposition the vehicle to the next stable location after the cleared gate. This location will be
used for all drivers. Note: All gates for progress are still “live” unless a gate has already been deemed “dead”.
o
1.4.1 - Vehicle Touches:
include but are not limited to: repairs, repositions, vehicle driving/falling into the
driver.
o
1.4.2 - On Course Repairs:
Must be completed on course and in the spot of which the driver decided to take the
repair. Repairs must be made within the course time, while the course timer will continue to run. If repairs are made
within the course time the driver must return to the last previous gate cleared. If repairs cannot be made within the
course time, the driver is given a DNF minus progress points for that course. There are no restrictions on whom or
how the repairs are made.
o
1.4.3 - Off course repairs (Optional):
A driver can call time to make an off course repair. Repairs should be
completed within 30 minutes, or the driver is given a DNF minus progress points. If the repair is made in the
allotted time the driver must return to the last previous gate cleared. A 1 minute time penalty will be subtracted
from the time that is left on that course, the timer will continue once the vehicle makes forward progress
o
1.4.4 Vehicle Out of Spec:
If the Judge has reason to believe a vehicle is out of spec during a course run, he
may call time to stop. At that point no additional inputs maybe given by the driver to the vehicle via touch or radio
control. The Judge must mark the vehicle’s location and perform a tech inspection in the specified tech area (same
manner as all other tech inspections). If the vehicle has been deemed within spec, the driver and vehicle will return
to the location marked by the judge and the clock will start once again. If the vehicle is now out of spec and the
Judge has determined that the vehicle has gained an advantage, the driver must take a repair (see rule 1.4.3) to
correct the problem. If the problem can not be corrected to bring the vehicle back within spec, the driver will receive
a DNF for that course (see rule 1.8 ). If a vehicle falls out of spec due to breakage on course and the Judge
determines the driver has not gained an advantage, then the driver may be allowed to continue on course without
stopping time and requiring a tech inspection. Bodies, and body panels are not included in this exception, and must
be replaced immediately, standard repair procedures and penalties apply.
1.5
- Gate Marker (10 pts each):
each gate will be comprised of 2 gate markers. Points are given when 4 wheels
do not travel between gate markers or any part of the vehicle or driver touches a gate marker. A gate marker will
remain "live" for the entire duration of the attempt on the course. Once any gate marker has been touched or
straddled, no more penalties will be given for that gate marker. Only when a gate penalty is assessed will that gate
marker be deemed "dead". No further penalties will be assessed at this point for that gate marker. (See Gate
Marker and Gate Clearing explanations, sec. 7.2 & sec. 7.3.)
1.6
- Boundary Marker (10 pts each):
Points are given when any part of the vehicle touches a boundary marker.
Once a boundary marker is touched the judge then will stop time, and the vehicle is then moved back by the driver
to the previously cleared gate with the rear axle aligned to that gate. If the vehicle cannot be aligned to the gate
due to course design, the judge will reposition the vehicle to the next stable location after the cleared gate. This
location will be used for all drivers. A boundary marker will remain "live" for the entire duration of the attempt on
the course, and should be replaced if moved. Boundary markers are not required in the design of a course.
1.7
- Maximum Penalty Points:
o
1.7.1 - The maximum points per course is 40.
At that time the driver is given a DNF and the run is complete
and the vehicle should be removed from the course.
o
1.7.2 - The maximum points per gate is 20. (Optional)
Once a driver has reached the maximum of 20-
penalty points for that gate they will be placed with the rear axle aligned to that gates exit. If the vehicle cannot be
aligned to the gate due to course design, the judge will reposition the vehicle to the next stable location after the
cleared gate. No progress points are given for the gates not cleared.
1.8
- DNF (Did Not Finish): (40 pts):
are given anytime a driver cannot complete a course for any reason. (Time
expired, Point-Out, Vehicle not Repairable, Went Home …etc) Progress points are awarded for each gate completed.
1.9
- DNS (Did Not Start) (50 pts):
are given anytime a driver cannot start a course for any reason. Vehicle must
start course under its own power.
