Bem-vindo: Sex Nov 06, 2026 4:42 pm
MensagemEnviado: Qua Set 24, 2008 4:56 pm
Registrado em: Dom Jul 15, 2007 4:42 pm
Pessoal estou colocando a venda um carregador com balanceadorTurnigy Accucel-6, nunca usado, vai na caixa com os plugs originais, segue foto dele e especificações:
The Turnigy Accucel 6 is an entry level balancing charger and discharger which can handle up to 6 cells and 5A.
The Accucel-6 will handle LiPo/LiFe up to 6S and NiMH/NiCd up to 15S and shows individual cell voltage during charge with realtime updates throughout the charge cycle.
Bundled with the Accucel-6 is a bunch of input and output wires which should satisfy any charging requirement.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~17v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Discharge current range: .1~1.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 355g
carrega life, lipo, Pb, nimh e nicd....possui balanceador para lipo...completo mesmo....
R$ 240,00
Yokomo MR-4TC
Traxxas E-maxx 3906 Full hop-up
Traxxas E-maxx 3905 (em processo de montagem)
Mamba Max
Feigão 6L
Turnigy
Lipo 3s 8000mah
Futaba 3PK
Editado pela última vez por MarcosCorreia em Seg Nov 03, 2008 4:57 pm, em um total de 1 vez.
MensagemEnviado: Seg Set 29, 2008 12:31 pm
MarcosCorreia escreveu:
Features;
Time limit function
Spec.
Weight: 355g
R$ 240,00
Yokomo MR-4TC
Mamba Max
Feigão 6L
Turnigy
Lipo 3s 8000mah
Futaba 3PK
MensagemEnviado: Seg Nov 03, 2008 4:20 pm
ja vendeu?
se eu retirasse na sua casa você faria por 220 reais?
Hobbyking 100A , 9T 4300kv
HPI TF1
Turnigy accucel
Lipos 2s 4200 / 3s 3600
MensagemEnviado: Seg Nov 03, 2008 4:56 pm
opa amigo, desculpe-me nem lembrava mais do topico, ja foi vendido sim...abraço
Yokomo MR-4TC
Mamba Max
Feigão 6L
Turnigy
Lipo 3s 8000mah
Futaba 3PK
Usuários navegando neste fórum: Google [Bot] e 2 visitantes
