Bem-vindo: Qui Out 29, 2026 2:41 pm
Criar novo tópico Responder  [ 33 mensagens ]  Ir para página 1, 2, 3  Próximo
MensagemEnviado: Qui Dez 18, 2008 10:21 pm
Registrado em: Qua Fev 06, 2008 11:18 pm
Fala pessoal, estou querendo migrar para lipo e estou pensando em comprar este carregador.
Turnigy Accucel-6 50W 5A Balancer/Charger
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7028
Manual
http://www.hobbycity.com/hobbycity/store/uploads/ACCUCEL_manual.pdf
Por US$ 37,99
Alguém já comprou nesta loja?
Qualquer fonte 12V resolve para alimentar ele?
Alguém aconselha ou desaconselha?
The Turnigy Accucel 6 is an entry level balancing charger and discharger which can handle up to 6 cells and 5A.
The Accucel-6 will handle LiPo/LiFe up to 6S and NiMH/NiCd up to 15S and shows individual cell voltage during charge with realtime updates throughout the charge cycle.
Bundled with the Accucel-6 is a bunch of input and output wires which should satisfy any charging requirement.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~17v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Discharge current range: .1~1.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 355g
This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT, Loong Max and any pack with a JST adapter.
*This unit has the same functions (except PC-USB) and features as the iMAX B6, except that it comes with an internal cooling fan.
** Manual can be found here;
Juka Araujo
Duratrax Evader EXT (Trinity 22t)
Duratrax Evader ST PRO (Mamba Max 5700kv)
Turnigy Accucel-6
Lipo Intellect 2S 5000 25+C
2 X NIMH 2000 Piranha
..............vrunnn
MensagemEnviado: Qui Dez 18, 2008 10:33 pm
Fala Tébio, você recomenda?
Juka Araujo
Turnigy Accucel-6
MensagemEnviado: Sex Dez 19, 2008 12:12 am
Vai que vai.
Eu tenho um, e conheço vários que tem esse carregador, excelente.
A melhor relação custo/benefício do mercado.
MensagemEnviado: Sex Dez 19, 2008 1:06 am
Valeu Helvio!!!!
Estou pensando seriamente nele!
A questão da fonte 12V, qualquer uma serve?
Juka Araujo
Turnigy Accucel-6
MensagemEnviado: Sex Dez 19, 2008 6:35 am
Carreguei packs 6 cell a 5A com fonte de computador adaptada, funciona muito bem!
Ele é show... melhor custo benefício, carrega até aquelas baterias feitas com limões na feira de ciência :mrgreen2: . Comprei nesta loja, inclusive!
Recomendo mandar um e-mail logo em seguida à compra, falando para colocarem um valor abaixo de 50 doletas no pacote. O meu dava uns 98 doletas, veio com o valor que pedi... 47 e uns cacos.
A loja é ótima! O Diana também tem um!
MensagemEnviado: Sex Dez 19, 2008 7:02 am
Registrado em: Qui Set 18, 2008 7:53 am
Pode comprar....otimo custo beneficio.
Stampede VXL
Turnigy Accucel-6
3s 20c 4000mah
3s 25c 2500mah
MensagemEnviado: Sex Dez 19, 2008 7:57 am
Pode comprar !!!! Recomendadissimo !!!!
Tenho um Bantam BC5 há muito tempo e recentemente comprei um Turnigy. Sem dúvida que o um excelente carregado e e' melhor que o BC5.
[]'s
E-Maxx (Mamba Monster 2200kv)
Inferno VE
Vorza HPI
Venom Creeper
MensagemEnviado: Sex Dez 19, 2008 8:09 am
O carregador é otimo , recomendo .
Como os outros ja falaram , ele tem varias regulagens , e carrega de tudo .
Pode comprar que você (e quem ver o topico) não vai se arrepender.
Hobbyking 100A , 9T 4300kv
HPI TF1
Turnigy accucel
Lipos 2s 4200 / 3s 3600
MensagemEnviado: Sex Dez 19, 2008 8:35 am
Registrado em: Qui Nov 20, 2008 7:22 pm
Manda bala
eu compro direto nessa loja coisas para meus aeros, minha ultima compra foi esc e motor pro 1:18 da minha filha.
em 1 semana chega tudo.
em relação a esse carregador pode meter bronca que o bixo é bom, mais da metade dos aeromodelistas daqui usam ele, show de bola! e fonte de micro é suficiente sim.
eu to namorando o Acuccel 8, mas só porque vou precisar pra umas baterias mais possantes dos aeros.
Abçs
http://www.chzrc.com.br
http://www.dulac.com.br
Equipe Campeã Brasileira 1:10 Nitro 2011
Equipe Campeã Sul Americana 1:10 Nitro 2011
MensagemEnviado: Sex Dez 19, 2008 10:33 am
depois de tanta recomendação...
Só resta duvida da fonte, eu queria uma fonte um pouco mais prática do que a de computador.
Uma fonte de 12V com quantos amperes é suficiente?
Muito obrigado a todos!
Juka Araujo
Turnigy Accucel-6
MensagemEnviado: Sex Dez 19, 2008 11:10 am
5A deve ser o suficiente , mas eu uso de 7A
HPI TF1
Turnigy accucel
MensagemEnviado: Sex Dez 19, 2008 11:53 am
Ok
Entre
Duratrax ICE
E IMAX B6
Qual, qual deles vale mais a pena? eu sei que o preço deles é bem diferente, mas em relação a funcionalidades, por exemplo o ICE não Balancia, o Turnigy não descarrega, etc.
Mas qual é mais funcional?
Mais uma vez Obrigado.
Juka Araujo
Turnigy Accucel-6
MensagemEnviado: Sex Dez 19, 2008 12:12 pm
Em relação a custo/beneficio eu ainda acho melhor o turnigy .
E ele descarrega sim , só que apenas a 1A .
HPI TF1
Turnigy accucel
MensagemEnviado: Sex Dez 19, 2008 12:53 pm
mete o turnigy que é golásso.
ele faz "diumtudo"
:D
MensagemEnviado: Sex Dez 19, 2008 1:16 pm
O turnigy cicla também... faz até 5 ciclos se não me engano... e tem 5 memórias pra configurações mais usadas.
Carrega balanceando lipo de até 6 cell se não me engano.