1.10
- Progress bonus (-2 progress point):
shall be awarded to drivers for each gate that is cleared by the
vehicle during the attempt of a course. A gate is considered cleared and a progress bonus shall be given when at
least one front and one rear tire passes completely through the gate in the intended direction of the gate. All 4 tires
must pass completely through the gate to receive the progress bonus without a gate
penalty. (See Illustration A) A 10 point gate penalty shall be given if all 4 tires do not
clear the gate, even if no gate marker is touched or straddled. The tires of the vehicle
must travel completely through the gate, and not just break the plane of the gate. Tires
must pass through the gate in the same direction and in the same attempt before a
progress bonus is awarded. These points are deducted from the total course score. Once
a driver has pointed out, no further Progress Points will be awarded.
Illustration A
1.11
Time Out:
A driver may call for time to stop so that he or she may safely reposition themselves on the
course. This time shall be used for the purpose of driver safety and may not be used to survey the course or for any
other advantage. Once the competitor is repositioned the time will start, however the judge has the right to start
time at any point.
1.12 - Course Direction (10 pts)
Gates must be cleared in their intended direction and sequence. Any part
of the vehicle entering an un-cleared gate in the wrong direction, or driven through out of sequence will result
in a 10 point penalty. The judge will stop time. The vehicle is then moved back by the driver to the previously
be used for all drivers. Once the gate is cleared and awarded progress it can be traveled in any sequence or
direction.
SECTION 2: Vehicle Requirements
2.1 - General:
o
2.1.1 -
Vehicles are limited to 4-wheeled vehicles only. These 4 wheels can be the only source of
propulsion for the vehicle.
o
2.1.2 -
Wheelbase is measuring from centerline of front axle stub to centerline of rear axle stub.(See rule 6.4)
o
2.1.3 - Bodied vehicles:
Any support chassis allowed.
2.1.4 - Bodiless vehicles:
Must be a self-supporting, structurally complete, rigid frame. The roof
must be raised a minimum of 1” from the main chassis to resemble a cockpit. The frame sides must
be an overall minimum of 1” tall (The cockpit & frame side are to be measured vertically from where
the hood intersects the cab). Bodiless vehicles should resemble a 1:1 vehicle.
o
2.1.4.1 -
Bodiless vehicles must have solid hood panel, solid roof panel and a minimum of 2 solid side-panels.
o
2.1.4.1.1 -
Hood, roof and side panels must be separate pieces of solid material
installed onto the bodiless vehicle frame.
o
2.1.4.1.2 -
All body panels are to be separate pieces from the
complete structural frame.
o
2.1.4.1.3 -
Body panels must be solidly installed in a manner that is
representative of a 1:1 vehicle.
o
2.1.4.1.4 -
It is required that at least one point of the side-panel must
reach to a span of 1” tall or more & at least one other point of the side-panel must reach to a span of 2.5” long or
more.
o
2.1.4.1.5 -
Body panels must be fitted to the vehicle, and not be overly exaggerated in size in order to distort
vehicles legal measurements.
o
2.1.4.1.6 -
Shocks and fasteners (nuts, bolts, washers, or spacers) shall not be included in the measurements of
the vehicle.
o
2.1.4.1.7 -
Bodiless vehicles must reach a minimum of (A) width, (B) length, and (C) height. Measurements may
include, but not limited to bumpers, stingers, frame-rails, side-rails, skid plates, roof, hood, and side panels.
See Illustration B.
Illustration B.
o
2.1.4.2 - Unibody –
Constructed of a single piece of solid material (fiberglass, aluminum, plastic, etc) and must
be self supporting. A Unibody cannot be fastened together in any nonpermanent way such as, nuts & bolts, pins,
rivets, zip ties, etc. The roof must be raised from the main chassis to resemble a cockpit and should resemble a 1:1
vehicle.
o
2.1.5 -
Winching down of the axles is allowed. The winch line must be attached within a 1/2" of the
center of the axle, and by a single attachment point only.
o
2.1.6 -
All suspension mounting points must be fixed mounted. This includes all link mounts, and
shock mounts.
o
2.1.7 -
There are no limitations on the amount of radio channels used on a vehicle.
o
2.1.8 - Active Suspension
is allowed - A suspension that is interlinked (such as the 1:1 Scorpion,
excluding the air bags used to raise and lower the vehicle) which by design moves part of the
suspension in one direction when moved from another. This does not have any driver input.
o
2.1.9 - Forced Articulation
is allowed – Forced articulation is the use of something such as
hydraulics or electronics to literally force the suspension to move in a driver-controlled manner.
