Bem-vindo: Dom Nov 29, 2026 4:14 am
MensagemEnviado: Ter Jul 17, 2012 6:04 pm
Registrado em: Ter Jun 26, 2012 10:31 pm
VENDO CARREGADOR DURATRAX-ICE, EM ÓTIMO ESTADO DE CONSERVAÇÃO.
SPECIFICATIONS
Input Voltage: 11-15V DC
Battery Types, # of cells:
1-10 Nickel-Cadmium cells (1.2 - 12.0V NiCd)
1-10 Nickel-Metal Hydride cells (1.2 - 12.0V NiMH)
1-4 Lithium-Ion or Lithium-Polymer cells (3.6 - 14.8V Li-Ion/Li-Po)
Battery Capacity Range: 100-9900mAh
Fast charge current: 0.1 - 8.0A (1C max for Li-Ion/Li-Po)
Fast charge methods: linear, reflex, impulse and 4-step
Fast charge termination:
peak detection for NiCd and NiMH
constant current/constant voltage for
Li-Ion/Li-Po (cc/cv) optional thermal cutoff for all battery types
Peak Sensitivity: 0 - 25mV adjustable
Trickle Charge Current: 0 - 500mA (n/a for Li-Ion/Li-Po)
Top-off Charge: 0 - 1000mA (NiMH only)
Discharge Current: 0.1 - 10.0A adjustable (2C max for Li-Ion/Li-Po)
Discharge Cutoff Voltage: 0.1 - 1.1V per cell NiCd & NiMH 2.5 - 3.7V per cell Li-Ion/Li-Po
Temperature Cutoff Range: 50 - 132° F
Cycle Count: 1-10 cycles (n/a for Li-Ion/Li-Po)
Cycle Cool-off Delay: 1-30 minutes adjustable
Battery Memories: 10 battery memories
Display Type: 8 x 21 LCD (168 characters max)
Graphical Displays: graphs charge and discharge voltage curves
Output Connectors: banana jacks (two adapter leads included)
Motor Break-in: 1.0 - 8.0V selectable, 1 - 180 minutes, 10A constant, 30A surge
Case Size: 5.5 x 1.8 x 5.9" [140 x 45 x 150mm]
Weight: 21 oz. [605g]
**************NÃO ACEITO TROCAS*****************
VALOR R$ 250,00
