Bem-vindo: Sáb Ago 16, 2025 6:31 pm
MensagemEnviado: Ter Ago 30, 2011 11:45 pm
Registrado em: Qui Jul 28, 2011 5:55 pm
Tamiya XB BMW M3 Sport Evo TT-01ED Drift Spec RTR =950,00
This is the electric powered 1/10 scale, ready to run
Tamiya BMW M3 E20 Sport Evo On-Road Drift Spec Car.
FEATURES: Chassis: TT-01D type E with shock tower now molded separately from
the gear case covers and new upper deck with transponder mount
new A parts (Uprights) made of polycarbonate plastic material
new D parts (upper deck, motor cover and more) made of fiberglass-
reinforced nylon material
Drive: Four wheel shaft drive
Electronic Speed Control: TEU-104BK with reverse, TAMM4541
Radio: Tamiya Finespec 27MHz 2-channel FM
Motor: 540 motor with pre-attached leads
Lights: TLU-01 LED head and tail lights turn ON when car is switched
ON, see COMMENTS, head lights are installed tail lights are not
Ball Bearings: Installed in differentials, bushings in wheel hubs
Shocks: Friction, plastic body CVA Super Mini
Gearbox: Sealed, front and rear
Differentials: Bevel gear, ball bearing equipped
Transmission: Single speed
Body: Polycarbonate, painted and trimmed with mirrors, rear wing and
body trim
Tires: Super Driftech drift spec resin 0.94" (24mm) wide, 2.4" (62mm)
diameter
Wheels: Silver finish BBS 2.0" (52mm) outer diameter, 0.94"
(24mm) wide +2° offset
Bumper: Front foam
Suspension: Independent double wishbone
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Steering: Bell-crank type with servo saver
INCLUDES: Tamiya BMW M3 E20 Sport Evo On-Road Drift Spec Car kit, 540 motor,
ESC, body, tires, foam bumper, spoke wheels, 19 tooth pinion gear,
61 tooth spur gear, LED light kit, decals FM radio and instruction
REQUIRES: Radio Batteries: 8 AA size (for transmitter)
Battery: 6-cell stick pack with standard connector
Charger: AC/DC timed or peak for 6-cell battery
Misc. Items: Building and track equipment
SPECS: VEHICLE-
Length: 17.4" (444mm)
Width: 7.4" (187mm)
Height: 5.2" (132mm)
Weight: Approx. 3.1lbs (1400g)
Wheelbase: 10" (254mm)
BODY-
Length: 17.2" (438mm)
Width: 6.25" (159mm)
Height: 4.2" (107mm)
MensagemEnviado: Ter Ago 30, 2011 11:47 pm
Carro Tamiya XB Electric VW Beetle M-04L RTR 57768 = 800,00 R$
This is the radio controlled, electric powered, Ready To Run
Tamiya Volkswagen Beetle On-Road Car.
FEATURES: Chassis: M-04L monocoque
Drive: Rear wheel
Suspension: Front and rear independent double wishbone with
lightweight front and rear uprights
Shocks: Coil-over
Radio: Tamiya Expec
Electric Motor: 540 size, mid-mounted
Electronic Speed Control: Tamiya TEU-101 BK, TAMM3194
Body: Painted vacuum formed polycarbonate with metal plated bumpers
and side mirrors
Tires: .98" (25mm) wide, 2.32" (59mm) diameter
Wheels: .98" (25mm) wide, 1.65" (42mm) diameter
Ball Bearings: Eight 5x10mm
Gearbox: Sealed
Steering: Equal length steering arms for optimum balance and steering
Bumper: Front foam
INCLUDES: Tamiya M-04L Volkswagen Beetle, 540 motor, coil-over shocks,
Electronic Speed Control, shocks, wheels, rubber tire
SPECS: Length: 15.5" (393.7mm)
Width: 7" (177.8mm)
Height: 6" (152.4mm)
Weight: 35.62oz (1010g)
REQUIRES: Battery: 6-cell flat with Tamiya type connector
Battery Charger: Timed or Peak for the 6-Cell Battery
Tools and track equipment
MensagemEnviado: Ter Ago 30, 2011 11:50 pm
Thunder Tiger 1/10 EP Sparrwhwk VX RTR 2.4G Nissan 350Z= 730,00 R$
Features
1.Composite tub chassis w/countersunk battery tray
2.AWD shaft drivetrain system
3.Full ball bearings
4.Cast aluminum motor plate and mount
5.Fully adjustable suspension
6.Hardened steel gear differentials
7.Carbon plastic suspension components
8.Assembled and glued wheels and tires
9.Independent oil-filled shocks
10.Fully upgradeable with hop-ups
11.ACE RC R/C AM 2-Channel radio gear
12.Self programming electronic speed control
13.Super performance 17 Turn Sports Motor
MensagemEnviado: Qua Ago 31, 2011 9:53 am
Agora sim.
Boas vendas
Abraço,
Vini
Vinicius S. Sório
No Chão
No Ar:
-HK 250GT 3D
-HK 136 (Micro)
