Bem-vindo: Qui Nov 26, 2026 5:21 am
Criar novo tópico Responder  [ 114 mensagens ]  Ir para página Anterior  1 ... 4, 5, 6, 7, 8  Próximo
MensagemEnviado: Ter Jan 19, 2010 1:59 pm
Junior3976 escreveu:
Fabio_Floripa escreveu:
Para o Pro-D, já saiu alguma relação de engrenagens (coroa e pinhão do diff) para CS ???
Fabio, vc que é mais fuçador, já viu alguma coisa pro nosso brinquedo? hehe
cara, para o pro-d o pessoal ta usando o da yokomo mesmo
so fazer umas adaptacoes para encaixar...
Vc sabe dizer o certo qual é? ou código das peças e onde achar?
desde já agradeço
Junior3976, é voce que tem o Pro-D genérico??
MensagemEnviado: Ter Jan 19, 2010 2:00 pm
http://www.genkidoridori.com/index.php? ... aa3b579286
o post do gringo que esta fazendo é este aqui
Chris escreveu:
Sorry about the delays guys, I have been working on it but still can't get it perfect. It seems to drive the wheels ok, but binds quite a bit. I did a little testing today in my lounge room and the motor didn't get too hot so it isn't too bad. This is what I have done with plenty of pics to show details:
First, these are the gears I was working with
Standard - 39T 17T
Yokomo - 40T 17T
Active Hobbies Stage 1 CS Kit for Yokomo SD - 36T 20T (no pic)
Active Hobbies Stage 2 CS Kit for Yokomo SD - 43T 13T
To start I didn't want anything that was overdriven too much at first, so I just used the Stage 1 kit (36T, 20T) in the rear diff. If I worked out correctly this would give me about an overdrive ratio of about 1.3. As previously mentioned there was a need to customise the gears to make them fit a spool as they are designed for ball diffs.
I had to pull out the die grinder and cut off the rear shaft on the bevel gear and also cut in a slot for the retaining pin to fit into.
There was also a need to increase the size of the inside hole and grind off the inside of the teeth on the ring gear so it fit onto the spool mounting position. I have also added 0.2mm of shim on the inside of the ring gear against the spool mounting position. Just a note here, I am not the best at using the die grinder so my work isn't great, this may also be contributing to my binding issues.
I then lubed all the bearings and gears and put it all back together.
I am still to do any real driving tests, but from driving it in my lounge, it seems to be ok. Depending on how it drives on the track, I may look at putting the Stage 2 kit into the front diff and put standard gears into the back for a ratio of about 1.45 and see how it goes. I will be doing my first real testing on Saturday this week and will let you all know how it goes.
Cheers
Chris
Tópico de referências.
MensagemEnviado: Ter Jan 19, 2010 2:58 pm
VinyyTuning escreveu:
eu mesmo
8ight-e MMM 2200kv
Losi Night Crawler 55T
HPI Apache SC Flux
Aeroworks Edge 35cc
Great Planes Escapade .45
MensagemEnviado: Ter Jan 19, 2010 5:07 pm
eu mesmo
Bacana, eu to avaliando o meu proximo chassi e estou pensando nesse Pro-D, por quanto ele saiu até chegar? (Valor+frete+impostos)
E quais as peças mais comuns que pedem mais manutenção?
MensagemEnviado: Ter Jan 19, 2010 7:52 pm
eu mesmo
Vinny, se nao me engano tem o topico dele lá no review.
da um look por lá
MensagemEnviado: Ter Jan 19, 2010 8:03 pm
da um look por lá
Opa mano, valeu pelo toque, vou juntar os trocados e talvez pegar um desse, já que é pra gastar, que eu gaste com algo que vale a pena!! (Mas tambem vou pegar só o chassi, mais nada kkkk!!!)
