Bem-vindo: Sex Out 30, 2026 12:23 am
MensagemEnviado: Sex Mar 04, 2011 6:47 pm
Registrado em: Sex Fev 27, 2009 3:44 pm
Sempre vejo as pessoas discutindo aqui como fazer isso e cada um tem uma teoria diversa.
Como jogar fora a sua bateria de LiPo, agora você vai aprender a fazer da maneira correta:
hobbico escreveu:
DISPOSAL OF LIPO BATTERIES
Unlike NiCd batteries, lithium-polymer batteries are
environmentally friendly. For safety reasons, it’s best that
LiPo cells be fully discharged before disposal (however, if
physically damaged it is NOT recommended to discharge
LiPo cells before disposal - see below for details). The
batteries must also be cool before proceeding with disposal
instructions. To dispose of LiPo cells and packs:
1. If any LiPo cell in the pack has been physically damaged,
resulting in a swollen cell or a split or tear in a cell’s foil
covering, do NOT discharge the battery. Jump to step 5.
2. Place the LiPo battery in a fireproof container or bucket
of sand.
3. Connect the battery to a LiPo discharger. Set the discharge
cutoff voltage to the lowest possible value. Set the discharge
current to a C/10 value, with “C” being the capacity rating of
the pack. For example, the “1C” rating for a 1200mAh battery
is 1.2A, and that battery’s C/10 current value is (1.2A / 10)
0.12A or 120mA. Or, a simple resistive type of discharge load
can be used, such as a power resistor or set of light bulbs as
long as the discharge current doesn’t exceed the C/10
value and cause an overheating condition. For LiPo packs
rated at 7.4V and 11.1V, connect a 150 ohm resistor with a
power rating of 2 watts (commonly found at Radio Shack) to
the pack’s positive and negative terminals to safely discharge
the battery. It’s also possible to discharge the battery by
connecting it to an ESC/motor system and allowing the motor
to run indefinitely until no power remains to further cause the
system to function.
4. Discharge the battery until its voltage reaches 1.0V per cell
or lower. For resistive load type discharges, discharge the
battery for up to 24 hours.
5. Submerse the battery into bucket or tub of salt water. This
container should have a lid, but it does not need to be airtight. Prepare a bucket or tub containing 3 to 5 gallons of cold
water, and mix in 1/2 cup of salt per gallon of water. Drop the
battery into the salt water. Allow the battery to remain in the
tub of salt water for at least 2 weeks.
6. Remove the LiPo battery from the salt water and place it in
the normal trash.
Fonte:
http://manuals.hobbico.com/gpm/gpmp0800 ... l-v1_2.pdf
Uma boa fonte de conhecimento sobre como tratar a sua bateria LiPo, colei acima apenas uma parte que eu acho a mais controversa aqui no fórum.
Se você não sabe ler em inglês, use o Google Translator (e quando tiver um tempo/dinheiro extra, recomendo que faça um cursinho de inglês).
Amplexos,
Mercyless
Reborn to be wild
MensagemEnviado: Sex Mar 04, 2011 6:53 pm
Ou vá a uma agencia bancária descarta-la.
Vorza Imagem Xray XT8 Imagem
4Pk
MensagemEnviado: Sex Mar 04, 2011 10:47 pm
As minhas, principalmente as estufadas, jogo nas lojas da Vivo :twisted: :twisted:
Savage Flux HP a venda
Losi 8ight 2.0 RR
Losi 8ight-T 2.0 RR
Losi Micro-T
MensagemEnviado: Sáb Mar 05, 2011 12:07 am
Mercyless escreveu:
Amplexos,
Mercyless
:putz: :putz: :putz:
Tempo pelo jeito, voce tem né Mercyless...
MensagemEnviado: Sáb Mar 05, 2011 11:29 am
nbrancalhaojr escreveu:
Germano escreveu:
Concordo que é uma forma bem mais simples de jogar fora as baterias, mas não sei se é um modo seguro.
Algumas agências bancarias e revendedores de celular tem como obrigação receber as baterias velhas de telefone que na sua maioria são de Lítio (LiPo e Li-ion), mas convenhamos, uma bateria de celular tem um "hardcase" parrudo, são de baixa capacidade de carga (geralmente abaixo de 1A) e são um pouco mais seguras que as nossas LiPos pois não tem fios saindo dela que podem descascar e dar curto.
Muitas de nossas baterias nem hardcase tem. Imaginem um LiPo sem hardcase dentro de uma caixa com gente jogando quilos de outras baterias por cima. Existe uma grande possibilidade de uma dessas baterias furar a LiPo e provocar um incêndio, concordam?
Não sigo exatamente o que a está descrito no texto acima, mas acho que desta forma seria mesmo o mais correto e seguro.