2.2 - Class 1 - Super Crawler Class:
o
2.2.1 -
Vehicle wheelbase is limited to a minimum of 16 inches and a maximum of 18 inches.
o
2.2.2 -
No limits to steering configuration.
o
2.2.3 -
Bodied vehicles must be 3” minimum height on sides. No less than 12.5” total length and full original
width, and no less than 5” in center.
o
2.2.4 -
Super class bodiless 12" overall length, 3" overall width, and 3.75" overall height.
o
2.2.5 -
Vehicle is limited to a minimum 3.2 inch wheels/rims or larger at the bead surface. Wheels may be
modified provided that the tire bead surface is not less than 3.2 inches in diameter. Tires may be modified from
other sized tires using only a pliable rubber.
2.3 - Class 2 – Class 2.2
o
2.3.1 -
Vehicle wheelbase is limited to a maximum of 12.5 inches.
o
2.3.2 -
Vehicle track width is limited to a maximum of 12.5 inches. This is determined by measuring
the bottom of the outer most edge of the front and rear tires while the vehicle is sitting on level ground.
o
2.3.3 -
Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Wheels may be modified provided
that the tire bead surface does not exceed 2.2 inches in diameter. With a tire mounted no exterior component of the
wheel including but not limited to the bead lock ring shall exceed 2.55".
Tires may be modified from other sized tires
using only a pliable rubber but must not exceed a total uncompressed outer diameter of 6 inches.
o
2.3.4 -
Vehicles are limited to 2-wheel steering only.
o
2.3.5 -
2.2 Crawler class bodiless 8" overall length, 3" overall width, and 3.75" overall height.
o
2.1.6 -
total length and full original width, and no less than 5” in center.
2.4 - Class 3 – Class 1.9
o
2.4.1 -
Vehicle wheelbase is limited to a maximum of 8.5 inches.
o
2.4.2 -
Vehicle track width is limited to a maximum of 8 inches. This is determined by measuring the
o
2.4.3 -
Vehicle is limited to 1.9 inch wheels/rims or smaller at the bead surface. Wheels may be modified provided
that the tire bead surface does not exceed 1.9 inches in diameter. With a tire mounted no exterior component of the
wheel including but not limited to the bead lock ring shall exceed 2.2". Tires may be modified from other sized tires
using only a pliable rubber but must not exceed a total uncompressed outer diameter of 4.25 inches
o
2.4.4 -
Vehicles are limited to 2-wheel steering on front axle only.
o
2.4.5 -
Vehicles are limited to the use of 2 channels radio control (one for steering & one for throttle)
only. Neither channel can be used to perform more than one function. Radio systems with more than
2 channels are allowed but only 2 channels can be used to control the vehicle.
o
2.4.6 -
Vehicles are limited to 1 ESC & 1 servo only.
o
2.4.7 -
Vehicles are limited to 1 motor powering both of the axles.
o
2.4.8 –
No driver controlled devices, other than steering and throttle control, will be allowed.
Independent throttle control to the front or rear axles (“burn” or “dig”), winching down the axles, and
forced articulation are not allowed in this class.
o
2.4.9 –
A battery is limited to 11.1 nominal voltage
o
2.4.10 –
1.9 Crawler class bodiless
6.75" overall length, 2.5" overall width, and 3.25" overall height.
o
2.4.11 -
1.9 Class body must be 2.75” minimum height on sides. No less than 9” total length and full original
width, and no less than 3” in the center. All bodies should resemble its original form (Jeep bodies look like a Jeep)
2.5 – Sportsman Class (Optional):
o
2.5.1 -
o
2.5.2 -
o
2.5.3 -
Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Wheels may be modified,
provided that the tire bead surface does not exceed 2.2 inches in diameter. With a tire mounted, no exterior
component of the wheel, including but not limited to, the bead lock ring shall exceed 2.55". Tires may be modified
from other sized tires using only a pliable rubber, but must not exceed a total uncompressed outer diameter of 6
inches.
o
2.5.4 -
o
2.5.5 -
2.2 Crawler class bodiless overall dimension of the complete chassis must be at least 8"overall length, 3"
o
2.5.6 -
Vehicles are limited to the use of 2 radio channels (one for steering & one for throttle) only. Neither
channel can be used to perform more than one function. Radio systems with more than 2 channels are allowed, but
only 2 channels may be used to control the vehicle.
o
2.5.7 -
o
2.5.8 -
(OPTIONAL) Vehicles are limited to 1 motor powering both of the axles.
