Bem-vindo: Qua Out 28, 2026 3:34 am
MensagemEnviado: Qua Jun 10, 2009 1:25 pm
Registrado em: Dom Abr 05, 2009 5:10 pm
Vendo Carregador RC-Power B6 novo na caixa
RC-POWER B6 - Carregador, Balanceador e Descarregador de Baterias
Valor : R$ 185.00 [Vendido]
Acompanha sensor de temperatura e cabo usb.
High powered circuit with maximum output power of 50W
Charge current up to 5A
Discharge current up to 15 cells of NiCd/NiMH, 2 to 20V of lead-acid (Pb) and 6 series of Li-ion/LiPO/LiFe batteries
Compatible with 3 types of lithium battery: Li-ion, LiPO and LiFe
Lithium battery 'fast' and 'storage' modes
Individual cell balance when discharging
Individual voltage balancer when charging
Delta-peak sensitivity for maximum safety; auto charge termination program
'Auto' function automatically sets the current
If charge capacity exceeds the limit, the process will terminate automatically
Integrated lithium battery balancer
Processing time limit
Input power monitor
Individual cell monitor
Store the data of 5 different batteries at any one time
Highly effcient cooling fan
Perform 1 to 5 charge/discharge cycles for battery refreshing and balancing
USB port for PC based analysis
Easy to read clear LCD screen
The RC Power BC6 battery charger/discharger is brand new and boxed and comes complete with:
DC clamp
USB cable
Multifunctional extension wire
Temperature sensor
DuPont plug for receiver
Driver disc
Instruction manual
Specifications:
Operating voltage range: 10.0 18.0V
Circuit power: max 50W for charging and max 5W for discharging
Charge current rate: 0.1 ~~ 5.0A
Discharge current range: 0.1 ~~ 1.0A
Charge/discharge cycle: 1-5
Battery memory: 10 models
Current drain for balancing LiPo: 300mAh/cell
NiCd/NiMH battery cell count: 1 ~~ 15 cell
Lithium battery cell count: 1 ~~ 6 series
Pb battery voltage: 2 ~~ 20V
Weight: 580g
Dimensions: 14 x 8.8 x 2.8cm (5.4 x 3.5 x 1.1")
www.eppower.com.br
Editado pela última vez por autoboy em Sáb Ago 08, 2009 8:44 pm, em um total de 2 vezes.
MensagemEnviado: Qua Jun 10, 2009 3:37 pm
Images: 1
Tem balanceador pra qualquer tipo de lipo???
ACE´S RC DRIFT TEAM
Tamiya TB03,novak slydr 6.5
Comunidade RC DRIFT
MensagemEnviado: Qua Jun 10, 2009 5:36 pm
D.K. escreveu:
Ola amigo!
Este carregador tem função de balaceamento tambem para lipo de 1~6series.
Respondido seu MP amigo.
Valeu!
www.eppower.com.br
Usuários navegando neste fórum: Nenhum usuário registrado e 18 visitantes
