Bem-vindo: Dom Out 18, 2026 10:00 am
MensagemEnviado: Sex Mar 21, 2008 4:31 pm
VENDIDO
Vendo o carregador Piranha DC pela bagatela de R$ 50,00 ja vai com Plug Tamiya e um adaptador para usar Deans
Citação:
This is the DuraTrax Piranha DC Peak Charger.
*** Five-Year Warranty ***
FEATURES: Charges 6 or 7-cell NiCd and NiMH batteries with capacities ranging
from 1200-3600mAh
Fixed linear charge current at 4A and automatic fixed TRICKLE
Charge at approximately 50mA
Designed for cost-conscious car modelers who want the advantages of
Peak Charging
Push button start with twin LEDs to indicate Fast and TRICKLE Charge
status
80-minute safety timeout-if battery is unable to reach Peak Charge
Charger automatically shuts down Peak Charge process after 80 mins.
and goes directly to TRICKLE Charge
INCLUDES: One DuraTrax Piranha DC Peak Charger with standard output plug and
alligator input plugs
REQUIRES: Connecting to DC input power such as a 12V automotive battery or a
12V Power Supply such as the HCAP0250 (requires removing plastic
terminal covers on the output terminals of this power supply)
**Do not use automotive battery chargers**
SPECS: Input Voltage: 11-15V DC
Number of Cells: 6-7
Battery Capacities: 1200-3600mAh
Fast Charge Current: 4A fixed
Fast Charge Termination: Negative DeltaV Peak Detection
TRICKLE Charge Current: approx. 50mA
Output Connectors: Charge lead with standard plug
Fuse: Internal
Length: 4" (102mm)
Width: 3" (76mm)
Height: 1.6" (42mm)
Weight: .44lb (196g)
MensagemEnviado: Sáb Mar 22, 2008 10:07 pm
Registrado em: Seg Mai 28, 2007 2:21 pm
cold, eu fico com ele!! eu ainda num tinha comprado do coelho e ele ja vendeu!!!
MensagemEnviado: Sáb Mar 22, 2008 11:27 pm
Drifter escreveu:
Puts Drifter, vc sumiu meu....achei que tinha desencanado....
Foi maus...
[]'s
PacaLoucos
MensagemEnviado: Seg Mar 24, 2008 2:55 pm
Coelho escreveu:
Drifter escreveu:
Foi maus...
[]'s
num tem problema não cara!! relax
MensagemEnviado: Qua Mar 26, 2008 9:21 pm
VENDIDO PARA O NOSSO AMIGO MAGRO!!
valeu velinho!! sempre bom fazer negócio com vc!!
