Bem-vindo: Sex Out 23, 2026 3:52 am
MensagemEnviado: Qua Jan 07, 2009 8:29 pm
Registrado em: Sex Dez 28, 2007 12:20 pm
Vendo:
ESC DURATRAX AUTO-SPORT INTELLISPEED
Input Power: 7.2 to 8.4 volts DC (6-7 cells)
Operating Frequency: 1.0 kHz
BEC: 5.0 volts / 1.0 amp
On-Resistance: 0.007 ohms
Max. Constant Current: 128 amps
Max. Peak Current: 440 amps
Acceleration Time Delay: 0.34 seconds fixed
Motor Turns Limit: no fewer than 20 turns
Case Size (with heat sink): 1.48 x 1.34 x 0.57" (42 x 38 x 16mm)
Weight (with heat sink): 1.9 oz (55g)
+ MOTOR STOCK 27T
VALOR: VENDIDO COM FRETE GRÁTIS VIA PAC
ESC NOVAK EXPLORER SPORT (COM SAÍDA PARA LUZ DE FREIO)
Input Voltage 6-7 cells (1.2 volts DC/cell)
Case Width 1.98 inches [50.29 mm]
Case Depth 1.42 inches [36.07 mm]
Case Height 0.70 inch [17.78 mm]
Weight (w/o heat sinks) 1.87 ounces [50.01 g]
On-Resistance @ Transistors 0.005 W
Rated Current 150 amps
Braking Current 50 amps
BEC Voltage 5.0 volts DC
BEC Current 0.5 amps
Wire Size (Battery/Motor) 16 gauge
Wire Length (Battery/Motor) 6 inches [152 mm]
Signal Harness Length 6 inches [152 mm]
Transistor Type MEGAFET
PWM Frequency 2500 hertz (nominal)
Part Number 1900
Brake Light Part Number 5655 (optional accessory kit)
+ MOTOR STOCK 27T
VALOR: R$ 130,00 COM FRETE GRÁTIS VIA PAC
ESC DURATRAX STREAK (COM FREIO ABS)
Stock Number: DTXM1030
Voltage Input: 4-10 cells
BEC Voltage: 5 volts
On-resistance*: 0.004 ohms
Rated Continuous Current*: 300 amps
Operating Frequency: 3500 Hz
Dimensions (w/o heat sink): 1.6 in x 1.5 in x 0.6 in (41 mm x 38 mm x 15 mm)
Weight (w/heat sinks): 2.1 oz (60 g)
Motor Sizes: 12 turns or more
+ MOTOR 12T DOUBLE
VALOR: NEGOCIANDO COM FRETE GRÁTIS VIA PAC
Helis: Lama v4, Big lama, Belt CP V2, 4#6.
Editado pela última vez por lucianofrutuoso em Sáb Jan 10, 2009 9:19 am, em um total de 2 vezes.
MensagemEnviado: Sex Jan 09, 2009 12:13 pm
O ESC DURATRAX AUTO-SPORT INTELLISPEED já foi.
MensagemEnviado: Sex Jan 09, 2009 9:18 pm
O combo "ESC DURATRAX STREAK + MOTOR 12T" não está mais disponível.
Sobrou somente
ESC NOVAK EXPLORER SPORT (COM SAÍDA PARA LUZ DE FREIO) PARA MOTOR ATÉ 15T
+ MOTOR STOCK 27T
ACRESCENTO MOTOR LATINHA + CABEÇOTE EXTRA PARA O MOTOR (COM ESCOVAS E MOLAS USADAS)
MensagemEnviado: Sex Jan 09, 2009 9:25 pm
Foto do combo que sobrou:
MensagemEnviado: Sáb Jan 10, 2009 9:20 am
Moderadores, podem remover.
MensagemEnviado: Sáb Fev 26, 2011 10:51 pm
Registrado em: Sex Jul 02, 2010 5:28 pm
+ MOTOR 12T DOUBLE
jah ta vendido?????
ImagemImagem
Side by Side Drift Team
