Bem-vindo: Qua Nov 25, 2026 4:34 pm
Criar novo tópico Responder  [ 45 mensagens ]  Ir para página Anterior  1, 2, 3
MensagemEnviado: Sex Fev 24, 2012 10:15 am
Jogo de chaves Turnigy Long Shaft 4pc Hex driver set por $5.88: http://www.hobbyking.com/buddy.asp?code ... 1C1C2858F5
Banana Plugs (non-gold) (10pairs/set) por $2.21: http://www.hobbyking.com/buddy.asp?code ... 0652EF9E27
Vorza Imagem Xray XT8 Imagem
4Pk
MensagemEnviado: Sex Fev 24, 2012 10:44 am
Algumas baterias:
2S:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8933&buddycode=924BBAAF-0DB1-408C-B03D-9CE7301D8828
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21354&buddycode=23B741C7-FF0B-485B-91E0-1D9DC38EC688
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=14081&buddycode=04F91CC7-0650-49BF-9AF9-624FE3CF9748
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21002&buddycode=082CF99A-682E-4FFF-A735-CD35F9853C84
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=17272&buddycode=E079B8BF-A8BC-42E5-83CA-1CCB77324163
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=11938&buddycode=F9B27015-B4A8-49FF-8198-6E6BD708D4C0
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=9514&buddycode=D92B0E41-D1C3-4A08-B049-B734327FEF5B
Vinicius S. Sório
No Chão
No Ar:
-HK 250GT 3D
-HK 136 (Micro)
MensagemEnviado: Sex Fev 24, 2012 8:05 pm
Registrado em: Sáb Nov 26, 2011 8:48 pm
Alô Pessoas....
Esse link é bastante útil pra encontrar os cupons e também pra postar os seus...
http://www.buddyprice.fr.nf/index.php
abraços
Atuais:
Sakura D3-8,5t-CS 1,56
Slash 4x4 Ultimate LCG
Passados:
Monster beatle 1/16 Turnigy
Traxxas E-revo VXL 1/16
HPI Sprint 2 Flux
MensagemEnviado: Ter Fev 28, 2012 3:32 pm
WHS50-Blue Turnigy Heat Shrink Tube 50mm Blue (1mtr) por $1.09: http://www.hobbyking.com/buddy.asp?code ... D178D916E1
GFT-20x50 High stength fiber tape 20mm x 50mtr por 2.60: http://www.hobbyking.com/buddy.asp?code ... D34375D448
AM-1519 Wire Strippers & cutter 2in1 (Strip like a p.... de 9.99 por 5.81: http://www.hobbyking.com/buddy.asp?code ... F2A5106BAC
4Pk
MensagemEnviado: Sáb Abr 21, 2012 12:10 pm
Alguns aqui que eu tenho, nao sei se ainda tá válido.
http://www.hobbyking.com/buddy.asp?code ... 903FD8C103
http://www.hobbyking.com/buddy.asp?code ... EAEB241831
http://www.hobbyking.com/buddy.asp?code ... AFCFF0DD9D
http://www.hobbyking.com/buddy.asp?code ... EB2EEAD544
http://www.hobbyking.com/buddy.asp?code ... 62103D01F2
http://www.hobbyking.com/buddy.asp?code ... 096FEDCC62
http://www.hobbyking.com/buddy.asp?code ... 3ED4BE2DA4
Losi XXX-SCB
MensagemEnviado: Sáb Abr 21, 2012 6:17 pm
Eu estou logado mas não aparece o desconto pra mim.
Aparece o preço normal.
MensagemEnviado: Sáb Abr 21, 2012 6:18 pm
Acho que esses budys não funcionam mais,
já são antigos... acho que só duram 1 mês.