SECTION 3: General Event Rules & Event Management
3.1
-USRCCA recognizes that some clubs may need to amend the USRCCA Rules to accommodate their terrain and
group size at a local level. These rules changes shall be posted in event notifications, and clearly communicated to
all competitors prior to competition. Multi-Club events that are Non-USRCCA Events are encouraged to run as strict
USRCCA Rules as possible. All USRCCA Sanctioned Events are required to strictly follow USRCCA Rules. Any rules
exception for sanctioned events must be pre-approved by the USRCCA Rules Committee.
o
3.1.1 -
Any event in which a National Invite is awarded is deemed a Sanctioned Event. This includes major
events, state championships, state crawl-offs, etc.
3.2-
Scores are ranked by the cumulative total of all course scores. Lowest total score wins.
o
3.2.1 -
Finals course scores are add to total event scores. DNS (50 pts) is given to drivers that did not compete in
the finals
3.3
- Tie Scores:
o
3.3.1
Nationals Style: In the event of a tie score the competitor with the lowest score on the final course run is
considered the winner. If both competitors are also tied on the final course then the second to the last course run
will be used, and so on.
o
3.3.2
Optional: In the event of a tie score the competitor with the lowest time on all courses will be chosen the
winner over the other competitor(s) with the same score.
3.4
- No pre-running courses: Drivers that pre-run a course will receive a DNS (50pt) for that course.
3.5
Courses not ran before designated cut off time will be scored as a DNS (50). Drivers in line to run their last
course by the designated cut off time will be given the chance to run that course.
3.6
- Winching (other than that done to the suspension) or ramping of any kind is not allowed. Using any device
(other than the tires) such as ramps or other objects to make progress in any direction is prohibited and
will result in a DNF for that course.
3.7
- No vehicle may be run in more than one class at an event.
3.8
- The vehicle must run a course entirely with the same wheelbase, track width, ride height, and tires it started
that course with. Any changes to the vehicle (other than winching down the suspension or forced articulation) by
the driver, another person, or any device, while on the course are prohibited.
3.9
- Vehicles cannot be exchanged for another vehicle during the competition.
3.10
- Drivers may make changes to wheelbase, track width, ride height, and tires between course runs, as long
as the vehicle remains within the specs for it's class.
3.11
- No modification to the course is allowed by anyone. This includes, but not limited to, removing of rocks,
stacking of rocks, purging a puddle of water, blowing/wiping dirt from rocks, removing of vegetation, or other types
of modifications to a course that could gain a driver an advantage.
3.12
- Any violations of event rules are subject to automatic disqualification by judges, event organizers, or
USRCCA. If violation of rules is severe and/or reoccurring the USRCCA reserves the right to ban the violator from
competition up to one year.
SECTION 4: Course Design
4.1 -
Gates consist of 2 Gate Markers.
4.2 -
Minimum of 20 inches apart for Super Class, a minimum of 16" apart for 2.2 Class and a minimum of 12"
apart for 1.9 Class. All measurements are from inside to inside of each gate marker.
4.3 -
(3-10) Gates per course
4.4 -
A minimum of 3 Courses per event is recommended.
4.5 -
Gates that are in close proximity to each other should be distinguished by color or markings.
4.6
- Gate markers that are designed as part of the course that count for penalty must also have progress or bonus
points awarded.
4.7
- Start Lines may consist of a start gate, chalk line or any other type of designated starting area. Start lines are
only used to start the course clock.
o
4.7.1 -
Scoring starts when time has started. Scoring stops when course is finished.
4.8 -
The course is finished once the last gate is completed and progress has been awarded (see rule 1.10)
4.9
Bonus (Optional) are extra gates placed anywhere on the course by course designers for bonus credit.
o
4.9.1 -
All penalties apply during the bonus attempt to the regular score even if the bonus is not completed or
aborted.
o
4.9.2 –
Course must be completed in order for bonus to be awarded.
o
4.9.3 -
Bonus may consist of more than one gate.
o
4.9.4 -
Bonus Gates are ran in the intended sequence set by the course designer.
4.10
Alternate (Optional) are secondary gates placed anywhere on the course by course designers for bonus
credit.
o
4.10.1 -
All penalties apply during the alternate attempt to the regular score even if the alternate is not
completed or aborted.
o
4.10.2 -
Course must be completed in order for alternate to be awarded.
o
4.10.3
Alternate may consist of more than one gate.
o
4.10.4 -
Alternate Gates are ran in the intended sequence set by the course designer.
