Bem-vindo: Sex Out 30, 2026 6:12 am
MensagemEnviado: Sex Mar 13, 2009 10:36 pm
Registrado em: Dom Dez 07, 2008 5:20 pm
Bem, estmos cada vez mais proximos de fazer os RC a combustão ir pro espaço... hehe
novas tecnologias de baterias estão sendo desenvolvidas, e dentre elas, uma é essa...
Simplesmente o tempo de recarga desta bateria (ainda feita só pra telefones móveis) de Litio Ion, é de 20 segundos!!!
isso mesmo, 20 segundos apenas
não vamos mais precisar ficar esperando a bateria carregar ou levar dúzias de baterias pra pista! oba! hehehe
(ps: isso vai levar um tempo pra chegar no brasil)
bem, e uma parte que eu gostaria de destacar é essa:
Citação:
Hoping that this technology will make it in to the marketplace in time for your next upgrade, or are you terrified at the thought of a battery which can hold several amp-hours being able to discharge in ten seconds?
Nessa frase diz mais ou menos que a bateria vai poder "guardar" vários (amp-hours) ampéres-hora e será capaz de descarregar em 10 segundos!
aqui o artigo original:
Citação:
Anyone who has sat impatiently waiting for their mobile device to suck enough juice into its battery for them to leave the house should perk up at the news that MIT boffins have come up with a new form of lithium ion battery which can be fully charged in under twenty seconds.
As reported over on TechRadar, the new technology – lithium ion phosphate – can fully charge or discharge at a rate twenty times greater than is possible using current lithium ion batteries. This breakthrough potentially holds the key to laptop batteries which are capable of storing an entire day's charge after just twenty seconds of mains time.
The key to the new battery type lies in a new surface structure, which allows the lithium ions to move rapidly around the outside in order to reach specific points in the material through which they must pass in order to charge or discharge. While traditional lithium ion structures – which are extremely energy dense, but slow to charge – rely on the ions aligning with the points in their own sweet time, the new structure sees the lithium ions racing towards their goal far faster than has ever been possible.
There's excellent news for anyone hoping for a commercialised version of the technology, too: the team at MIT which developed the new system, lead by professor Gerbrand Cedar, believes that – as the technology is merely a modification of existing batteries, and doesn't require a new material but instead merely a new method of creating said material – we could see batteries built around the discovery within two to three years.
The new lithium ion phosphate batteries have other benefits, too – not least of which is that the rate at which the battery degrades and loses its ability to hold a charge is greatly reduced compared to other battery types, providing the possibility for batteries that last as long as the laptop does.
For those of a chemical bent the research has been written up in the most current issue of Nature, or there's a particularly in-depth look over on Ars Technica.
Hoping that this technology will make it in to the marketplace in time for your next upgrade, or are you terrified at the thought of a battery which can hold several amp-hours being able to discharge in ten seconds? Share your thoughts over in the fourms.
fonte: Bit-tech
TC-4 Diggity Designs Full Carbon (vendendo) / Savage 4.6 (convertida flux)
Spektrum Dx3
Xcelorin 7500kv + hobbywing 60A / Trackstar 1:8 2650kv + Mamba monster 2
MensagemEnviado: Ter Mar 17, 2009 6:37 pm
comentários? hehehe
pô, logo estaremos carregando 5% da bateria por segundo!... muito melhor que os 2% por minuto atualmente.. hehe
Spektrum Dx3
MensagemEnviado: Ter Mar 17, 2009 7:25 pm
Realmente, se essa tecnoliga chegar pra gente vai ser uma maravilha, mas o carregador vai custar uma grana e a fonte pra ele idem.
"fully charge or discharge at a rate twenty times greater than is possible using current lithium ion batteries" , ou seja 20x mais rápido que lition-ion. Não sei qual é a velocidade de carga de uma bateria dessas, mas se for igual a lipo é 1C. Agora imagine uma bateria dessa de 5000mAh, 20C seriam 100A, tem que ter uma bateria de caminhão!
MensagemEnviado: Ter Mar 17, 2009 9:54 pm
sei la né...
se ela não esquentar muito carregando significará que ela esta aproveitando bem a energia que é passada pra ela...
ai eles podem inventar um sistema com umas 3 baterias de chumbo, que você liga o carregador algum tempo antes em casa, ai deixa as baterias de chumbo (dentro dele) carregando... na hora as de chumbo só descarregam (as 3 junto) e junto ainda com os plugues ligados na bateria do carro... ele não iria sobrecarregar nem as baterias de chumbo nem a do carro...
é um sistema de recarregamento que deve ser pensado, mas se for assim, logo estaremos inaugurando um "posto de recarga" pra baterias nas pistas...
uma tomada 220 que é alugada durante 1 minuto por 1 real... hehehe
Spektrum Dx3
MensagemEnviado: Qua Mar 18, 2009 11:41 am
Images: 119
Pô... no dia que as LiPo carregarem em 20min igual as A123 pra mim já tá bom... :wink:
== Team Associated B64D ==
== Team Associated B3.1E ==
== Team Associated B3 ==
MensagemEnviado: Qua Mai 20, 2009 10:33 pm
BOAS NOVAS!!!
de acordo com a revista INFO de março, esta bateria ja foi criada e testada, só falta conseguirem torna-la em um tamanho menor
não disse mais nada sobre ela, mas estão tentando diminuir para colocar em celulares
agora se conseguirem diminuir para o tamanho de um celular, pra um automodelo vai ser facil facil :D
a informação está entre as páginas 14 a 20, eu não lembro direito qual é, mas é uma página da esquerda da revista :D
Spektrum Dx3
MensagemEnviado: Qui Mai 21, 2009 9:53 am
Estou com as minhas primeiras A123 a caminho... Será que esta tecnologia chega logo?
MensagemEnviado: Qui Mai 21, 2009 9:59 am
é bem provavel que demore, e quando chegar vai chegar com o preço do olho da cara, mas o importante é chegar :)
Spektrum Dx3