MensagemEnviado: Dom Mai 06, 2012 10:27 pm
Turnigy Heat Shrink Tube 10mm BLACK (1mtr) http://www.hobbyking.com/buddy.asp?code ... DBFE71133B
Turnigy Heat Shrink Tube 10mm RED (1mtr) http://www.hobbyking.com/buddy.asp?code ... 31D0628CB6
Losi XXX-SCB
MensagemEnviado: Qua Dez 19, 2012 10:26 pm
Images: 59
buddycodes valem por 14 dias do dia que foram gerados ....
servo arm p/ futaba em aluminio de 4.49 por 3,39
http://www.hobbyking.com/buddy.asp?code ... 8661858B0E
servo arm longo pra futaba de 4.99 por 4,61
http://www.hobbyking.com/buddy.asp?code ... BCB981995D
servo de 20KG coreless mto bem falado nos forun de monster truck gringos
http://www.hobbyking.com/buddy.asp?code ... 90B7FD0E89
BEC de 8 amp
http://www.hobbyking.com/buddy.asp?code ... 920913AC10
Diferencial traseiro monster beetle e race buggy 1/16
http://www.hobbyking.com/buddy.asp?code ... 377A205DD1
BL4x4
MensagemEnviado: Qui Dez 20, 2012 2:34 am
Images: 14
Minha contribuição...
Pneus para 1/16
Front Tire Set - A2003T and A3007 (2pcs)
http://www.hobbyking.com/buddy.asp?code ... 6986C49775
Rear Tire Set - A2003T and A3007(2pcs)
http://www.hobbyking.com/buddy.asp?code ... F9CD07E6FF
Torre de aluminio traseira 1/16
Aluminum Rear Shock Tower - A2003T
http://www.hobbyking.com/buddy.asp?code ... 5D144AD6B3
Torre dianteira em plastico 1/16
Front Shock Tower - 110BS, A2003, A2027, A2029 and A3007
http://www.hobbyking.com/buddy.asp?code ... A0C18AB833
Amortecedores dianteiro 1/16
Front Shock set (2Pcs/Bag) - 110BS, A2003T, A2027, A2029 and A2035 1
http://www.hobbyking.com/buddy.asp?code ... 1B0EF0AE79
Sextavados em aluminio 1/10
Purple Aluminum Wheel Adaptors with Lock Screws - 7mm (12mm Hex) 1
http://www.hobbyking.com/buddy.asp?code ... A0597BCD77
Chassi 1/16
Plastic Chassis - 110BS and A2003T
http://www.hobbyking.com/buddy.asp?code ... 7BDA486508
Clips bolha com angulo de 90°
Dayglo Orange Small-ring Body Clips (90 deg) 10Pc
http://www.hobbyking.com/buddy.asp?code ... 86B4CCA639
Por enquanto é isso ai pessoal....
Abraço..
Irei repostar no topico do buggy e do monster beatle para que o pessoal tenha acesso..
Boa sorte :P
Ofna Hyper 7 1/8
Tô de volta!!! (Outra vez)..
MensagemEnviado: Qui Dez 20, 2012 8:16 am
Para quem usa o google chrome eu recomendo esse plugin que mostra se o produto tem ou não desconto por buddyprice:
https://chrome.google.com/webstore/deta ... najinljndp
É só instalar que se tiver aparece uma janelinha do canto superior direito da página do produto, muito bacana mesmo.
MensagemEnviado: Qui Dez 20, 2012 9:28 am
Images: 59
rpompeu escreveu:
boa dica , funciona no chromium do ubuntu tb !
ma uma duvida , de onde ele busca os buddycodes ? e como posso adicionar os meus links na busca dele pra ele saber que tem ?
BL4x4
MensagemEnviado: Sex Jan 04, 2013 2:14 pm
http://www.hobbyking.com/buddy.asp?code ... E9B2E22AEB
Losi XXX-SCB
MensagemEnviado: Dom Fev 03, 2013 10:29 am
Registrado em: Seg Nov 28, 2005 2:15 am
Tem isso ainda ? preciso de baterias 3S
MensagemEnviado: Dom Ago 11, 2013 7:17 pm
flbernardo escreveu:
testei varios do ano passado q estao ai em cima, e estao funcionando
