Bem-vindo: Sex Ago 15, 2025 9:38 am
MensagemEnviado: Qui Out 28, 2010 8:02 pm
Registrado em: Qui Out 28, 2010 7:44 pm
Traxxas Slash 2wd 2.4ghz Rtr W/7-Cell Battery & Charger 1/10
Até 20/11/2010 - [b][b]R$ 786,11[/b][/b]
Traxas Slash 4x2 Modelo 5803 Cor Preto e Vermelho RTR -
Frete por conta do comprador
This is the 2.4GHz radio controlled, electric powered, ready to run,
Traxxas Slash Short Course Race Truck.
FEATURES: Chassis: Modified tub 0.08" (2mm) thick composite nylon with
side nerf bars to impact and support body
Drive: Rear wheel
Motor: Titan 12 turn 550 size modified with internal cooling fan
Battery: 7-cell 3000mAh NiMH
Battery Charger: AC powered
Transmission: Brushless ready Magnum 272 metal-gear with ball
bearings
Slipper Clutch: Revo-spec Torque-Control system
Differential: Planetary type with hardened steel gears
Ball Bearings: Rubber sealed
Main Gear: Plastic, 48 pitch 86 tooth
Pinion Gear: Metal, 48 pitch 18 tooth
Radio: Traxxas TQ 2.4GHz Direct Sequence Spread Spectrum (DSSS)
programmable system
Radio Box: Sealed and watertight for driving through water, mud and
snow
Electronic Speed Control: Traxxas XL-5 (TRAM3017) watertight, with
reverse and brake and Traxxas high current connector
Shocks: Adjustable Ultra shocks with X-ring technology, oil filled
plastic body
Wheels: 1.5" (38mm) wide, 2.2" (56mm) diameter 5-spoke satin finish
Tires: All terrain with foam inserts 1.8" (46mm) wide, 4.25" (108mm)
outer diameter
Bumpers: Scale front and rear tube style
Body: Molded from Lexan, trimmed and prepainted
Suspension: Four wheel independent
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Steering: Bellcrank type with servo saver
INCLUDES: Traxxas Slash Short Course Race Truck with 2.4GHz radio system, ESC,
body, motor, 7-cell 3000mAh NiMH, AC powered charger, decals and
illustrated instruction manual
REQUIRES: AA Batteries: Four for transmitter
Track equipment
SPECS: Vehicle-
Length: 22.36" (568mm)
Width: 11.65" (296mm)
Height: 8.42" (214mm)
Front and Rear Track: 11.65" (296mm) distance between outer edges of
wheels
Wheelbase: 13.2" (335mm)
Ground Clearance: 3.5" (89mm)
Weight: 76.2oz (2.16kg)
Body-
Length: 21.3" (542mm)
Width: 11.4" (289mm)
Height: 5.3" (135mm)
NA CAIXA TRAXXAS NOVO
Editado pela última vez por RCTriploX em Ter Nov 23, 2010 10:09 pm, em um total de 3 vezes.
MensagemEnviado: Qui Out 28, 2010 8:21 pm
Registrado em: Qui Set 10, 2009 8:17 pm
Amigo seja bem vindo, mas leia as regras do forum e atualize seu cadastro informando sua localização.
abraço
MensagemEnviado: Sex Dez 24, 2010 12:10 am
Registrado em: Dom Jun 21, 2009 11:05 pm
Bom dia !
Consegue chegar num preço melhor ?
Carros: HIMOTO MEGA E8MTL 1:8 RTR BRUSHLESS / HIMOTO MEGAP MXT-2S 1:8 NITRO SH21
Qualificações:
viewtopic.php?f=3&t=22429
Parque Witeck ! Um espaço dedicado a natureza!
http://www.parquewiteck.com.br
