Bem-vindo: Sex Out 30, 2026 9:13 pm
MensagemEnviado: Sáb Mai 09, 2009 7:59 pm
Registrado em: Sáb Set 08, 2007 1:30 pm
Vendo Carregador Cell Master Platinum (MMRP1000) - R$ 250,00
E
Cooler para baterias modelo Battery Heat Sink II - R$ 100,00
Ambos da Muchmore. Carregador com várias funções monitora temperatura, delta peak, descarrega, ciclo CTX e outras. O Cooler tem 6 ventiladores, faz uma diferença grande na temperatura.
Link do fabricante: http://www.muchmoreusa.com/chargers/mmrp1000.html
Características:
•Black backlit LCD with 16x2 characters
•IC-controlled ball bearing fans
•Gold-plated clips
•High resolution, 16-bit AD for accurate volt reading
•6 charging memories
•Auto restart system
•Magnetic temperature probe
•Auto-start timer
•Blue status indicator
•Customizable charging name
•Zero-delta peak cutoff
•Output control pins for battery warmer or cooling fan stand
SPECIFICATIONS
Dimensions: 4.9 x 4.5 x 1.9 in (124 x 114 x 47 mm)
Weight: 1.06 lb (482 g)
Number of Cells: 1-8
Max Charge Current: 0.1-10.0A (adjustable)
Discharge Current: 0.1-10.0A (adjustable)
Cutoff Voltage: 0.1-9.9V (adjustable)
Input Voltage: 10.0-16.0V
Charging Capability: 10-9990mAh (adjustable)
Charging Modes: Peak & CTX charge, Trickle, Flex, Lithium
Trickle Charge Rate (After Charge): 0.1A
Voltage Threshold/Delta Peak: Zero, 3-99mV
Flex Charge: 0-9 Level (adjustable)
Thermometer Sensor: 15-70°C
Keys: 4
Cooling: Ball bearing temperature controlled dual fans
