Bem-vindo: Seg Nov 02, 2026 8:52 pm
 Título: RTR onroad 4wd
MensagemEnviado: Qua Dez 18, 2013 11:05 am
NÃO SOU EU QUE ESTOU VENDENDO, ACHEI NO SITE DA TOWERHOBBIES
http://www3.towerhobbies.com/cgi-bin/WT ... LWL371&P=1
This is the 1/10 scale Electric Powered, 2.4GHz Radio Controlled
Ready to Run TS4e Touring Car with Orange Body from Thunder Tiger.
FEATURES: Chassis: Composite nylon tub
Drive: Dual belt, four wheel with cam for adjusting belt tension
Motor: 540 size 3300kV brushless
ESC: Ace BLC 30 with forward/brake/reverse, 5V 2A BEC
Radio: Cougar GP2 IFHSS 2.4GHz 2-channel
Suspension: Rear, Independent, 3-point rear suspension link
Front, F1 style
Body: Trimmed and painted molded Lexan
Differentials: Front and rear
Shocks: Oil filled plastic body
Steering: Adjustable, true Ackerman system
Tires: Treaded rubber 0.94" (24mm) wide, 2.5" (63mm) diameter with
foam inserts
Wheels: Racing dish type, white in color 2.04" (52mm) diameter
Bumper: Front foam
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable front and rear, camber refers to the angle of the
tops of the tires from vertical when viewed from front or behind
vehicle
Warranty: Thunder Tiger guarantees this car to be free from defects
in both material and workmanship. This warranty does not cover any
components damaged by use or modification. A part or parts missing
from the kit must be reported within 60 days of purchase. No part
or parts will be sent under warranty without proof of purchase
INCLUDES: RTR TS4e Touring Car with 2.4GHz Radio, ESC, Body, Brushless Motor
and Instructions
REQUIRES: AA Batteries: Six for transmitter
Battery: 6-cell 7.2V stick pack with Standard connector
Battery Charger: For selected battery
Track equipment
Losi XXX-SCB
MensagemEnviado: Qua Dez 18, 2013 3:22 pm
Cupom de desconto
014TB - SAVE $30 on a $150.00 order
Team Associated RC8T FT
Team Associated SC10 4x4 FT
