Bem-vindo: Qui Nov 26, 2026 3:47 am
Criar novo tópico Responder  [ 35 mensagens ]  Ir para página Anterior  1, 2, 3
MensagemEnviado: Qua Nov 26, 2014 6:14 pm
Galera ...
taí os detalhes:
Dewalt 18V (versao 1)
DeWalt Part # 396505-22
Voltage 18vdc (can be overvolted)
Output gear 15 Teeth, nonstandard pitch
Gearbox BPDGFGDN
Body length 2 7/8"
Overall length 3 1/2"
Diameter 1 27/32"
Weight 15.65 oz or 0.9781 Lbs
Estimated Values
Torque Constant 1.2 oz-in/amp
Voltage Constant 1125 RPM/volt
Stall Amperage 155 amps
Dewalt 18V (versao 2)
DeWalt Part # 393111-01
RPM 20,000 ungeared
Output gear 16 Teeth, nonstandard pitch
Gearbox BPDGFGD18
Weight 18.8oz (1.175lb)
Length 78mm (3.07")
Diameter 46mm (1.8")
Output pinion 16 tooth gear
Shaft 5mm dia x 7mm
Armature Resistance: 0.072 Ohms
Stall Current: 250 Amps
Torque Constant: 1.2 ozf-in/Amp
Stall Torque: 300 ozf-in
Angular-velocity Constant 1100 RPM/v
No-load Current: 2.6 Amps
Peak Power: 1.5 HP
Peak Effeciency: 81%
Dewalt 24V
DeWalt Part Number 389010-00
Voltage 24vdc (can be overvolted)
Nominal Torque 94.5 in-lbs
Torque at stall 192 in-lbs
Torque Constant: 1.5 ozf-in/Amp
Nominal Amperage 68 Amps
Stall Current: 190 Amps
RPM 21,000 ungeared
Angular-velocity Constant 880 RPM/v
Output gear 19 Teeth, nonstandard pitch
Gearbox BPDGFGD24
Size 4.8" long x 2.25" dia
Weight 25.60oz or 1.600 Lbs
Armature Resistance: 0.095 Ohms
Peak Power: 2 HP
Dewalt 36V
Approximately 1hp max output @ 36VDC
15600 RPM @ 36V
Voltage Constant = 520 rpm/V (forward)(475 rpm/V (reverse))
Torque Constant = 2.6 oz-in/amp
Stall current: 300 amps
Length: 3.125 inches
Diameter: 2.0 inches
Pinion gear: 14 tooth, 13mm diameter
Weight: 1.78 lb
Shaft: 5 mm, with non-standard-pitch 14 tooth pinion
Size: 50 mm diameter, ~84 mm long without shaft
Mounting: 4x M4 on 33 mm bolt circle
MensagemEnviado: Sex Nov 28, 2014 1:14 pm
Fala Pancho,
Fazendo uma regra de 3 aqui:
Motor V1 em 16,8V: 144A / Pinhão original: 15T
Motor V2 em 16,8V: 233A / Pinhão original: 16T
ESC: 180A
Ou seja, o esc não vai aguentar os dois motores nem a pau. Só vai aguentar o motor versão 1, se usar o motor versão 2 vai queimar. Para usar dois motores em paralelo, cada um deve ter no máximo 90A.
Detalhe:
V1: 1125kv
V2: 1100kv
Para de inventar e põe essa summit pra rodar!!! hahaha
MensagemEnviado: Sex Nov 28, 2014 1:32 pm
KKKKK
Blz .... Mas o titan eu nao coloco nem a PAU !!!
ABço
MensagemEnviado: Sex Nov 28, 2014 3:59 pm
Vai no dewalt mesmo.
Pra vc ter ideia esse esc não aguentaria nem dois titan 775 ligados em paralelo.
Cada titan 775 precisa de 130A em 18V, e aproximadamente 121A em 16,8A.
Se vc quer algo com dois motores, segue um link interessante:
http://www.beatyourtruck.com/forum/show ... maxx/page6
MensagemEnviado: Ter Dez 02, 2014 4:17 pm
Showww....
Em breve novidades !
Abços
