MensagemEnviado: Qui Jun 20, 2013 7:14 pm
RX8 GEN2 1/8th Scale Competition Brushless Controller
http://www.teamtekin.com/rx8.html
Recursos:
Ultra-smooth and Precise Throttle and Braking Control
Compatible with Sensored/Sensorless Brushless and Brushed Motors
Easily Access Programming, Anywhere, Anytime
Datalogging Capability
High Voltage Programmable BEC
EZ Access HotWire Programming Port
HotWire PC Interface for Advanced Programming and Updating
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
Removable/Replaceable Cooling Fan
HDAC: High Density Copper PCB's
Sensor Plug for Precise Commutation with all Motors
Gold-plated Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
30mm RX8 Fan Included #TT3832
High airflow volume for extreme cooling
Impact resistant durable design for offroad applications
Brushless Motor
Recursos Programáveis
High Voltage BEC (6.0v/7.4v)*
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Timing Profiles (5 preset - 2 custom*)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, 4S, 5S, 6S, Custom)
Save, Load and Share custom ESC setup files*
Save, Load and Share Data Log files*
Extensive Tuning via Tekin HotWire PC Interface
Especificações
Controls: Forward/Brake/Reverse
Input Voltage: 2S-6S Lipo
Continuous Current: 220 Amps*
BEC: 6.0v / 7.4v 7amps
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Max Current: 220amps per phase
Timing Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4in (38 x 55.8 x 25.5mm)
Weight: 2.7oz / 76.5g
Tekin recommends LiPo batteries with at least a 40C discharge rate for 1:8 applications.
*Requires HotWire Sold Separately
Team Associated RC8T FT
Team Associated SC10 4x4 FT
MensagemEnviado: Qui Jun 20, 2013 8:58 pm
Registrado em: Sex Jun 08, 2012 3:58 pm
Comprei o meu hoje... Tava difícil de achar...
MensagemEnviado: Qui Jun 20, 2013 9:19 pm
Quanto?
MensagemEnviado: Qui Jun 20, 2013 9:33 pm
Tower só em Julho
Amain PreOrder
Na Amain ainda acha uns combos com o motor T8
ESC 220,00
Motor T8 160,00
Combo 330,00
MensagemEnviado: Sex Jun 21, 2013 8:43 am
Achei no ebay.... paguei U$200,00 + frete.
Tinha pre-order na Tower mas acabei cancelando, ta demorando demais....
MensagemEnviado: Sex Jun 21, 2013 12:48 pm
viewtopic.php?f=13&t=42128
SCX10 Dingo Kit
Axial Wraith
Thunder Tiger MT4 G3
Savage XS Kit
Turnigy Mini Rally Extreme
Losi Micro SCT Brushless
