Bem-vindo: Sex Nov 06, 2026 4:43 pm
MensagemEnviado: Ter Abr 01, 2014 7:29 pm
Registrado em: Dom Nov 20, 2011 11:32 am
Yefa escreveu:
Yefa escreveu:
Contato - Fábio
fabiomalves34@gmail.com
HPI WR8 KEN BLOCK GYMKHANA
FORD FIESTA
UM CANHÃO - 60MPH - 100 KM/H
TRAÇÃO 4X4 - ESCALA 1/8
***** NOVO NA CAIXA *****
PREÇO - R$ 2200,00
Vídeo HPI:
PREÇO - R$ 2200,00
Detalhes do Produto:
This is the Electric Powered, 2.4GHz Radio Controlled, 1/8 Scale,
Ready to Run WR8 Flux Ken Block Ford Fiesta Rally Car from HPI.
FEATURES: Chassis: 0.12" (3mm) thick silver anodized aluminum with composite
front and rear braces and plastic side dirt guards
Drive: Four wheel shaft
Radio: HPI TF-40 2.4GHz 3-channel with steering and throttle end
point adjustment, trim and dual rates, fail safe and SF10W
waterproof analog steering servo
Motor: Flux Vektor 4000kV brushless
ESC: Flux Vapor Pro with reverse, cooling fan and fully programmable
with the #100573 Castle Link USB Programmer, HPIC0573 (not
included)
Differentials: Three, adjustable bevel gear type, oil filled
Shocks: Oil-filled, composite body with rear mud guards
Suspension: Front and rear sway bars, composite lower suspension arms
and solid upper links
Tires: Scale Michelin Tarmac Rally, 1.4" (35mm) wide, 3.1" (80mm)
diameter
Wheels: Tarmac Spec plastic 1.4" (35mm) wide, 2.2" (56mm) diameter,
12mm hex size
Ball Bearings: Full set
Pinion Gear: 15 tooth
Spur Gear: 46 tooth composite
Body: Trimmed and painted white with all sponsor decals applied
Bumper: Front foam with plastic raised skidplate that allows car to
slide over objects in the road
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Non-Adjustable camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Warranty: 2-year limited through manufacturer, valid only in USA,
Canada and South America
INCLUDES: HPI RTR WR8 Flux Ken Block Ford Fiesta Rally Car with 2.4GHz Radio
System, ESC, Brushless Motor, Body, Transmitter and
Instruction Manual
REQUIRES: LiPo Battery: 2-3S LiPo with at least 25C rating and 3500mAh and
Deans plug
Battery Charger: Compatible with selected battery
LiPo Charging Bag
Building and track equipment
SPECS: Vehicle-
Length: 19.1" (485mm)
Width: 8.9" (227mm)
Height: 6.8" (172mm)
Wheelbase: 11.8" (300mm)
Body-
Length: 18.9" (480mm)
Width: 8" (203mm) behind front wheels, narrowest point
9.1" (232mm) at rear wheels, widest point
Height: 6" (153mm)
Fábio Alves ( Yefa ) - fabiomalves34@gmail.com
E-MAXX Brushless Mamba Monster
Stampede Castle Sidewinder SV2
Summit 1/10
MensagemEnviado: Qui Mai 08, 2014 5:00 pm
Registrado em: Qua Fev 26, 2014 2:21 pm
Interessa a troca do Combo que tem nele !!!
Usuários navegando neste fórum: Google [Bot] e 2 visitantes
