Bem-vindo: Dom Nov 01, 2026 5:20 pm
MensagemEnviado: Sex Jan 16, 2009 9:00 am
Registrado em: Ter Jun 12, 2007 3:33 pm
Galera,
Só sobrou o esc + cartão de programação + ubec !!! Ótimo para fazer conversão de GP para EP, porém NÃO TEM FREIO !!! Alias tem freio mas é aquele que quando para de acelerar freia !!!
Apenas R$ 300,00 tudo !!!
Segue as especificações de cada item abaixo:
TURNIGY Plush 100amp Speed Controller
This besc is mounted on a precision made PCB, it also has an oversized heatsink held tight against the FETs with screws.
This esc can handle large motors up to 100A and 6S
Specification
Constant Current: 100A Burst Current: 105A
BEC Mode: Linear BEC: Opto Only
Lipo Cells: 2-6 Lipo Cells: 2-4
NiMH: 5-18 Weight: 125g
WARNING:
For some large motors, you must use High timing mode. Failure to do so will result in a burnt esc.
TURNIGY BESC Programming Card
This device plugs inbetween the Rx and the speed controller. It allows the user to program the BESC according to a series of LED indicators.
It has buttons at the bottom so you can navigate through the menu and select the feature you want, then change it. Its very simple and is much easier than listening to jingles or a series of beeps.
TURNIGY 5-7.5A (8~42v) HV UBEC for Lipoly
The all new Turnigy 7.5A UBEC is an advanced switching DC-DC regulator which will supply a constant 5A or more with short bursts of up to 7.5amps. The Turnigy UBEC plugs into a 3 - 10 Cell Lipoly pack and supplies a constant 5 or 6v to your receiver.
The system includes an anti-short circuit and overheat function with a thin metal shield cover, reducing noise
Also included is an Output filter to reduce noise, an on/off switch and a step down regulator adapter.
Chip efficiency is 92%.
Specification
Output (Constant): 5v/5A or 6v/5A Input: 8v-42v (3-10cell lipo) High Voltage
Size: 48x27x9mm Weight: 37g
Quiescent current: 20mA Type: Switching, however because of the noise reduction (thin metal case & filter) this unit gives the same noise as a Linear BEC.
Segue algumas fotos:
Fotos dos equipamentos antes de montar no carro:
Fotos atuais:
http://img7.imageshack.us/img7/3739/dsc006222.jpg
http://img21.imageshack.us/img21/3995/dsc006402.jpg
http://img410.imageshack.us/img410/8647/dsc006412.jpg
http://img11.imageshack.us/img11/2900/dsc006212.jpg
Tudo em excelente estado, funcionando perfeitamente.
Quem quiser mais é só pedir ... tenho um caminhão de fotos ... rsrsrs
Veja minha qualificação e outros produtos a venda na minha assinatura.
Dando um tempo no Hobby.
Vendendo tudo ... aceito trocas e propostas:
VENDO Chassis Buggy 1/8
VENDO Esc 100A + Progr. card + Ubec 7,5A
VENDO Bolha 1/8 Dodge Viper + Rodas e pneus
VENDO Vários itens - Meu E-SHOP
MINHAS QUALIFICAÇÕES
Editado pela última vez por rogeriomila em Ter Mar 31, 2009 5:41 pm, em um total de 5 vezes.
MensagemEnviado: Seg Jan 19, 2009 2:28 am
Registrado em: Qui Jan 24, 2008 8:29 pm
nao vende o feigao nao??
Slash 4x2 / Mamba Max / Velineon 3S /bolha proline Baja
Venom Creeper Comp
Hobao Hyper10SC 4x4 3s
E-Revo Brushless / MMM 2200
MensagemEnviado: Seg Jan 19, 2009 8:36 am
biancocf escreveu:
Só vendo completo mesmo.
MensagemEnviado: Ter Jan 27, 2009 12:35 pm
:bleh:
Editado pela última vez por rogeriomila em Seg Mar 30, 2009 11:12 am, em um total de 1 vez.
MensagemEnviado: Seg Mar 09, 2009 3:45 pm
:bleh:
MensagemEnviado: Qua Mar 18, 2009 2:53 pm
:bleh:
MensagemEnviado: Qui Mar 19, 2009 9:57 am
:bleh:
MensagemEnviado: Qua Mar 25, 2009 8:35 am
:bleh:
MensagemEnviado: Seg Mar 30, 2009 11:13 am
Anuncio COMPLETAMENTE reformulado !!!
MensagemEnviado: Ter Mar 31, 2009 5:43 pm
Agora só sobrou o Esc 100A + cartão de programação + Ubec 7,5A (até 42V) !!!
Por R$ 300,00 !!!
MensagemEnviado: Qua Abr 01, 2009 9:22 am
Para pessoas de São Paulo tem como retirar em mãos ... posso fazer em até 10 vezes sem JUROS no Cartão de Crédito !!! Com TOTAL SEGURANÇA !!!
MensagemEnviado: Seg Abr 06, 2009 12:22 pm
BAIXEI PARA R$ 250,00 !!!
MensagemEnviado: Seg Abr 06, 2009 12:30 pm
É impressão minha, ou tá escrito no ESC que é "a prova de balas"? :blink:
MensagemEnviado: Qua Abr 15, 2009 9:11 am
Fala Doug,
Pra vc ver como ele aguenta o tranco ... rsrsrsrs
Separando...
Esc + programming card = R$ 200,00
BEC = R$ 50,00
Valeu ...
MensagemEnviado: Qui Abr 16, 2009 4:21 pm
:bleh:
