Bem-vindo: Dom Mar 29, 2026 1:00 pm
Criar novo tópico Este tópico está trancado. Você não pode responder ou editar mensagens.  [ 3 mensagens ]
MensagemEnviado: Ter Ago 11, 2009 10:45 am
Registrado em: Sáb Abr 04, 2009 11:00 pm
radio novo só tirei da caixa, acompanha receptor e radio
esqueça as interferencias
veja descricao do radio
comprei e não usei
http://www.the-hobby-estore.com/eurgle- ... -1292.html
Eurgle 2.4Ghz 3 Channel Digital Programmable LCD Radio Gear
If you are looking for a budget but quality 2.4Ghz radio gear for your car or boat, I am dare to say it would be the best one you would find in the market. This 3 Channel radio gear comes with a LCD monitor for programming your radio. It is much more convenient than ever before. Comparing with the others, you might need to connect the radio to your computer for programming. But you don't need to do so with this radio! Also, it has 8 model memories for your models - Car and Boat.
One of the advantages of 2.4 GHz radio is no interference! You can say goodbye to frequency pins, getting shot-down, or shooting someone else down for that matter.
You'll never have to worry about "noise" coming from your motor or speed control (or anywhere else on your model) affecting your radio's performance.
The signal is pure digital, so no more annoying glitches that shatter the confidence and cause you to worry about crashing.
The equipment is all solid state. There are no pots to tune, nothing to ever degrade in performance, adjust or need tuning.
novo nunca usei R$ 250,00
Features:
Full range 2.4GHz 3-channel radio
Multi-data computerized Display 128*64 LCD
8-Model Memory
8 Models Select
Integrated timer
Contrast Adjustment
ABS System
Throttle cut
Computer Programmable
Digital Control
Specification:
Transmitter / Receiver: 2.4GHz
Mode Type : Car / Boat
RF Power : Less than 20dbm / 0.8W
Modulation : FM / GFSK
Code Type : Digital
Sensitivity: 1024
LCD: 128*64 dot
Low Voltage Warning: Yes
DSC Port : Yes (3.5mm)
Radio Weight : ~558g
Receiver Weight : ~5.5g
Packing Weight : 990g
Items included:
Eurgle 2.4Ghz 3 Channel 2.4Ghz Transmitter
Eurgle 2.4Ghz 3 Channel 2.4Ghz Receiver
RC8B MMM NEU 1512 1.5D/F
RC8E MMM NEU 1512 1.5D/F
REVO 1/16 MAMBA PRO 6900
fabio
MensagemEnviado: Qua Ago 19, 2009 10:54 am
Registrado em: Seg Mar 23, 2009 2:01 pm
Fábio,
Estou querendo um rádio destes para o GP. Não consegui fazer o FailSafe dele funcionar. Caso eu consiga, este poderia ficar para o EP.
Vamos conversar por MP.
MensagemEnviado: Qua Ago 19, 2009 2:16 pm
Anúncio duplicado e agora, trancado.
Rádio sendo vendido em outro anúncio já presente nos classificados.
Se for o caso de 2 rádios idênticos, acrescentar esta informação no outro anúncio.
== T.O.P. Rebel F1 ==
== DX3R ==
== Lipo! ==