SECTION 5: Judging
5.1 -
Judges are responsible for watching vehicles while on the course, and to penalize drivers that commit
penalties while competing.
5.2 -
Judges should call out penalties when they occur.
5.3 -
Judging should be done by at least 2 people per driver. One Judge to call out penalties and one
Judge/Scorekeeper, to record penalties, tally maximum penalties, keep time (if applicable), etc.
5.4 –
Judges are responsible for keeping spectators at a safe distance from the course to avoid spectator
interference.
5.6 –
If a spectator accidentally interferes with the vehicle the driver should not penalized. If a fan intentionally
interfered with the vehicle, and significantly changes the outcome to the driver's advantage then the driver should
be penalized appropriately at the discretion of the judge. Intentional spectator interference includes but is not
limited to if a fan stops a truck from falling in water, off a cliff, or other obvious hazard to avoid damage.
5.7 –
Spotters (Optional) If spotters are permitted by event organizers drivers are responsible for identifying the
driver’s spotter. Only designated spotters shall be allowed on course with the driver and judges. All penalties
committed by the spotter shall count towards the driver’s total score. (i.e. touches, stepping on gates, course
modification, etc.)
SECTION 6: Glossary of Terms
6.1 - Event/Competition:
The coming together of drivers at a certain place and time to compete on single or
multiple courses.
6.2 - Course:
A course is the terrain that consists of a start gate, an end gate, and all the terrain in between them.
Every course has an intended direction of travel, or “flow”, through the gates.
6.3 - Gate:
A gate is used to mark an obstacle within a course and/or guide the vehicle through the course. A gate
consists of 2 gate markers measuring no less then; 20" for the Super class, 16” for the 2.2 class, and 12“ for the
1.9 class from inside edge of one marker to the inside edge of the opposite marker. The gate is the entire area
between the gate markers; determined by the size of the gate markers and the distance between them. See
Illustration C below. Every gate has an intended direction of travel, or “flow”, through
the gate. This direction will be marked, explained or implied by the course designers.
All gate markers are “live” until touched or straddled.
Illustration C.
6.4 - Wheelbase:
is measured from center of axle nut to center of axle nut. The vehicle should be set down on a
flat surface by the driver. The front wheel on the side that is being checked, must be pointing straight forward. At
that time, the driver will then cycle the suspension through it's complete extension and compression range while the
judge measures the vehicle's maximum wheelbase. At any point the vehicle's wheelbase cannot extend beyond the
maximum limit of it’s class. All the above procedures must be duplicated on the opposite side. Note:
All vehicles will
be teched in the same ready to run condition, and set up as the vehicle will be run on the course. If the vehicles
wheelbase is affected by radio control it must be cycled or activated during tech inspection.
6.5 - Ve hicle track width:
is measured from the outer most edge of a tire to outer most edge of a tire.
SECTION 7: Penalty Examples and Additional Penalty Definitions
The examples and definitions used in this section are intended to help explain rules in previous sections not override them
7.1 - Back Up/ Reverse Examples:
o
7.1.1 -
If the driver intentionally drives the vehicle in reverse, a reverse penalty will occur.
o
7.1.2 -
If the vehicle stops on an incline and then rolls backwards a reverse penalty will occur.
o
7.1.3 -
If a vehicle is climbing an obstacle and is bounced backward by the terrain but the tires are still moving
forward, no reverse penalty will occur.
o
7.1.4 -
If a vehicle flips over backward, without the driver reversing, no reverse penalty will occur.
o
7.1.5 -
Once a reverse penalty has been assessed, no further reverse penalty can be assessed until the vehicle
o
7.1.5.1 - Example:
Reversing, stopping, and then reversing again will only result in one reverse penalty.
o
7.1.5.2 - Example:
When high-centered, Reverse, forward, and then reverse again to rock the
truck back and
forth will only result in one reverse penalty until forward progress is made.
o
7.1.6 -
Reverse penalties are assigned at the Judge’s discretion if the actions performed by the
Vehicle/driver is not clearly defined by the rule.
