Bem-vindo: Sex Nov 06, 2026 9:43 am
MensagemEnviado: Seg Fev 02, 2015 3:08 pm
Registrado em: Qui Out 05, 2006 12:10 am
Images: 1
Pessoal,estou colocando a venda o rádio que corri o ano passado, está rádio está entre os 10 mehores do mundo para automodelismo, tempo de resposta dele é 5,5ms
Ele está em perfeito estado, não tem nada quebrado o com defeito, radio muito novo mesmo.
Junto com o rádio mando bateria lipo e dois receptores de 5 canais.
O valor desse rádio na amainhobbies é $399
http://www.amain.com/radiopost-ts401-g2 ... rs/p404391
Vou colocar a venda por R$ 850,00
Esse valor pode ser pago no cartão pelo mercado pago ou pague seguro, porem o comprador vai arcar com as taxas dos sites
Features:
VERSION 4.11
LCD Swivel: First Ever Color LCD Screen (6 color modes to choose from). LCD can swivel vertical or horizontal to expose the menu keys.
Internal Antenna: High efficiency antenna provides excellent performance and no more antennas to break. Another first from Radiopost
Direct Sequence 2.4GHz Technology: No more frequency hopping, a direct digital signal provides excellent feel and ultra fast response.
3 Selectable Modes of Transmit Speeds: You have the option to increase or decrease the speed allowing the use of analog and digital servos
Easy to Use Interface: No more searching through long complicated menus. The ability to scroll and find what you need when you need it is our goal.
Light Weight Performance: Transmitter is designed to have a balanced feel when operated. The radios efficiency allows you to use 5 dry cells or a Radiopost 6.6V LiFe (sold separately) making it one of the lightest and efficient transmitters in the market.
Customizable Settings: The steering and throttle trigger spring tension can be infinitely adjustable to customize the feel. The drop down can be angled to the users preference.
Drop Down Included: A drop down wheel is included to enhance the comfort in those long mains. The wheel drop down has been optimized for increased comfort and performance.
Easy Left Hand Adjustability: The process of adjusting the drop down from right to left handed is a breeze. Just 4 screws and the included wire is all you need. No more fishing the wires from one side to the other. No more dealing with extra parts and screws.
Specifications:
Transmitter:
Model: TS401
Channel: 4 Ch - 9 Ch Receivers can be used
Frequency: 2.4GHz Band SDS
Operating Voltage: 4.4V ~ 8.4V
Frame Rate Speed: 5.5ms, 10.5ms & 16.5ms
Screen Resolution: 240 x 400 (WQVGA)
Power Supply: 5 AA Alkaline Dry Cell DC 7.5V
Weight: 1.42 lbs / 646g (Without Battery)
Dimension (HxWxD): 9.05x7.08x5.5"
Receiver:
Model: RP24RA5DX
Channel: 5 Ch
Frequency Bandwidth: 2.405~2.480 GHz
Power Consumption: 47mA
Size (HxWxD): 22.3x37.2x13.3mm
Weight: 7.5g
Operating Temp: -20 Degree to +60 Degree C
Rated Voltage: 3.0 V ~ 8.4 V
Valor R$ 850,00
====Garagem====
E-Revo 1/10 - TrackStar 2560Kv
Truggy Losi 8ight - TrackStar 2560Kv
Buggy Losi 8ight - Xerun 2200Kv
Inferno VE - Tork 2650Kv
DBX 1.0 E - EZrun 4000Kv
Micro Losi 1/36
Spektrum DX3S
Meus Tópicos
VENDAS
QUALIFICAÇÕES
MensagemEnviado: Seg Fev 23, 2015 5:10 pm
Registrado em: Seg Fev 23, 2015 5:05 pm
boa tarde eu me interesso no seu radio tem com anunciar no ML
MensagemEnviado: Seg Fev 23, 2015 5:23 pm
Images: 1
Daniel Paula escreveu:
Boa tarde Amigo,
Desculpe mais o rádio foi vendido fora do site.
====Garagem====
Micro Losi 1/36
Spektrum DX3S
Meus Tópicos
VENDAS
QUALIFICAÇÕES
