Bem-vindo: Dom Nov 01, 2026 1:05 am
Criar novo tópico Responder  [ 34 mensagens ]  Ir para página 1, 2, 3  Próximo
 Título: vendido
MensagemEnviado: Seg Jul 23, 2007 12:48 am
Registrado em: Qui Jun 21, 2007 3:12 pm
amigos esse kit importando direto custa 1390 e comigo sai a 1220! aproveitem! segue descrição do mesmo!
FEATURES: Chassis: Double deck 1/8" (2.5mm) thick woven carbon fiber with blue
aluminum bulkheads for very rigid chassis assembly allowing easy
tweaks for high grip carpet racing or low traction parking lot
racing and all conditions in between
Drive: Four wheel dual belt with adjustable diff heights and belt
tension
Motor Mount: Machined blue aluminum with integrated heat sink
Ball Bearings: Full set of 20
Shocks: Four VCS2 oil-filled with coil-over springs, silicone shock
bladders and hard anodized threaded bodies
Shock Towers: 0.12" (3mm) thick woven carbon fiber
Carbon Fiber: Front and rear shock towers
battery strap, steering rack, and bellcranks
Camber Link Mounts: Blue anodized aluminum
Top Deck Standoffs: Blue anodized aluminum
Arm Mounts: Blue anodized aluminum
Hex Drive: 12mm, clamping, blue anodizied aluminum
Main Gear: Kimbrough 87 tooth, 48 pitch plastic construction
Gearbox: Closed front and rear
Differentials: Ball differential in the front and rear, composite
with blue aluminum outdrive saver rings
Bumpers: Foam front
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Steering: Ball bearing supported, mono-bellcrank with integrated
adjustable servo saver
Ackerman: Adjustable, Ackerman describes the effect of the inner
front wheel turning faster than the outer front wheel during turns
Sway Bar: Front and rear
Battery Strap: Woven carbon fiber
INCLUDES: TC5 rolling chassis with oil-filled threaded aluminum shocks,
Carbon fiber chassis, shock towers, blue anodized aluminum parts,
carbon fiber parts, blue screws, 20 ball bearings, Associated
logo decal sheet, 87T 48 pitch Kimbrough spur gear,
titanium blue anodized turnbuckles, illustrated manual and
complete parts breakdown
Editado pela última vez por fabiokot2006 em Ter Ago 14, 2007 2:33 pm, em um total de 2 vezes.
 Título:
MensagemEnviado: Seg Jul 23, 2007 8:42 am
Registrado em: Seg Abr 16, 2007 3:51 pm
Se possível coloque fotos do carro ou mesmo um link para que os menos experientes possam dar uma olhada e saber qual é o carro.
Abraços e Bons Negócios!!!
Tamiya TG-10 O.S 12 Sanwa Ferrari Modena
Tamiya TA-03 David Jun, Novak DusterII, Peak
Tamiya TA-03 David Jun, MC210CB, Stock
Tamiya TA 03 Pro, Latinha
HPI Formulinha F1 Carbono, MC310CB, Monster
Carregador ICE Duratrax
MensagemEnviado: Seg Jul 23, 2007 10:42 am
vejam o link
http://www.teamassociated.com/racerhub/ ... port08.htm
abraços a todos
 Título:
MensagemEnviado: Seg Jul 23, 2007 1:00 pm
E vc teria pra pronta entrega? Nos sites lá fora tá esgotado...
MensagemEnviado: Seg Jul 23, 2007 1:07 pm
No fornecedor meu consta que está pendente de entrega ainda para este mes amigo
 Título:
MensagemEnviado: Seg Jul 23, 2007 2:28 pm
Realmente ta deve estar em falta. Mesmo o Fabian ta sem kit em estoque, mas já está para receber.
Acho que a Associated não deve estar dando conta da demanda.
Corally RDX PHI'09
MazdaSpeed 6
Speed Passion
Tekin RS Pro
Spektrum DX3R
Intellect
MensagemEnviado: Seg Jul 23, 2007 2:33 pm
Ficarei feliz em lhe atender assim que estiver disponível novamente, este ou outros kits de seu interesse
abraços
MensagemEnviado: Seg Jul 23, 2007 5:54 pm
obrigado por seu depoimento amigo
MensagemEnviado: Seg Jul 23, 2007 11:53 pm
tenho outros kits tambem a quem desejar
MensagemEnviado: Ter Jul 24, 2007 9:15 pm
aguardo contato amigos
MensagemEnviado: Ter Jul 31, 2007 3:06 pm
algum interessado
MensagemEnviado: Seg Ago 13, 2007 10:13 pm
abaixei a 1200
 Título:
MensagemEnviado: Seg Ago 13, 2007 10:43 pm
Registrado em: Sex Nov 11, 2005 6:07 pm
fabio não sei se vc sabe mas o Fabian KAloustian que representa a Associated no brasil tem esse kit a 1000,00
Abraço;
TAMIYA CR01 ford Bronco HOPADAÇO
TAMIYA Scania R-620 6x4 highline
TAMIYA King hauler 1/14
TAMIYA alfa Giulia M04
Revinho 1/16 CHEGANDO
E muitos outros tamiya............
MensagemEnviado: Ter Ago 14, 2007 12:33 am
entao faço esse kit a 990
MensagemEnviado: Ter Ago 14, 2007 12:38 am
a proposito magrinho, tua bateria deu um problema la com o alimao, ve la com ele o que foi valeu
