Bem-vindo: Ter Ago 12, 2025 12:52 pm
MensagemEnviado: Qua Nov 21, 2012 9:25 am
Novo na caixa, nunca andou. R$1500+frete
Vai sem rodas e pneus, o buggy + bolha.
Pra andar voce precisa de motor, esc, receptor, bateria, rodas e pneus.
This is the electric powered, radio controlled, 1/8 scale
Mugen MBX6-ECO Off Road Buggy factory built kit.
FEATURES: Chassis: A7075 T6 aluminum 0.12" (3mm) thick
M Spec - Factory built kit
Drive: Four wheel three differential shaft drive
Shocks: Four oil filled 15mm aluminum body
Shock Towers: 0.16" (4mm) thick carbon graphite
Gearbox: Sealed, front and rear
Differentials: Planetary geared
Motor Mount: Two piece
Transmission: Single-speed
Ball Bearings: Full set
Suspension: Pillow ball
Body: Clear buggy type
Pinion: 14T
Spur Gear: 46 tooth
Battery/ESC tray: Accomodates two batteries
Camber Tie Rods: Adjustable, Camber describes the angle at which the
tires sit vertically
Steering Tie Rods: Adjustable, Caster/Toe-in is the angle at which
the tires point inward as viewed from above
Steering: Bell-crank type, with carbon graphite steering brace and
adjustable Ackerman. Ackerman describes the effect of the inside
front wheel turning faster than the outside front wheel during
turns
INCLUDES: Mugen MBX6-ECO Off Road Buggy Kit with clear buggy body,
rear wing, decal sheet, window mask sheet, battery/ESC tray,
14t pinion and illustrated instrucion manual
REQUIRES: Motor: 1/8 scale brushless motor
ESC: 1/8 scale brushless motor compatible ESC
Radio: 2-channel with standard servo for throttle
Building and track equipment
SPECS: Vehicle
Length: 18" (457mm)
Width: 12-1/8" (309mm)
Wheelbase: 12.5 - 12.75" (320 - 325mm)
Gear Ratio: 11.12:1
Weight: 7.4lb (3,370g)
Body-
Length: 13" (330mm)
Width: 6.9" (177mm)
Height: 3.9" (101mm)
Editado pela última vez por sabongi em Ter Nov 27, 2012 11:42 am, em um total de 1 vez.
MensagemEnviado: Seg Nov 26, 2012 4:17 pm
Quem fechar até quarta feira ganha frete PAC free!
MensagemEnviado: Seg Nov 26, 2012 7:30 pm
Foto real
MensagemEnviado: Ter Nov 27, 2012 11:41 am
VENDIDO
MensagemEnviado: Ter Dez 11, 2012 12:51 pm
Registrado em: Ter Ago 23, 2011 8:40 pm
sabongi escreveu:
VENDIDO
Bom dia Sabongi
Estou querendo vender o meu Mugen eco que compei de voce
ainda não andou esta na caixa novo.
estou pedido 1500,00 mais frete
obrigado.
Obrigado a todos.
Ivar
Mugen MBX6 ECO
Vorza HPI
Micro Losi
Monster Beatle
Inferno MP-5
