Bem-vindo: Dom Out 11, 2026 7:41 pm
MensagemEnviado: Qui Out 11, 2012 7:17 pm
Registrado em: Seg Mar 05, 2012 8:59 pm
Vendido!!!!
Vendo 2 pçs - Turnigy nano-tech 8400mah 3S 40~80C Lipo Pack
Valor R$ 250,00 (cada)
High performance replacement for Traxxas TRA2878. Fits Slash VXL and Slash 4x4 (battery expansion kit required, not recomended for brushed motor models)
Add extreme power and performance to your Traxxas vehicle with this high discharge, high capacity TURNIGY nano-tech battery!
More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are built with an LiCo nano-technology substrate complex greatly improving power transfer making the oxidation/reduction reaction more efficient, this helps electrons pass more freely from anode to cathode with less internal impedance.
In short; less voltage sag and a higher discharge rate than a similar density lithium polymer (non nano-tech) battery.
For those that love graphs, it means a straighter, longer curve. For pilots it spells stronger throttle punches and unreal straight-up performance.
Excellent news for 3D pilots!
Unfortunately with other big brands; numbers, ratings and graphs can be fudged. Rest assured, TURNIGY nano-techs are the real deal, delivering unparalleled performance!
Spec.
Capacity: 8400mAh
Voltage: 3S2P / 3 Cell / 11.1V
Discharge: 40C Constant / 80C Burst
Weight: 641g (including plug & case)
Dimensions: 157 x 45 x 45mm
Discharge Plug: TRX plug
*The nano-core technology in lithium ion batteries is the application of nanometer conductive additives.
1) The nanometer conductive additives form ultrastrong electron-conducting networks in the electrodes which can increase electronic conductivity.
2) These additives create a superstrong ability for imbibition in the carrier liquid to supply more ion channels. This improves the ability of ion transmission and ion diffusion.
Through improving electronic conductivity and ion transmission, the impedance is reduced and the polarization of high rate discharge decreases greatly.
Advantages over traditional Lipo batteries;
-Power density reaches 7.5 kw/kg.
-Less Voltage sag during high rate discharge, giving more power under load.
-Internal impedance can reach as low as 1.2mΩ compared to that of 3mΩ of a standard Lipoly.
-Greater thermal control, pack usually doesnt exceed 60degC
-Thickness swelling during heavy load doesnt exceed 5%, compared to 15% of a normal Lipoly during heavy load.
-Higher capacity during heavy discharge. More than 90% at 100% C rate.
-Fast charge capable, up to 15C on some batteries.
-Longer Cycle Life, almost double that of standard lipoly technology.
Claudio Vidal
cr_vidal@yahoo.com.br
Carros:
Duratrax Evader Brushless
Traxxas Slash 4x4 Ultimate
Editado pela última vez por cr_vidal em Sáb Out 13, 2012 6:04 pm, em um total de 1 vez.
MensagemEnviado: Sex Out 12, 2012 2:38 pm
Registrado em: Ter Out 02, 2012 8:59 am
Tenho interese mande e-mail para wagner@agisistemas.com.br sou de Sp - Capital ja mandei uma resposta a vc mas nao tive sua resposta.
MensagemEnviado: Sex Out 12, 2012 5:10 pm
faz sedex gratis para interior de sp para fecharmos as duas?
AT.
Fernando
QUALIFICAÇÕES
viewtopic.php?f=3&t=23242
MensagemEnviado: Sex Out 12, 2012 10:06 pm
PITOCCAO escreveu:
Amigo, envio sim por Sedex.
Me mande uma MP para fechar o negócio.
Abs,
Claudio Vidal
Claudio Vidal
Carros:
MensagemEnviado: Sex Out 12, 2012 10:08 pm
wagnersahara escreveu:
Wagner, td bem?
Recebi sua MP e respondi, dou preferencia para fechar as duas em conjunto.
Caso não feche com o PITOCCAO as duas elas ainda estão disponíves, caso vc queira só uma sem problemas.
Abs,
Claudio Vidal
Claudio Vidal
Carros:
MensagemEnviado: Sex Out 12, 2012 10:11 pm
mandei mp para fecharmos as duas
AT.
Fernando
QUALIFICAÇÕES
MensagemEnviado: Sex Out 12, 2012 10:47 pm
pgto efetuado comprovante enviado por mp
AT.
Fernando
QUALIFICAÇÕES
