Bem-vindo: Sex Out 30, 2026 1:01 am
MensagemEnviado: Ter Abr 01, 2008 9:00 am
Essa eu não esperava: a Tower está anunciando, para o meio de junho, baterias LiPo de 35.000 mAh (ou se preferirem 35 Ah) fabricadas pela Team Orion!
Como "disponibilidade" aparece "Middle June". Bizarro! Estúpido! Dá pra dar câibra no dedo!!!!! :evil: :twisted: :evil:
No site da Team Orion não aparece nada ainda. Mandei um e-mail pra Tower pedindo mais detalhes!
Direto do site:
NOTES FROM OUR TECH DEPARTMENT
This is the Team Orion Power Edition 35000mAh Ultimate Lithium Polymer Battery Pack.
The carbon edition comes encased with carbon-look case.
These batteries must be charged ONLY with a charger
designed to charge Lithium Polymer batteries which can apply
the "Constant Current/Constant Voltage" (CC/CV) charge technique.
FEATURES: Specifically designed for use in R/C cars
Cells are housed in a durable, crash resistant plastic case
500% longer run-time and 30% less weight than traditional NiCd and
NiMH cells
Lifespan up to 10 times longer than NiCd and NiMH cells with no
memory effect
Can be charged hours or days ahead of time
May be used and recharged limitless times per day
Installed equalizing/balancing port
INCLUDES: Team Orion Power Edition 35000mAh Li-Po 2S1P
4" long lead with 4mm male bullet connectors on one end and a Female
Tamiya battery connector on the other end
REQUIRES: Charger such as the Team Orion Advantage Charging System ORIP3117,
the Great Planes Triton GPMM3150, Hobbico Accu Cycle Elite
HCAP0280, Hobbico Quick Field Charger MKII HCAP0290,
or the Great Planes PolyCharge Lithium Polymer DC charger GPMM30100
SPECS: Length: 5.4" (137.5mm)
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 35000mAh
Charge rate: 1C (4.8 amps)
Cutoff voltage: 2.7 volts per cell
Output voltage: 7.4 volts nominal
COMMENTS: NEVER charge Lithium Polymer batteries with a charger designed for
NiCd, NiMH, or any other type of battery chemistry. Use ONLY
the chargers listed under REQUIRES or equivalent substitutes.
Do not allow Li-Po cells to overheat at any time. Cells which reach
greater than 140° Fahrenheit (60C) will usually become damaged and
could catch fire.
Do not charge Li-Po cells on or near combustible materials including
paper, plastic, carpets, vinyl, leather, wood, inside an R/C/ model
or full size automobile.
Do not discharge, doing so will damage the pack.
Do not expose Li-Po cells to water or moisture at any time.
Do not store batteries near an open flame or heater.
Do not assemble Li-Po cells or pre-assembled packs together with
other Li-Po cells or packs.
Do not leave a Li-Po battery unattended during charging
Always store Li-Po batteries in a secure location away from children
Always remove a Li-Po battery if model is involved in any kind of
crash. Carefully inspect the battery and connectors for even the
smallest damage. CAUTION: cells may be hot! Do not allow the
electrolyte to get into eyes or on skin. Wash affected areas
immediately if they come into contact with electrolyte.
Do not alter or modify connectors or wires of a Lithium battery pack.
JiM 11.10.06
ir/jxs
MensagemEnviado: Ter Abr 01, 2008 10:02 am
Quanto tempo será que dá pra andar com isso ?????????
MensagemEnviado: Ter Abr 01, 2008 10:08 am
Images: 8
Fernando escreveu:
Acho que o ano inteiro....de modified.... :machado:
MensagemEnviado: Ter Abr 01, 2008 10:52 am
Caraca, e isso é porque ela é 1P, imagina se eles resolvem fazer 2P? A carga da bateria ia durar mais que o carro! hehehe
MensagemEnviado: Ter Abr 01, 2008 11:01 am
imagina é o tempo p/ carregar ela toda :shock:
Tópico de referências.
MensagemEnviado: Ter Abr 01, 2008 11:05 am
eu acho que tem um zero a mais ali, nesse peso e tamanho não dá pra colocar 35A de corrente, não mesmo !
MensagemEnviado: Ter Abr 01, 2008 11:17 am
This pack started it all—the first ultra-capacity LiPo battery in the hobby industry for R/C cars. The Platinum Edition 35000 is the LiPo battery that set all the new standards. It provides “next-level” LiPo performance, weighs less than a conventional LiPo pack, adheres to the most rigorous safety standards, and is capable of up to 500 cycles—it’s simply the standard against which all others are measured.
MensagemEnviado: Ter Abr 01, 2008 11:19 am
:shock: :shock: :shock: :shock:
Caramba, quanto será que morre numa dessa?? quantas doletas?
Já tinha lido o anúncio tbm, e é isso mesmo, meros 35000 mah! huauhauha
== T.O.P. Rebel F1 ==
== DX3R ==
== Lipo! ==
MensagemEnviado: Ter Abr 01, 2008 11:57 am
seanikaido escreveu:
sera que da pra trocar as baterias do carro 1:1 por essa? rsss
daqui a pouco a galera ta abrindo lugar nos cofres dos carros e colocando essa pequena barrinha no lugar daquele trambolho!!!
AEEEEEE vou testar em um UNO e ver o que da!! huahuahuauha
MensagemEnviado: Ter Abr 01, 2008 1:42 pm
Daqui a pouco essas Li-Po vão virar arma...dá pra matar alguém eletrocutado :mrgreen:
Os caras já querem partir pra ignorância :shock:
MensagemEnviado: Ter Abr 01, 2008 3:00 pm
A Tower colocou preço:
U$ 89,00
Promoção inicial!!!
Agora vou de LiPo estúpida !!!!!!!!!!!
MensagemEnviado: Ter Abr 01, 2008 3:10 pm
Fernando escreveu:
U$ 89,00
Promoção inicial!!!
só!!! que isso!! os caras tão dando essas lipos!!
cara. vou comprar pra colocar no meu carro 1:1. por esse preço vou usar para o chuveiro, fogão eletrico. afff... Lipo varias utilidades!!
MensagemEnviado: Ter Abr 01, 2008 3:30 pm
90 doletas???
Não é 1º de Abril???
Se for esse preço, me incluam, vamos fazer um pacotão, que duas dessas são minhas!!!
MensagemEnviado: Ter Abr 01, 2008 3:52 pm
Registrado em: Ter Jun 12, 2007 3:33 pm
Fernando,
Consegue passar o link pra gente?!
Valeu
Dando um tempo no Hobby.
Vendendo tudo ... aceito trocas e propostas:
VENDO Chassis Buggy 1/8
VENDO Esc 100A + Progr. card + Ubec 7,5A
VENDO Bolha 1/8 Dodge Viper + Rodas e pneus
VENDO Vários itens - Meu E-SHOP
MINHAS QUALIFICAÇÕES
MensagemEnviado: Ter Abr 01, 2008 4:10 pm
Helvio Lagares escreveu:
90 doletas???
Acho que sim viu...
É bem comum os caras lá fora levarem "à sério" essas brincadeiras e espalharem notícias/boatos desse calibre.
Mas se for verdade, quero 3 :mrgreen:
