Bem-vindo: Seg Out 19, 2026 5:33 pm
 Título: VENDIDO
MensagemEnviado: Qui Jan 29, 2009 8:10 pm
R$130,00
http://www.teamnovak.com/products/esc/gtx/index.html
Está com conectores bullet (banana) por enquanto ou se o comprador assim o quiser. Trocarei por Deans em breve (assim que eu os encontrar...)
GTX PROGRAMMABLE RACING ESC SPECIFICATIONS
Input Voltage: 4-7 cells or 25 Li-Po when used with Novak's #5470 Smart-stop Li-Po Module (#5470)
Footprint: 1.11” x 0.86” (28.2 x 21.8mm)
Weight: 0.64 oz. (18.1g) [with heatsink, without wires]
Motor Limit: None (Any brush-type R/C Motor)
On-Resistance:0.00034 ohms
Rated Current: 700* Amps @ 25°C MOSFET Temp.
Braking Current: 300* Amps @ 25°C MOSFET Temp.
BEC: 6 Volts/ 3 Amps
Schottky Diode: 36 Amp Built-In
Maximum Discrete Steps: 2600 (1300/Forward, 1300/Reverse)
Battery/Motor Wire: 10”/14G (12AWG can also be used)
*Due to the unique nature and advanced technology of the GTX's MOSFETs, the MOSFET manufacturer has changed the current rating from 150 amps to 700 amps and braking current rating from 60 amps to 300 amps.
GTX PROGRAMMABLE RACING ESC FEATURES
Microprocessor-controlled
7 Throttle Programs
On-Board Programming with 4 Color Status LEDs
Gold-Plated PCB Direct-Solder Wire Tabs
Variable Throttle Step Technology
User-replaceable combination Input Harness/Power Switch (#5305)
One-Touch Set-Up
Radio-Priority Circuitry
Polar-Drive Circuitry
Thermal Overload Protection
Digital Anti-Glitch Circuitry
GTX PROGRAMMABLE ITEMS
Throttle Programs: 7 (6 fixed, 1 customizable)
Drive Frequencies: 1 of 7 (1-11 kHz)
Minimum Drive: 1 of 5 (2-12%)
Brake Frequency: 1 of 5 (1-6 kHz) Standard or Drag
Minimum Brake (all programs): 1 of 7 (0-50%)
Dead Band: 1 of 5 (2-6%)
Drag Brake: 1 of 7 (0-50%)
Editado pela última vez por Isao_TKR em Seg Abr 13, 2009 3:27 pm, em um total de 1 vez.
MensagemEnviado: Dom Fev 01, 2009 9:42 pm
Registrado em: Seg Dez 15, 2008 7:39 am
Enviei MP, obrigado.
MensagemEnviado: Ter Fev 03, 2009 1:57 pm
R$120,00
MensagemEnviado: Seg Fev 16, 2009 9:24 am
R$100,00
MensagemEnviado: Seg Fev 16, 2009 1:33 pm
esse esc serve em motores brushless?
obrigado!
QUASE FAZENDO UMA DOAÇAO!!
MensagemEnviado: Seg Fev 16, 2009 1:39 pm
Registrado em: Seg Jul 16, 2007 4:58 pm
Opa, respondendo para o Isao, não este esc é somente para brushed.
JRXS R/TF-3 guardado pro filhão Gabriel. Pai babão.. e agora tb o Raphael....
MAMBA 7700 KV / GTB 3.5 R
CAMARO68/MUSTANG70/R33/ BARRACUDA
DX2 /301 DX
6000 machamps / 4000 lipos by Aldo. eheheh
Usuários navegando neste fórum: Google [Bot] e 8 visitantes
