Bem-vindo: Sáb Mar 28, 2026 9:30 pm
MensagemEnviado: Sex Nov 15, 2013 7:45 pm
Registrado em: Ter Jun 04, 2013 9:11 pm
mEU IRMAO TROUXE UMA ESC DE FORA PRA MIM, MAS COMPROU ERRADO, POR ISSO TO VENDENDO.
NUNCA FOI USADA TA NA CAIXA COM TUDO QUE VEIO. CAIXA LACRADA.
VALOR: 150,00 + FRETE
obs: SEM PROGRAM CARD
DESCRIÇÃO DA ESC
Features:
1. Water-proof and dust-proof.The ESC can wrok under water for a short time.
(please remove the cooling fan when running car in water,and after running,please make the ESC clean and then dry it to avoid the oxidation to copper connector)
2. Specially designed for RC car and truck,with excellent start-up,acceleration adn linearity features.
3. Compatible with sensorless brushless motor.
4. 3 running modes suitable for different applications ("Forward with brake” mode, "Forward/Backward with brake" mode and "Rock crawler" mode).
5. 4 steps of maximum reverse force adjustment.
6. Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
7. 9 start modes ("Punch") from "Soft" to "Very aggressive" to be suitable for different chassis,tires and tracks.
8. Multiple protection features: Low voltage cut-off protection for Lipo or NiMH battery / Over-heat protection
/ Throttle signal loss protection / Motor blocked protection.
9. 8 steps of timing adjustment.
10. Several programming methods are supported,such as: The "SET" button on the ESC,the LED program card,the advanced LCD Program Box,and the PC Software.
11. The firmware of ESC can be online updated through an USB adapter on the advanced LCD program box.
Specifation:
Model: EZRUN-WP-80A
Cont.Current: 80A
Burst Current: 540A
Resistance: 0.0004 ohm
Suitable Car: 1/10 scale on-road/off-road/SCT/Monster
Suitable motor: 2S Lipo /6 cells NiMH: ON-road:>=5.5T ,3650 size motor
SCT/Monster:KV=6000, 3656/3660 size motor;
3S Lipo/9 cells NiMH: ON-road:>=8.5T ,3650 size motor
SCT/Monster:KV=4000, 3656/3660 size motor;
Battery: 4-9 Cells NiMH or 2-3S Lipo
1)For 4-6 Cells NiMH or 2S Lipo: You needn't change the 5V cooling fan on the ESC;
2)For 7-9 Cells NiMH or 3S Lipo: You must change the original 5V cooling fan to 12V cooling fan,or supply the
5V cooling fan from the receiver (5-6V);
BEC: 6V/2A (Linear mode built-in BEC)
Motor Type: Sensorless Brushless
Dimension: 46*34*35
Weight (with all wires): 82g
fotos tiradas da internet, quem tiver interesse so entrar em contato.
NA GARAGEM:
KYOSHO INFERNO VE RACE SPEC
HPI VORZA FLUZ HP
MensagemEnviado: Seg Nov 25, 2013 3:20 pm
Registrado em: Sex Fev 17, 2012 12:05 pm
Brother tu é de que estado? e quanto ficaria o frete para o cep:70.306-000?
Tamyia TRF 416
Sakura D3 CS Sport
Traxxas Slash 4x4
Referências aqui!
MensagemEnviado: Seg Nov 25, 2013 3:22 pm
Acabei de vender amigo.
NA GARAGEM:
HPI VORZA FLUZ HP
