MensagemEnviado: Seg Nov 19, 2007 2:29 pm
Registrado em: Qua Jun 20, 2007 4:49 pm
Procurei aqui no forum e não achei muita coisa...gostaria de saber se o carregado Duratrax Piranha CX10 carrega NiMH. Pois estou comprando as baterias e tbm um carregador...gostaria de algo basico que fosse AC/DC.
 Título:
MensagemEnviado: Seg Nov 19, 2007 3:39 pm
specs escreveu:
This is the CX10 AC/DC Fast Charger used for
charging 6 to 7 Cell Sub-C size Battery Packs.
*** Five-Year Warranty ***
FEATURES: After 15 minute timer shuts off, TRICKLE Charge starts with Red LED
indicator light.
Black/Aluminum Anodized Face Plate with Red and Yellow Stripes.
Kyosho Style Adapter.
Fused Overload Protection at the AC circuit, Reverse Polarity
Protection at the DC input.
Use at home or at the track with 110V AC or 12V DC Power Sources.
INCLUDES: One CX10 AC/DC Fast Charger w/Standard Connector, 2½' DC Input
Wire w/Alligator Clips and 5½' AC Input Cord pre-installed.
One Kyosho Adapter
SPECS: Pack Rating Charge Time in Minutes - Next page
1300 to 1500mAh: 15 - 23 minutes
1700 to 2000mAh: 28 - 33 minutes
Fuse Protected: 1.5 slowblow
Mechanical Timer: 15 minute
Fast Charge Rate: 2.5A
TRICKLE Charge Rate: 35 to 75mA
Power Source: 12V DC or 110V AC US Standard
COMMENTS: To determine the condition of the battery, run it in the model, then
compare the run time to a known good battery.
The instructions for the charger are printed directly on the box.
There is no separate sheet of instructions.
Warning: Do not leave your charger unattended while charging packs.
Warning: If using an automotive battery, ENGINE MUST BE OFF.
Warning: Never cut the charge cord or solder in your own connector.
JAL 5/8/00
ir/jl
Click here for Units of Measure Conversion Calculators
não carrega baterias nimh não.
 Título:
MensagemEnviado: Seg Nov 19, 2007 3:46 pm
Onde diz que não carrega????
 Título:
MensagemEnviado: Seg Nov 19, 2007 3:50 pm
valeu Cold Fusion, já tinha visto essas informações...mas o que eu achei estranho é que simplesmente não diz nda sobre o tipo de bateria.
rafammbass, essa era a minha dúvida, por não diz nda.
 Título:
MensagemEnviado: Seg Nov 19, 2007 3:53 pm
rafammbass escreveu:
só pelo carregador não ter identificador de pico. ja se tem uma base. pelo menos eu aprendi que não se deve carregar baterias nimh sem que o carregador identifique o pico da mesma.
certo?
é tb posso ta errado né. mas esse reloginho não me engana, pq eu tenho uma bateria de 2000mah nimh, porem ela pega 2400mah, e se esse carregador só carrega até 2000 em 30 min, não vou usar a capacidade plena do carregador, ou vou ter que ficar fazendo continhas e adivinhando quanto que minha bateria vai alcançar no dia tal. hehehe
 Título:
MensagemEnviado: Seg Nov 19, 2007 4:03 pm
Carregar, carrega sim.
O lance é que ele não tem detector de pico, e as NiMh, nesse aspecto, são um pouco mais sensíveis que que as NiCd.
Então, não se recomenda usar esse carregador.
 Título:
Cold Fusion escreveu:
certo?
Aqui tem um bando de loucooo... que carrega NiMh com carregador que diz que é só pra NiCd...
Acho que não tem mal, depois de fazer as continhas e não estrapolar o limite da bateria!
Não é o ideal, mas como diria o Hélvio, serenity now e vai com cuidado!
 Título:
MensagemEnviado: Seg Nov 19, 2007 4:20 pm
Se a bateria estiver 100% descarregada... você faz as contas, para digamos carregar só uns 90% da NiMh...
assim não tem perigo.... mas também nunca vai ter 100%..
 Título:
MensagemEnviado: Seg Nov 19, 2007 4:31 pm
mas tudo isso que vcs estão falando é tipo "gambiarra" então eu não recomendo, e pra min isso ja se caracteriza como não carregar. ou seja, carrega mas estraga com o tempo. dai é froids, perder uma bateria em pouco tempo de uso é muito triste!!
 Título:
MensagemEnviado: Seg Nov 19, 2007 4:34 pm
Existe algum problema em carregar nimh sem ser com capacidade total? Eu pensei que não acontecia nada, já que não tem aquele lance de efeito memória...
 Título:
Que gambiarra que, ateu!
Não crês no jeitinho brasileiro?
 Título:
MensagemEnviado: Seg Nov 19, 2007 4:37 pm
Isao_TKR escreveu:
Existe. Você não pagou por 8/10 de bateria. Hehehehe
 Título:
MensagemEnviado: Sex Nov 23, 2007 10:54 am
Valeu pela ajuda....como eu queria um carregador relativamente barato e e que poderia ser usado para NiCd e NiMH, acabei comprando o Piranha DC Peak Charger, que realmente é o mais barato...vou testar neste fds.
MensagemEnviado: Dom Abr 06, 2008 3:06 pm
Registrado em: Sex Dez 28, 2007 12:20 pm
Tenho um pack de 3300mAh. Quanto tempo eu a deixo carregando?
Deixo 45 minutos, mais hoje percebi que o carro não dá mais o mesmo rendimento.
Helis: Lama v4, Big lama, Belt CP V2, 4#6.
MensagemEnviado: Dom Abr 06, 2008 5:18 pm
Registrado em: Ter Mai 29, 2007 10:15 pm
Será que o termo Bomba-relógio diz alguma coisa ? Pois é mais ou menos o que esse carregador significa para as baterias Nimh... Além disso, vai estragar as baterias e o transformador que existe dentro do carregador. Não vale a pena.
Emilio
Tamiya TA05R
Esc Novak Cyclone 99/LRP QC2 Competition
Motor Stock CO27/Latinha Johnson
GP 3700/IB 4200