7.2 - Clearing of a Gate:
o
7.2.1 -
A gate is considered cleared when at least one front and one rear wheel passes between the two gate
markers only in the intended direction of the gate.
o
7.2.2 -
All gates must the cleared in the intended sequence of the course layout (gate 1, then gate 2, then gate 3,
and so on).
o
7.2.3 -
A vehicle may travel through a gate while it is in reverse and still clear that gate as long as it only travels
though in the intended direction (reverse penalty(s) will be assessed as necessary).
o
7.2.4
If all four wheels of a vehicle pass between two gate markers that gate is considered a cleared gate with no
penalties and a gate progress bonus is awarded.
o
7.2.6
If one wheel from the front axle and one wheel from the rear axle passes between two gate markers
(vehicle straddles a gate), that gate is considered a cleared gate. This however will result in a Gate Marker penalty
of 10 points and a gate progress bonus is awarded.
o
7.2.7
If one wheel only from the front axle or one wheel only from the rear axle passes between two gate
markers (vehicle straddles a gate) that gate is not considered a cleared gate. This will result in a Gate Marker
penalty of 10 points and no gate progress bonus is awarded.
7.3 - Gate Marker penalty:
o
7.3.1 -
At any time a gate marker is touched by a vehicle or by a driver, a Gate Marker penalty is assessed.
o
7.3.2 -
If at any time the axle of a vehicle (facing in any direction) passes over any part of a gate marker and
both tires of that axle are touching the ground (or any object on the ground) on opposite sides of the gate markers,
it is considered a straddle and a Gate Marker penalty is assessed.
o
7.3.3 -
A driver can only continue with the course when a gate is cleared or 20 pts (if optional by pass rules are
used)
at that gate is accumulated.
o
7.3.4 -
If a wheel floats above a gate marker, the driver must correct it before that gate is deemed clear and
progress is awarded. If the driver fails to correct the position of the tire, such that it is not located above the gate
marker, and continues to clear the gate, a gate penalty will be assessed at that time in addition to the gate
progress. All 4 tires must go between the gate markers to not receive a gate penalty.
Section 8: Sportsmanship
8.1 – Sportsmanship:
is required at RC Rock Crawling Competitions. If a competitor or team member (including
but not limited to spotters) promotes unsportsmanlike conduct, they and/or their team members may be penalized
upon the Marshal's review of the incident. Unsportsmanlike conduct includes but is not limited to rude or abrasive
actions towards officials or other teams or spectators, destroying property, displaying drunken or disrespectful
behavior, use of excessive on course profanity or kicking/throwing their controller or rig. The violator(s) and/or their
team members may be penalized upon the Marshal's review of the incident. Unsportsmanlike conduct may result in
a 50 for the course, and/or disqualified from the competition.
8.2 -
No alcohol allowed on course during competition.
2-17-2010
T+
Fabiano - BH/MG
Axial AX-10 - Kalango
Axial AX-10 - Kamaleao
Venom Creeper - Aranha
MensagemEnviado: Seg Abr 18, 2011 12:21 pm
Preguiça monstra!!! :bocejo: :bocejo: :bocejo: :bocejo: :bocejo:
Traduz os melhores momentos aí....
[ ] Wally
Wallison Cunha
MensagemEnviado: Seg Abr 18, 2011 2:15 pm
pô... os caras só querem mastigadinho... depois falam que um certo alguém é preguiçoso...
de inicio, os pontos interessantes e aplicaveis sao:
1- Reverse/back-up - 1 ponto : é quando vc tem ao tentar uma vez transpor um obstaculo e nao consegue de primeira tem que voltar de ré e começar de novo.
2- Rollover / capotagem - 5 Pontos : a regra americana diz que se capotar e cair com as 4 rodas no chao nao é considerado a perda de pontos, eu acho que poderiamos simplificar e simplesmente capotou? sao 5 pontos e fim de papo
3- touch / toque no veiculo - 10 pontos : novamente a regra americana tem algumas observaçoes quando a encostar no veiculo intencionalmente ou nao, se é p/ consertar algo ou nao, poderiamos simplificar com encostou no carrinho? seja com dedo, mao, pé, nariz, bunda, etc.. leva 10 pontos
OBS: numa capotagem no qual é preciso desvirar o carrinho com a mao, logo, vai levar 15 pontos, 5 da capotagem + 10 do toque, na regra americana se vc capotar e tiver que pegar o carrinho com a mao, perde só 5 pontos da capotagem
4- Gate Maker / marcadores de traçado - ( as meia bola de tenis) - 10 ou 5pts : a regra americana tb tem varias sub regras sobre isso, mas poderiamos simplificar com algo do tipo, passou com uma roda em cima do marcador? 5 pontos , passou com a roda em cima e tirou o marcador do lugar? 10 pontos
acho que com essas 4 regras já teriamos um bom começo e competitividade, alem de claro estabelecer um tempo minimo p/ cada circuito..
depois quando tiver muito carro, e o negocio bombar mesmo, vamos acressentando mais firulas as regras a fim de dar competitividade e equilibrio aos participantes.. o que acha?
