Bem-vindo: Dom Mar 29, 2026 5:30 am
MensagemEnviado: Qua Nov 06, 2013 9:22 pm
Registrado em: Sáb Ago 08, 2009 9:46 pm
[VENDO] PEÇAS AVULSAS TEAM ASSOCIATED 1/8 compativeis com SC8/RC8/RC8T
Valor das peças + Envio
ASC89051 - Team Associated Factory Team Threaded Shock Body Rear (RC8) (2) R$ 80
ASC89028 - Team Associated Steering Blocks (RC8/RC8T) R$ 80
ASC89366 - Associated RC8T Front/Rear CVA Bones R$ 70
ASC89091 - Team Associated Factory Team Sway Bar Socket Joint (RC8) (4) R$ 60
ASC89310 - Team Associated Upper & Lower Front Arm Set R$ 50
ASC89029 - Team Associated Steering Block Bushings (RC8) R$ 40
ASC89162 - Team Associated 15x21x4mm Bearing R$ 40
ASC89320 - Associated RC8T Front Chassis Brace R$ 30
ASC89357 - Team Associated 16x38mm Rear Shock Boot Set (4) R$ 30
ASC89356 - Team Associated 16x32mm Front Shock Boot Set (4) R$ 30
ASC89017 - Team Associated Front or Rear Gear Box (RC R$ 30
ASC89229 - Team Associated Blue Countersunk Washer (10) R$ 30
ASC89316 - Associated RC8T Shock Risers w/Pins R$ 30
ASC89396 - Team Associated 16mm RTR Preload Clip Set R$ 30
ASC89008 - Team Associated Throttle Servo Horns (RC8) (4) R$ 30
ASC89065 - Team Associated Shock Rod Ends (RC8) (4) R$ 30
ASC89090 - Team Associated Antiroll Bar Ball Joint (RC8) (4) R$ 30
ASC89031 - Team Associated Caster/Hub Spacers (RC8) (8) R$ 20
ASC89092 - Team Associated Antiroll Bar Retainer/ Eyelets (RC8) R$ 20
Foto das peças
http://imageshack.us/photo/my-images/197/5h71.jpg/
Off Road - Team Associated RC8te - Trackstar 2100kv
MensagemEnviado: Qui Nov 21, 2013 4:16 pm
ASC89017 + horns
ASC89017 - Team Associated Front or Rear Gear Box (RC R$ 30 VENDIDO PARA O USUARIO MACH
MensagemEnviado: Dom Dez 01, 2013 11:21 am
tudo vendido.
