Bem-vindo: Seg Out 12, 2026 5:41 pm
MensagemEnviado: Sex Jul 15, 2011 10:11 am
Como eu disse no outro tópico,de pouquinho em pouquinho vou tirando informações do outro tópico que é muito grande e colocando aqui.
_________________________________________________________________________________________________
Stampede XL5
Specs
Type: 2WD Monster Truck
Scale: 1/10
Length: 16.25 inches (413mm)
Width: 12.75 inches (324mm)
Wheelbase: 10.63 inches (270mm)
Weight: 65.3oz (1.85kg)
Chassis: Modified Tub made of Composite Nylon
Drive Train: Magnum 272ª Transmission
Motor or Engine: Titan¨ 12T 550
Speed Control: XL-5 Electronic Speed Control
Speed: 30+mph
Gear Pitch: 48-Pitch
Wheel Size: 2.8" Mirror-Chome (All-Starsª)
Kit/RTR: RTR
Gender: Male
Minimum Age Recommendation: 8 years
Experience Level: Beginner
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
Needed to Complete
8 AA batteries for the transmitter
7.2V Battery and Charger for the starting system
Stampede VXL
Specs
Type Electric 2WD Monster Truck
Scale 1/10
Length 16.3in. (413mm)
Width 12.75in. (324mm)
Wheelbase 10.63in. (270mm)
Weight 4.1lb (1.85kg)
Chassis Composite Nylon Modified Tub
Drivetrain 2WD
Motor or Engine Velineon 3500 Brushless
Speed Control VXL-3s Electric Speed Control
Radio TQ 2.4GHz High Output with Traxxas Link
Gear Pitch 48-Pitch
Wheel Size 2.8in.
Kit/RTR RTR
Stampede 4x4
Specs
Length 19.36in. (500mm); 15.63in. (397mm) without wheelie bar
Front Track 13.39in. (340mm)
Rear Track 13.39in. (340mm)
Center Ground Clearance 2.90in. (74mm)
Weight 66.45oz (1.88kg)
Height (overall) 9.21in. (234mm)
Wheelbase 10.83in. (275mm)
Shock Length Long (front), XXLong (rear)
Tires Talon 2.8in.
Tire Diameter 4.80in. (122mm)
Wheels (front/rear) 2.8in. Black-Chrome All-Star
Wheel Diameter 2.8in. (72mm) Outer
2.8in. (72mm) Inner
Speed Control Type VXL-3s Electronic Speed Control
Motor (Electric) Velineon 3500 Brushless
Overall Drive Ratio 13.97 (stock, out of box)
Differential Type Hardened Steel Bevel, Sealed, Limited Slip
Gear Pitch 32
Chassis Structure/Material Molded Tub/Nylon Composite
Drive System Shaft-Driven, Direct Drive 4WD
Steering Dual-Bellcrank with Integrated Servo Saver
Radio System TQ 2.4GHz High Output Radio with Traxxas Link
MensagemEnviado: Sex Jul 15, 2011 10:23 am
Para quem quiser mais detalhes dos modelos segue site do fabricante:
XL-5 (#3605): http://traxxas.com/products/models/elec ... 05stampede
VXL (#3607) : http://traxxas.com/products/models/elec ... tampedevxl
4x4 VXL (#6708): http://traxxas.com/products/models/elec ... pede4x4vxl
E nesse grupo também pode incluir as Monster Jam (#3602) : http://traxxas.com/products/models/elec ... monsterjam
Que são uma versão da XL-5 .
ImagemGUH
TRAXXAS STAMPEDE VXL
AXIAL SCX 10
HOBÃO HYPER 10sc
Editado pela última vez por Guh Killer em Sex Jul 15, 2011 10:31 am, em um total de 2 vezes.
MensagemEnviado: Sex Jul 15, 2011 10:27 am
Vistas explodidas
Stampede XL5
Stampede Shock and Front Assembly
Stampede Rear Assembly
Stampede Chassis Assembly
Stampede Transmission Assembly
Stampede VXL
Stampede VXL (#3608) Front Assembly
Stampede VXL (#3608) Rear Assembly
Stampede VXL (#3608) Chassis Assembly
Stampede VXL (#3608) Transmission Assembly
Stampede 4x4
front, rear, chassis, driveline, driveshaft, modular