VinyyTuning escreveu:
Essa parte eu não entendi...
Você achou o tópico inútil ou não conseguiu ler pois não está em português?
Sim Vinyy, pois administro muito bem o meu tempo e ainda me sobra algum para ajudar o fórum, diferente de você que fica só "pegando no meu pé". A parte que você citou do meu texto é de extrema importância para você. Vai estudar um pouco mais, pois você precisa, mesmo.
Amplexos,
Mercyless
Reborn to be wild
MensagemEnviado: Sáb Mar 05, 2011 2:03 pm
Images: 14
Bom tópico hein!! quando minha lipo ja estiver a beira da morte ja sei oque fazer hehe..
ps: esses dois ai hein :pedala: ,mais dessa vez o Mercyless nem atentou :mrgreen2:
Ofna Hyper 7 1/8
Tô de volta!!! (Outra vez)..
MensagemEnviado: Dom Mar 06, 2011 10:22 am
Demorado esse método de descarte da hobbico, mas se for para o bem do meio ambiente, tudo bem.
MensagemEnviado: Dom Mar 06, 2011 11:17 am
Mercyless escreveu:
Amplexos,
Mercyless
:lol: :lol: :lol: :lol:
Faz-me rir Mercyless, "ajudar o fórum"...
Se quer ajudar mesmo, postasse o texto traduzido, Ctrl+C e Ctrl+V não adianta blz? Muita gente aqui TRABALHA, ao invés de voce, que coça o saco o dia inteiro pelo jeito.
P.s: Desculpe ficar "pegando no seu pé", quer que eu mande flores, ou vá ai bater um papo amigo com voce?
:putz:
MensagemEnviado: Dom Mar 06, 2011 4:12 pm
Vinyy, se para você não ajudou pois você não compreendeu o que está escrito, não tenho culpa, mas a informação contida nesse texto é sim de grande valia pois vem de uma grande fabricante que entende do assunto. Infelizmente o texto não está em um idioma que você compreenda, mas você poderia se beneficiar desta da mesma forma que uma pessoa que saiba ler em inglês se você fosse atrás de um método de tradução online como o google translator. Mas não, pra que! vou esperar alguém traduzir pra mim! Este seu pensamento é preguiçoso, assim você não cresce na vida. Quer que eu dê a comida na sua boca também? Quer que eu limpe a sua bunda após você defecar?
Trabalho sim, bastante! Graças ao meu trabalho posso ter vários carrinhos e outros "brinquedos" legais. Porém, como já afirmei anteriormente, administro muito bem o meu tempo, consigo "brincar de carrinho" e ainda ajudar o fórum com o meu pequeno conhecimento.
Se você achou completamente inútil o texto pois ele está em inglês, que tudo neste fórum deveria ser postado na língua de Camões, peça para algum moderador excluir este tópico, por mim, whatever!
:putz:
Não Vinyy, respeito a sua orientação sexual adversa, mas nada de flores pra mim, beleza?
Amplexos,
Mercyless
P.S.: Vinyy, escute um conselho de amigo, vai estudar.
Reborn to be wild
MensagemEnviado: Dom Mar 06, 2011 6:51 pm
Eu gostei da informação postada, tem muita utilidade, principalmente pros novatos.
Sugiro até colocar como tópico fixo. Eu também não domino o inglês, e procurei a tradução no Tradukka.com (acho que traduz melhor que o google), assim como faço para acompanhar os foruns lá fora, termos técnicos de manuais, etc.
Mercyless, antes que você também me recomende que tenho que estudar inglês... só não o fiz ainda por causa da carga de trabalho que tenho (quase 80h semanais), mas está nos planos.
Não acredito que seja um esforço muito grande procurar a tradução, ainda mais se o assunto é do interesse pessoal.
GRK 2+/ ARC R10 /Slash 4x4
FUTABA 4PX + HK 310 + GT2
viewtopic.php?f=3&t=8083
MensagemEnviado: Dom Mar 06, 2011 7:22 pm
zaranza escreveu:
HAHAHA, Boa Professor!
80hs?!?!?! Tá trabalhando mais que eu que estou trabalhando hoje, trabalhei ontem e vou trabalhar normalmente 2ª, 3ª e 4ª! Sobra tempo pra sexo ou vc desistiu disso depois das crianças? hehehe
MensagemEnviado: Seg Mar 07, 2011 7:12 am
Pompeu, pro sexo sempre sobra tempo pro sexo .
Gostei do seu carrinho novo. Carrinho de bebe. hehehehe
MensagemEnviado: Ter Mar 08, 2011 10:16 am
Mercyless escreveu:
Amplexos,
Mercyless
Kkkkkk
pegou mal com a piadinha Mercyless?? kkkkkkkk...
