Bem-vindo: Seg Out 19, 2026 6:42 am
MensagemEnviado: Qua Fev 20, 2008 10:32 am
Registrado em: Ter Jun 12, 2007 3:33 pm
Galera,
Estou querendo investir em um novo projeto de RC. Por isso estou "dando" meu Brushless Novak rsrsrs.
"NOVAK SUPER SPORT PLUS + MOTOR SS5800"
Está na CAIXA com TODOS os MANUAIS!
Esta é a oportunidade pra quem sempre quis comprar um Brushless. Por esse preço e com essa qualidade, nem importando!
Excelente Brushless anda muito e a marca dispensa comentários.
Bateu a incrível velocidade de 85km/h no meu off-road.
Agora vamos ao que interessa.
PROMOÇÃO SÓ ESSA SEMANA por R$399,00
Fotos:
http://img340.imageshack.us/img340/6065/dsc02635up5.jpg
http://img168.imageshack.us/img168/4546/dsc03303ad9.jpg
http://img256.imageshack.us/img256/8761/dsc03295kv0.jpg
http://img504.imageshack.us/img504/4825/dsc03299xk8.jpg
http://img174.imageshack.us/img174/16/dsc02711ahb8.jpg
Segue as especificações:
SUPER SPORT PLUS ESC SPECIFICATIONS
BRUSHLESS MODE SPECIFICATIONS
Motor Limit: 225 Watts (Compatible with Novak SS5800 and SS4300 motors)
On-Resistance: 0.0019 ohms (per each phase-3)
Rated Current: 160 amps (forward/reverse); 160 amps (brake)
BRUSHED MODE SPECIFICATIONS
Motor Limit: 12-turn r/c brushed motor
On-Resistance: 0.0006 ohms
Rated Current: 480 amps (forward); 480 amps (brake)
COMMON SPECIFICATIONS
Input Voltage: 4-7 cells (1.2V/cell)
Case Size: 1.32? x 1.75? x 1.05? (w/heat sink); (33.5mm x 44.5mm x 26.7mm)
Weight: 1.7 oz.; 48.2 g (without power wires)
BEC: Heavy-duty 6.0 volt/3.0 amp
Discrete Steps: 1024 (512 forward, 512 brake/reverse)
SS5800 BRUSHLESS MOTOR FEATURES
Virtually maintenance-free: no brushes, brush springs, or commutator to true or wear out
Completely enclosed motor provides protection from the elements
Sensor technology provides excellent starting torque and continuous synchronization for great, low-speed driveability, vehicle control, and consistent, accurate brakes
Standard 540-size car motor with a 1/8" diameter hardened output shaft to accept all existing pinion gears
High performance design: Kv=5,800 RPM/Volt; Kt=0.45 in-oz/amp; Power output: 196 watts (See above for definition of Kv and Kt)
Pre-wired and ready to install
Low cogging for smooth acceleration and smooth coasting (See above for definition)
Ball bearings for smooth, low-friction operation
Direct-solder wiring tabs for easy wire replacement
One-piece, multi-pole cylindrical neodymium magnet for high reliability, and stationary windings for better heat conduction over brushed motors
Qualquer dúvida é só falar.
Veja meus outros produtos a venda:
viewtopic.php?f=4&t=5091
Dando um tempo no Hobby.
Vendendo tudo ... aceito trocas e propostas:
VENDO Chassis Buggy 1/8
VENDO Esc 100A + Progr. card + Ubec 7,5A
VENDO Bolha 1/8 Dodge Viper + Rodas e pneus
VENDO Vários itens - Meu E-SHOP
MINHAS QUALIFICAÇÕES
Editado pela última vez por rogeriomila em Seg Mar 03, 2008 8:51 am, em um total de 1 vez.
MensagemEnviado: Qua Fev 27, 2008 8:49 am
Para Conhecidos faço até 2 vezes.
Ou seguro um cheque pra 30 dias.
Ou então em até 12 vezes pelo Mercado Livre.
Valeu ...
Usuários navegando neste fórum: Google [Bot] e 2 visitantes