Fabiano - BH/MG
MensagemEnviado: Seg Abr 18, 2011 10:01 pm
:blink: :blink:
A galera da terra do pão de queijo aí tá de parabéns !!
Eu vou ler com mais calma todo o rulebook, mas já de antemão eu tenho alguns pontos, rsrs.
Primeiramente eu gostaria de frisar que foram poucas as vezes que eu vi um crawler e dessas vezes nenhuma eu vi ele escalando, então, dêem um desconto aí, :mrgreen:
Rolou, tombou, capotou e precisará pegar o carrinho para arrumar, eu acho que deveria ser só os 10 pontos.
Capotou e ficou com as 4 rodas pra baixo não perderia pontos (sorte ?) mas e quanto a questão do traçado ? O auto não sairia da reta ?
Para terra Brasilis haverá a caracterização e penalidades ou até a proibição do uso de certas features nos autos, como DIG, 4 wheels steering ?
Valeu pessoal,
Grande abraço, ótima iniciativa, e não liguem se falei asneira, minha área mesmo é a trail !
Tundra -- 80%
Higher Gear Box
F-250 -- 100%
MensagemEnviado: Ter Abr 19, 2011 8:06 am
opa..
acho que de inicio, vamos deixar valer tudo, DIG, 4W steering, carros de escala diferente até termos quorum p/ dividir melhor as categorias
eu havia sugerido em outro topico de por enquanto só fazermos divisao entre Crawlers 1/10 e Summits 1/10 pois esses nao tem condicao nenhuma de competirem entre sí.
se colocarmos regras demais quanto aos carros agora, vai acabar espantando o povo...
T+
Fabiano - BH/MG
MensagemEnviado: Ter Abr 19, 2011 5:17 pm
É, acho que é só fazer uns ajustes tupiniquins que fica bom. Acho também que podíamos criar a regra de utilizar acessórios para transpor obstáculos, tipo guincho, estepe, prancha, etc. Lógico, perdendo pontos.
E tb o aborto de trechos, pois pode ser que alguma viatura não consiga transpor determinado, como as 2 subidas cabulosas da pista do adrenalina.
[ ] Wally
Wallison Cunha
MensagemEnviado: Ter Abr 19, 2011 6:14 pm
Onde fica essa pista ?
MensagemEnviado: Ter Abr 19, 2011 6:42 pm
Em Belzonte. Dá uma olhada lá no tópico de Belo Horizonte. Tá convidado.
[ ] Wally
Wallison Cunha
MensagemEnviado: Ter Abr 19, 2011 6:47 pm
Opa, demorou.
Pena que eu to meio longe daí, uns 700km... :mrgreen2:
MensagemEnviado: Ter Abr 19, 2011 8:28 pm
Wally BH escreveu:
[ ] Wally
Pô Wally, voce disse algo bem legal e que eu ia comentar ontem mas acabei esquecendo.
Fazer 2 opções de um mesmo trecho no percurso por exemplo, onde o trecho mais cavernoso e dificil daria bonus ao competidor. Claro que qualquer infração nesse pedaço tiraria pontos normalmente, mas a recompensa deve valer o desafio.
Entenderam ? :mrgreen:
Abraços !
Tundra -- 80%
Higher Gear Box
F-250 -- 100%
MensagemEnviado: Ter Abr 19, 2011 11:31 pm
Citação:
Porque????
Falow,
Fernando - PaNeTo
Joguinho legalzinho!!
MensagemEnviado: Ter Abr 19, 2011 11:49 pm
pq a maioria dos bêbados sao um estorvo... certamente p/ ter essa regra deve ser pq já deve ter rolado brigas e outros problemas com bebida
imagina um bebum numa competicao fazendo merda e querendo provar que tem rasao??
T+
Fabiano - BH/MG
