Bem-vindo: Qui Out 22, 2026 11:42 pm
MensagemEnviado: Dom Jun 07, 2009 11:44 am
Registrado em: Ter Mai 19, 2009 6:40 pm
Motor elétrico 19T(19 voltas) H.A.R.D. - X3
Baixei o Preço!!!! Apenas R$60,00
Motor muito novo, andou no total 40 minutos, exelente desempenho!
Foto real:
Specifications
Voltage Range : 4.8V-12V
Size: 540 (540size = 54mm)
Turns: 19
No-Load RPM: 25500 RPM @ 7.2V
Started Torque: 2.99kg-cm @ 7.2V
No-Load Current: 2.8A @ 7.2V
Speed Enhanced
The X3 laps the competition, boasting a beefy 19 turn armature? much faster the than the generic motors found in other kits. The X3 takes full advantage of your battery pack, giving you that extra punch when you hit the throttle. You?ll notice the speed with power to spare immediately, that?s the edge you always get when you?re racing H.A.R.D.!
Performance Enhanced
More power plus more speed equals heat. Heat is the enemy of every RC motor. Stock can motors are notorious for heat build up because there is no heat sink endbell. That?s why H.A.R.D. doesn?t leave engineering to chance.
Link no Mercado Livre:
http://produto.mercadolivre.com.br/MLB-96950456-_JM
Editado pela última vez por hsanjos em Qua Jul 15, 2009 9:38 pm, em um total de 1 vez.
MensagemEnviado: Qua Jul 15, 2009 9:28 pm
Images: 5
Ainda tem o motor?
