Bem-vindo: Sáb Nov 28, 2026 10:05 am
MensagemEnviado: Ter Abr 09, 2013 6:40 pm
All ...
A Venda ... Trail Finder 2 Truck Kit w/Mojave Body Set - RC4WD - (R$ 2.399,00) ... na caixa ... zerada ... sem montar ... necessário toda a parte eletrônica (exe.: rádio, receptor, servos, motor e esc) ... interessados, favor entrar em contato via mensagens privadas, e-mail rubenssilvestre@gmail.com ou celular 011-9-9286-7126
"...Custom Designed for True-to-Scale Looks
Realistic Billet Aluminum Ladder Frame Chassis
2 Speed Remote Selectable Transmission
Center Mounted Realistic 4x4 Transfer Case
Cast Metal Axles with Locked Differentials
True to Scale Leaf Spring Suspension
Highly Detailed Body with Dropped Bed and More
1.55 Stamped Steel Beadlock Wheels with Lug Nuts
Super Grip High Performance Mud Thrasher Tires
Realistic Tube Bumpers - Rock Rails - Skid Plate..."
All New Hammer Transfer Case
Ratio - 1.47:1 Gears - Wide 32P steel gears Features - 8 bearings, cast casing, hardened gears
All New R3 2 Speed Transmission
Ratios Pinion/spur 14/64 = 4.57:1 1st gear
3.47:1 2nd gear 1.27:1
Gears - Wide steel 32P, Delrin spur, slipper clutch,
Features - Machined billet aluminum casing, scale looking, Motor mount can be rotated to 10 different positions,
compatible with other brand spurs (Axial, Traxxas, Robinson)
Cast Yota Axles
Ratio: 15/40 = 2.67:1 Width at hex (using 4mm TF2 hexes): 176.5mm
All New Trailfinder 2 Chassis
Features - Billet aluminum constriction Adjustable shock hoops
Driveshafts
High quality plastic material, very durable High quality steel Yokes
Wheels
Name: 1.55 OEM beadlock wheels Hub: 12mm hex Width: 22mm Back spacing: 9mm
Features: Stamped steel, aluminum hub, internal beadlock, very scale looking, 6 bolt pattern,
Bumpers
Tough Armor TF2 Winch front bumper Tough Armor TF2 Rear Bumper Tough Armor TF2 Side Sliders Authentic
looking crawler style tube bumper. Very high quality flexible plastic, very durable, very scale.
TF2 Truck Dimensions
Wheels base: 287mm (11.3") Width:
215mm (8.5") Height: 210mm (8.25")
Ground clearance: 57mm (2.5")
Final Drive Ratios: 1st - 62.1:1, 2nd - 22.75:1
Mais algumas fotos ilustrativas de modelos finalizados e com acessórios a serem adquiridos a parte (via encomenda) ...!!!
Necessário saber o local para envio e, desta forma, calcular ou negociarmos o frete ou a entrega ... caso tenham interesse em parcelamento ... este poderá ser feito via Mercado Livre ...!!!
São Paulo/SP - Brasil
MensagemEnviado: Ter Abr 09, 2013 8:17 pm
ML - http://produto.mercadolivre.com.br/MLB- ... -rc4wd-_JM
MensagemEnviado: Qua Abr 10, 2013 9:30 am
Pts é o melhor trial que já vi, não quis montar ele? Pena q não moramos perto pq senão seria eu, tu e o andy andando com as trail finder 2 hehehehehe, recomendo 100% o carro é ótimo mesmo.
Tá nervoso? Vai pilotar!
MensagemEnviado: Qua Abr 10, 2013 10:21 am
Images: 5
Moisés escreveu:
Melhor trial com certeza, o curso da suspensão é ótima, nem tem necessidade de 4 link.
Se vc montar não vai querer vender não Rubens, tbém recomendo 100%...
Só entende isso q eu estou falando quem tem um na garagem...
Espero q o futuro comprador confirme o q a gente falou acima, abração Rubens...
MensagemEnviado: Qua Abr 10, 2013 11:55 am
andyadesivos escreveu:
Moisés escreveu:
Andy e Moises ... pois é umas prioridades mudaram e não vou poder monta-la ... se puderem divulgar entre amigos ... eu agradeço ...!!!
Andy ... este fds estarei em CWB ... vou levar as longarinas ...!!!
MensagemEnviado: Qua Abr 10, 2013 12:15 pm
Images: 5
caramelospeed escreveu:
Moisés escreveu:
Vou divulgar sim, só reforçando, quem comprar não vai se arrepender, é um rc c/ o preço um pouco mais salgado q os outros, mas vale cada centavo.
Eba, me passa seu número novamente por mp p/ gente se encontrar Rubens, abração...
MensagemEnviado: Qui Abr 11, 2013 7:07 pm
MensagemEnviado: Dom Abr 14, 2013 6:07 pm
Registrado em: Qua Mai 09, 2012 1:47 am
Proposta boa demais pra vc, quer troca na "oreia" num traxxas XO-1 zero na caixa sem uso?
Ele ta anunciado no ML por 3099,00. Se topar faço a troca sem volta.
MensagemEnviado: Ter Abr 16, 2013 10:35 am
marcosrings escreveu:
Marcos,
Beleza ...???
Seguinte ... não consegui a triangulação que eu pretendia ... portanto não vou poder fzr a troco.
Obrigado pela proposta ...
MensagemEnviado: Ter Abr 16, 2013 11:18 am
Te mandei um mail Rubens.
MensagemEnviado: Qui Abr 18, 2013 8:02 am
Esse vem pra Maringá.
Já que comprei esse kit vou vender meu axial, tá novo e nunca usado, tá cheio de upgrades.
contato pelo eu mail marcosrings@gmail.com
MensagemEnviado: Qui Abr 18, 2013 10:35 am
KIT VENDIDO PARA O MARCOS, CONFORME MENSAGEM ACIMA ... PARABÉNS MARCÃO ... TENHO CERTEZA QUE VAI PIRAR NESTE KIT ...
MensagemEnviado: Qui Abr 18, 2013 11:13 am
Registrado em: Seg Mar 14, 2011 10:03 pm
Cria o tópico de venda com fotos Marcos, certeza que aparece um comprador!
Rubens, fecha o tópico para ir para o histórico! Lá no topo tem a opção :drinks:
Jeep Wrangler Crawler - Timberwolf 1/10
Cherokee Black - Venom Creeper 1/10
Land Defender 90 Orange
Cherokee Black/Orange - SUMMIT 1/8
CJ-3A Jeep Dragon 1/6
RC Trial Circuit - SP/BR
MensagemEnviado: Ter Abr 30, 2013 6:02 pm
CAROS ... CASO MAIS ALGUEM TENHA INTERESSE NESTE MODELO, FAVOR ENTRAR EM CONTATO VIA MP ...!!!