MensagemEnviado: Ter Jan 19, 2010 11:44 pm
Vinny[/quote]
Chegou pra mim por 580 reais, mas acredito que chegue por menos, pois for por intermédio e paguei um sedex a mais. Bom eu ja gastei mais uns 600 reais nele, porém por puro capricho, ele esta todo HPI menos fibra e aluminio, o resto tudo. Mas com mais uns 150 reais vc deixa ele sem quebrar nada....
Os dogbones que vem são bem ruins tem que trocar, tirar uma pequena folga que tem nas engrenagens dos diffs dai já ta de boa pra drift, agora se for por pra andar grip pode trocar a parte de transmissão inteira e parafusos...
O meu troquei tudo, parafusos,cx dos diffs, engrenagens, dogbones todos, bandeijas, entre outros...se quiser comprar só pra drift vale a pena, o chassis é bem equilibrado e muito bom de drifar...
bom é isso aí qualquer coisa só perguntar
abraço
Junior
8ight-e MMM 2200kv
HPI Apache SC Flux
Aeroworks Edge 35cc
MensagemEnviado: Qua Jan 20, 2010 8:03 am
abraço
Junior
Nossa, pensei que sairia mais caro, gostei muito do preço...
Voce acha que dá pra andar de brushed com esse chassi?? Vou usar minha eletronica atual, só que com um motor mais fortinho. Os parafusos desse carro são todos allen certo? O carro vai ser para drift mesmo, uma vez ou outra ando de grip.
MensagemEnviado: Sáb Fev 06, 2010 10:19 am
Olá pessoal so novo aqui no forum e no mundo EP, alguem já fez couter steer no HPI Sprint 2 Flux?? Estava lendo alguns foruns sobre o HPI mas não encontrei as peças, Fabio vc tem alguma ideia sobre as peças que devo mudar no HPI? Pois li no Zero Gravity, que tem uma relação certa de giro, entre a frente e atraz. Alguem tem uma ideia do que devo comprar..... Muito obrigado
Att
MensagemEnviado: Sáb Fev 06, 2010 10:38 am
esanti escreveu:
Att
Bom amigo, o flux é igual o sprint mesmono site do ZG lá tem as pecas que precisa para p sprint
MensagemEnviado: Sáb Fev 06, 2010 10:44 am
esanti escreveu:
Att
Da uma olhada nesse video,no youtube na descrição tem uns links ali acho que explica melhor.
http://www.youtube.com/watch?v=Ql_TsujOLiQ
MensagemEnviado: Ter Fev 09, 2010 12:05 pm
Vou tentar seguir a dica do forum de couter steer Zero Gravity, vou tentar achar essas peças, como provavelmente so vou achar fora, pergunto, vai ficar uma relação boa de diferença de giro entre a frente e atraz com essa configuração???
Cyclone 18T - pulia traseira
Cyclone 39T Ball Diff - diferencial dianteiro
Cyclone correia traseira,
Cyclone correia dianteira
Att.
MensagemEnviado: Ter Fev 09, 2010 12:18 pm
vi alguem aqui no forum vendendo um kit para o counter do sprint
MensagemEnviado: Sex Abr 09, 2010 10:19 pm
para quem tem sprint
segue um setup ai para colocar no CS
Front Setup:
-Pro4 One-Way Diff with 39t pulley
-Yokomo BD Front Belt
-Hpi 15t One-Way Center Pulley
-39/15 = 2.6
Rear Setup:
-Cyclone Spool Diff with 32t Sprint Pulley
-Cyclone Stock Front Belt
-23t Pulley with a Spur Gear Adapter
-32/23 = 1.39
MensagemEnviado: Sex Abr 09, 2010 10:29 pm
Front Setup:
-39/15 = 2.6
Rear Setup:
-32/23 = 1.39
valeu mesmo fabio, assim como o pessoal de floripa tambem somos amantes do drift em Campo Grande - MS, temos 2 drifeiros com sprint. Vou tentar achar essas peças.
