Bem-vindo: Qua Nov 04, 2026 5:25 am
 Título: Hotbodies TCXX
MensagemEnviado: Sex Ago 17, 2012 3:10 pm
carro novo da hotbodies, o meu ja ta comprado. só esperando a liberação da fabrica.
Features Summary
- Optimized design and balance for modern LiPo batteries
- New narrow 2.5mm thick chassis
- New carbon battery mount
- New one-piece symmetrical 2.5mm top deck
- Compact bulkheads
- Split pivot blocks for more chassis flex
- New compact motor mount
- New aluminum spur gear mount
- Narrow layshaft and 20T pulleys
- ‘Flipped’ belt drivetrain layout
- Twin crank steering with new longer aluminum arms
- New carbon steering tower bar
- New steering arm post
- New aluminum servo mount
- Bulkheads fully symmetrical front to rear and left to right
- Adjustable top deck flex with bulkhead screws
- Motor mount completely under top deck
- Servo and radio gear sit as close as possible to centerline
- 20T layshaft pulleys and 39T front/rear pulleys combine for increased efficiency
- Rear gear differential for less maintenance
- Aluminum/steel front spool with aluminum sleeves
- Aluminum & steel driveshafts
- Lightweight steel axles with 2mm pins for cup joints
- Clamping hex hubs
- 3.65mm shock towers, 7 fine-pitch adjustment holes in front, 8 in rear
- New aluminum shock stand-offs
- Worlds-winning suspension design with longer top links
- Reversible lower arms for extra shock positions
- Adjustable anti-squat, toe, roll centre
- Droop screws
- Full set of turnbuckles
- Threaded shock bodies with single o-ring construction
- New aluminum spring adjuster and spring retainer
- PTFE 3-hole shocks and spacers
- Wide sway bar rods
- Complete set of sway bars included (1.2mm, 1.3mm, 1.4mm)
- Infinitely adjustable ball stud sway bar mounts
- Fully equipped with ball bearings
- Wheels, tires and inserts not included
- Also requires body and electronics
MensagemEnviado: Sex Ago 17, 2012 4:43 pm
Registrado em: Dom Jan 24, 2010 12:04 am
Cold, nas fotos não dá pra ver, o chassi é aberto em baixo da coroa?
Qualificações no RcElétrico: viewtopic.php?f=3&t=26254
Qualificações no Mercado Livre: http://www.mercadolivre.com.br/jm/profi ... d=66905346
Loja Virtual
MensagemEnviado: Sex Ago 17, 2012 4:51 pm
rasta_man escreveu:
é sim. sim. na segunda foto da pra ver o fundo branco. hehehe
MensagemEnviado: Sex Ago 17, 2012 5:44 pm
Cold escreveu:
rasta_man escreveu:
Eu fiquei na dúvida, pois a coroa também é branca...
A abertura é gigante então, vem desde baixo do diferencial :O
Pensa num chassi flexível... rsrs
Loja Virtual
MensagemEnviado: Sex Ago 17, 2012 6:11 pm
E onde você comprou, antes da liberação?
== T.O.P. Rebel F1 ==
== DX3R ==
== Lipo! ==
MensagemEnviado: Sex Ago 17, 2012 7:21 pm
Seanikaido escreveu:
Na fabrica né fusquinha azul.. rssss..
MensagemEnviado: Sex Ago 17, 2012 7:26 pm
piloto HB é assim uehuehue
MensagemEnviado: Sex Ago 17, 2012 9:44 pm
Fala Fenix, ressurgindo das cinzas! Bora voltar a andar!
MensagemEnviado: Sáb Ago 18, 2012 11:16 am
Jonnydb escreveu:
E ele avisou a HB que ele assinou contrato com outra? (CASOU KKKK)
== DX3R ==
== Lipo! ==
MensagemEnviado: Sáb Ago 18, 2012 3:27 pm
Registrado em: Dom Set 14, 2008 2:21 pm
Comprou para que...apoiar os livros da estante ?
MensagemEnviado: Seg Ago 20, 2012 9:02 pm
Jonnydb escreveu:
KKKKKKKKKKKKKKKKKKKKKKKKKK
pior do que esse contrato é o contrato com (as dividas) ai fudeu!! uhahuahuahua..
MensagemEnviado: Seg Ago 20, 2012 9:04 pm
DPickthall escreveu:
aaahhhhh. não fala assim. vc me magoa!! uhahuahuahua
vcs não tem noção de como estou com vontade de voltar. mas o problema não é a patroa. e sim os 7 cartões de credito com limite estourado que tenho pra pagar.
MensagemEnviado: Ter Ago 21, 2012 9:13 am
Cold escreveu:
Como eu disse
CASAMENTO = GAME OVER
MensagemEnviado: Ter Ago 21, 2012 7:15 pm
Cold escreveu:
Como eu disse
poutz.. não.. me recuso!! uhahuauh
MensagemEnviado: Ter Ago 21, 2012 7:19 pm
Cold escreveu:
então vai correr na proxima etapa? hahaha
