Bem-vindo: Sex Ago 15, 2025 6:43 pm
MensagemEnviado: Sex Jun 29, 2012 11:10 pm
Registrado em: Ter Ago 09, 2011 2:27 am
Images: 19
Pessoal,
Estou colocando a venda(no momento seria uma reserva pois ainda não chegou no Brasil), um chassis do Kyosho Mini-Z MR03 Chassis Set ASF 2.4GHz 2012 SP Limited Edition Yellow.
PEÇA ÚNICA!!!!!!
Esse modelo trata-se de uma edição limitada(somente 1500 peças produzidas) repleta de acessórios e opcionais originais Kyosho, incluindo diferencial de esfera, rolamento, motor X-Speed, amortecedor a óleo, e muitos outros upgrades que fazem desse carro o melhor custo benefício do mercado!!!!! Lembrando que o modelo MR03 simples é vendido por R$599,00 hoje pelo mercado livre.
Site de vendas oficial da Kyosho:
http://www.kyoshoamerica.com/MR-03-Chas ... 10982.html
2012 SP Limited Edition - Acompanha:
Full Ball Bearing Set - The 2012 MR-03 SP is equipped with a full set of precision ball bearings.
Ball Differential Set - MZW206 ball differential set gives you full tune-ability over your diff and superior cornering control. *Limited Edition Yellow Aluminum
Oil Filled Rear Shock - Pre-installed rear oil filled shock set plants the rear end of the MR-03 on the ground and absorbs all small bumps with authority.
LM Ball Diff Included is also an optional rear ball diff shaft to convert your standard diff to an LM ball diff set up.
Front Spring Set - MZW401 Front spring set is included for endless tuning options.
X-Speed- The 2012 SP Limited Edition MR-03 comes equipped with Kyoshos fastest Mini Z motor, the X-Speed V.
Tire Gauge - You also get the new Mini Z Cup tire gauge in gold anodizing. *Limited Edition Yellow Aluminum
Gold Nylon Nut - You also get some cool yellow aluminum nylon wheel nuts to finish this chassis off.
Tie-Rod You also receive a full set of tie-rods, giving you the maximum advantage over the competition.
Chassis Set Contents
HM specific motor case unit (included)
LM specific motor case unit (included)
MM specific motor case (installed)
Lower and upper plate for narrow tread (front), steering tie rod (included)
Lower and upper plate for wide tread (front), steering tie rod (installed)
Front suspension spacer for adjustment
6T. 7T. 8T. 9T Pinion Gear
Wheel wrench
Pinion removing tools
Pairing stick
MZW1 (Ball Bearing Set) (installed)
MZW206 (Ball Diff Set) (installed)
MZW302-1 (Rear Shaft LM Ball Diff *shaft only)
MZW13 (Color Nylon Nuts Gold) (installed)
MZW207 (Rear Oil Shock Set) (installed)
MZW401 (Front Shock Spring)
MZW117 (Mini Z Cup tire gauge Gold)
MZW301 (X-Speed V Motor) (installed)
MZW402 (Tie Rod Set)
Technical Data:
Length: 125-133mm (4.9-5.2in)
Width: 65-76mm (2.5-2.9in)
Height: 34-35mm (1.3-in)
Chassis Type: MR-03W-MM
Wheelbase: 86-106mm (3.3-4.1in)
Weight: 130g
Required For Operation
ASC Body (Mini-Z Auto Scale Collection Body)
Perfex KT-18 Transmitter Sold Separately #82001
Tires & Wheels
4 x AAA-size alkaline batteries for transmitter (KT-18)
4 x AAA-size alkaline or NiMH batteries for chassis.
Valor R$799,00 com frete gratis vai PAC
Segue minhas qualificações: viewtopic.php?f=3&t=30565
Qualquer dúvida, por favor, perguntem avontade!!!
MR03 Limited Yellow Edition - Nissan Silvia S-15 / Buggy MB-010 Optima+Lazer
Imagem Imagem Imagem
Editado pela última vez por marcelocgomes em Seg Ago 06, 2012 10:24 pm, em um total de 1 vez.
MensagemEnviado: Sáb Jun 30, 2012 1:01 am
Registrado em: Sex Nov 11, 2005 6:07 pm
Show de bola uma pena que comprei um lote de minis da THUNDER com o alberto senão ficaria facil
TAMIYA CR01 ford Bronco HOPADAÇO
TAMIYA Scania R-620 6x4 highline
TAMIYA King hauler 1/14
TAMIYA alfa Giulia M04
Revinho 1/16 CHEGANDO
E muitos outros tamiya............
MensagemEnviado: Seg Ago 06, 2012 10:23 pm
Images: 19
Favor remover anuncio, não vou mais vender o carro!
Att, Marcelo
