Bem-vindo: Qui Out 22, 2026 2:06 am
MensagemEnviado: Qua Ago 06, 2008 9:01 pm
Olá pessoal estou vendendo s seguintes items:
Carregador LRP Pulsar Competition 3 Professional
Usado umas 10 vezes... perfeito na caixa...
Valor: VENDIDO
Site do Fabricante: http://www.lrp.cc/en/products/charge/charger-with-discharging-function/produkt/pulsar-competition-3/details/
Especificações:
* Charge NiMH - LiPo - NiCd • Fast charging 1 to 8 cells (NiMH/NiCd), 1 to 3 cells (LiPo), 0.1A to 10.0A on the fly. • 2 charge modes: Linear and Multi-Step with PCS-4 and adjustable Delta Peak (5-95mV) • Auto-Restart-System and Auto-Start-T
* Partial Charge Never store NiMH and LiPo-batteries empty. The PCC-3 features a “Partial Charge” mode for batteries. With this function you can set a fixed capacity value, e.g. 1000 mAh, and the PCC-3 will charge exactly this capacity amount into your battery. Your advantage: optimal storage ? optimal lifetime.
* Discharge NiMH - LiPo - NiCd • Discharge current 0.1A to 12.0A adjustable on the fly. Displays discharge time, capacity and average voltage. • Adjustable cut-off voltage from 0.9V to 7.2V • Matching Mode: fully automatic measurement of a battery pack
* Voltage-Output Function • Adjustable output from 1.0V to 12.0V / 20A • Can be used to break in brushes, run comm-lathes or power 7.2V soldering irons, tire warmers and many more.
* 25 years warranty
* Plug-in-and-Drive
* German Technology
* World Champions Technology
Fotos:
ESC LRP A.I. Super Reverse Digital
Pouco Uso ... Perfeito na caixa...
Valor: VENDIDO
Site do Fabricante: http://www.lrp.cc/en/products/electronic-speed-controls/car/produkt/ai-super-reverse-digital/details/
Especificações:
* LRP´s exclusive A.I. Automatic Setup
* 100% digital
* Fail Safe System
* Limited Lifetime Warranty
* Multi-Protection-System
* Plug-in-and-Drive
* Forward/Reverse speed control
* 25 years warranty
* 3x Multi Protection System
* BEC / Electric power supply of the receiver 5.0V
* Set-up Procedure automatic
* Fail Safe System Yes
* Weight 47.5g
* Size 42.5 x 42.5mm
* High frequency Yes
* Motorlimit over 13 turns
* Multi-Protection-System Yes
* Voltage Input 4-7 cells (4.8-8.4V)
* Connectors Standard Tamiya Style
* Rated Current 120A
* Typical Voltage Drop @20A 0.160V
* forward/brake/reverse Yes
Fotos:
Tx Futaba 4PK Super
Referências
Editado pela última vez por oficinaiti em Seg Out 27, 2008 5:44 pm, em um total de 6 vezes.
MensagemEnviado: Qua Ago 13, 2008 10:03 am
Registrado em: Qua Jul 23, 2008 5:08 pm
Ola amigo !!
Aceita trocar o carregador em um HPI MICRO RS4 NOVO ?
AbraçO!
TC5 / NTC3 FACTORY TEAM / NTC3 RTR
BRUSHLESS / NOVAROSSI LS3
MAZDA / DODGE / LOLA ...
FUTABA 3PM 2.4GHz
MSN - pit-bull__@hotmail.com
MensagemEnviado: Qua Ago 13, 2008 10:50 pm
Valeu amigo... mas por hora ... apenas venda... Aproveito para dizer q faço o carregador por R$330,00 com frete grátis por SEDEX!!!!
Tx Futaba 4PK Super
Referências
MensagemEnviado: Sex Ago 15, 2008 3:12 pm
Amigo ele carrega que tipo de bateria e até quantos mAh?
Obrigado !
FUTABA 3PM 2.4GHz
MensagemEnviado: Sex Ago 15, 2008 3:30 pm
Lucas Bastos escreveu:
Obrigado !
É SÓ LER O PRIMEIRO POST!!!!!!! :putz:
Falow,
Fernando - PaNeTo
Joguinho legalzinho!!
MensagemEnviado: Sex Ago 15, 2008 4:10 pm
Tá certo que você tá na tolerância zero Paneto, mas o indivíduo descreve o carregador em inglês... E se o cara não sabe inglês?
Na descrição diz que carrega Nixx e Lipo mas não informa até qual capacidade de bateria que ele carrega, mas por esse carregador ser bom acredito que carregue qualquer capacidade atual.
Fernando_Paneto escreveu:
Obrigado !
Falow,
Fernando - PaNeTo
MensagemEnviado: Sex Ago 15, 2008 4:31 pm
Olá ... ele Carrega NiMH, LiPo e NiCd. 1 até 8 células (NiMH/NiCd), 1 até 3 células (LiPo), de 0.1A até 10.0A.
Desconheço limite de MAh pra este carregador... vou ver mais tarde se o manual diz algo... e posto aqui.
[]'s
Rafael
Tx Futaba 4PK Super
Referências
MensagemEnviado: Sáb Ago 16, 2008 10:43 am
Precisa de fonte?
AbraçO!
FUTABA 3PM 2.4GHz
MensagemEnviado: Sáb Ago 16, 2008 10:47 pm
Registrado em: Dom Ago 10, 2008 8:25 pm
O ESC serve para motor Brushless? tem alguma limitacão?
que tipo de motor posso usar com esse ESC?
MensagemEnviado: Seg Ago 18, 2008 10:10 am
Janio escreveu:
O ESC não serve para Brushless. VocÊ pode usar qualquer motor Brushed até 13 Voltas...
Precisa de fonte?
AbraçO!
Sim... se você não utilizar ele na bateria do carro terá que usar uma fonte para conseguir os 12V. Eu modifiquei uma fonte de computador e estou usando ela aqui em casa... Não envio a fonte junto pq meu outro carregador também precisa dela...
Tx Futaba 4PK Super
Referências
MensagemEnviado: Ter Ago 19, 2008 2:48 pm
Novo Preço no Carregador e ESC... é pra levar pessoal... :D
Tx Futaba 4PK Super
Referências
MensagemEnviado: Dom Set 07, 2008 11:59 am
Torrando o carregador e ESC pessoal... vamo lah ;)
Tx Futaba 4PK Super
Referências
MensagemEnviado: Qua Out 01, 2008 10:26 pm
Dae pessoal... baixei tudo pra vender de vez...
[]'s
Rafael
Tx Futaba 4PK Super
Referências
MensagemEnviado: Qua Out 15, 2008 12:35 pm
Atualizando o tópico... ESC vendido...
Tx Futaba 4PK Super
Referências
MensagemEnviado: Qua Out 15, 2008 1:19 pm
Registrado em: Qua Out 03, 2007 8:35 am
já vendeu o carregador? vc é de onde?
LUIS HENRIQUE
SERPENT S411TE / HOBBYWING / SANWA M11X
