Bem-vindo: Sex Nov 06, 2026 2:38 pm
MensagemEnviado: Dom Jul 06, 2014 3:23 pm
Registrado em: Sáb Set 07, 2013 6:28 pm
Images: 17
Vendo Kit brushless 5050Kv + Bateria Lipo Zippy 2200Mha 20c, estavam montados em um buggy himoto 1/16 e faziam o carro dar aprox 60km/h e um run time de +- 50 min
ESC Specification:
Cont. Current: 18A
Burst Current: 25A
Car Size: 1/18th
Battery: 2-3 Cell Lipo / 4-9 Cell Ni-XX
L-BEC: 5V / 1A Output
Motor Type: Sensorless Brushless
Size: 30 x 26.1 x 13.8mm
Weight: 26g (Including wires)
Motor Plugs: 3.5mm Bullet type
Battery Plug: Required
On/Off Switch: Yes
Reverse: Yes
Motor Specifications:
Turns: 12T
KV value: 5050KV
Poles: 4
Diameter: 21.5mm
Motor length: 37mm
Extend shaft diameter: 2mm
Length of extend shaft: 11±0.5mm
Weight: 60g
No loading @ 7.2V: 2.2A
Max current: 34A
Resistance (Ω): 0.027Ω
Battery range: 2~3s 7.4v~11.1v
Operation Temperature: 80°
Max Temperature 130°
Suitable car scale: 1/18
Suitable ESC: 25A
Thickness of lamination: 0.2X20mm
Battery Spec.
Capacity: 2200mAh
Voltage: 2S1P / 2 Cell / 7.4v
Discharge: 20C Constant / 25-30C Burst
Weight: 133g (including wire, plug & shrink wrap)
Dimensions: 104x34x17mm
Balance Plug: JST-XH
Foto:
http://img822.imageshack.us/img822/9900/dcum.jpg
Tudo por R$ 100,00 + frete
MensagemEnviado: Dom Jul 06, 2014 3:48 pm
Registrado em: Seg Dez 17, 2012 2:10 am
MP!
MensagemEnviado: Seg Jul 07, 2014 12:42 pm
Images: 17
VENDIDO
