Bem-vindo: Qui Nov 26, 2026 4:51 am
Criar novo tópico Responder  [ 37 mensagens ]  Ir para página Anterior  1, 2, 3
MensagemEnviado: Qua Dez 09, 2009 7:34 am
Images: 5
NATTIS, valeu a dica, vou fazer no meu buggy 1/16... Eu nunca teria essa coragem...
___ Bill_________________
Hemtt 8x8 Creeper.
Stampede, nariz empinado...
FSR EB4, voando baixo.
Lancia (1980), o primeiro...
MensagemEnviado: Qua Dez 09, 2009 7:54 am
Registrado em: Seg Dez 07, 2009 6:44 pm
sergipe escreveu:
Esse foi o principal motivo que me levou a comprar o combo VXL,o fato de ser "waterproof"
VXL-3s (WATERPROOF) ESC SPECIFICATIONS:
Input voltage: NiCad/NiMH 4-9 Cells(4.8 to 10.8 Volts DC)
Input voltage: LiPo 2-3 Cells (7.4 to 11.1 Volts DC)
Case Size: 39mmW x 55mmD x 33mmH
Weight: 90 grams
Motor Limit: Brushed/Brushless: No motor limit.
On Resistance Forward: 0.00075 Ohms
On Resistance Reverse: 0.00075 Ohms
Peak Current - Forward: 320A
Peak Current - Reverse: 320A
Braking Current: 320A
Continuous Current: 200A
BEC Voltage: 6.0V
BEC Current: 2.5A (with 6-cell NiMH)
Power Wire: 12-Gauge Maxx® Cable
Input Harness Wire: 26 Gauge / 100mm
Transistor Type: MOSFET
Low Voltage Detection: 2-Stage indicators, switchable (on or off)
Thermal Protection: 2-Stage thermal shutdown
Profile selection:
Sport Mode:
100% fwd, 100% brakes, 100% rev
Race Mode:
100% fwd, 100% brakes, no rev.
Training Mode:
50% fwd, 100% brakes, 50% rev.
Single-button setup: Yes, Traxxas EZ-Set®
Battery Input Connector: Traxxas High-Current Connector
Motor Types (Autodetect) Brushed, brushless, sensored brushless
Ports: RX Input, motor sensor, auxiliary fan
Quanto custa esta brincadeirinha amigo???
[]'s obrigado!!!
ABRAÇOS!!
Xande Souto
• AX-10 - VolksCrawlerRust
http://www.rceletrico.com.br/forum/viewtopic.php?f=58&t=14775
• Pista RC Rock Crawling e trail IN-DOOR??? Aqui (BH) tem!!!! http://www.rceletrico.com.br/forum/viewtopic.php?f=58&t=17830&sid=b433ad44a70ea406cf9a9702b0fb2be7
MensagemEnviado: Qua Dez 09, 2009 8:28 am
Acredito que somente com pasta não ia funcionar porque ela altera a viscosidade com a temperatura e como o auto sofre vários impactos ela começaria a escorrer e sair o lugar onde não estivesse prensada. Também precisava selar o ESC, a pasta iria aos poucos dando lugar a água até encher o ESC de água novamente.
Eder.Holz escreveu:
Nattis, que bom que funcionou.
Eu ia sugerir pasta térmica. Encheria o esc com essa pasta. Só não sei se essa pasta é condutora de energia ou não. Mas é muito utilizada em amplificadores de som automotivo e em processadores de computador para ajudar na tranferencia de temperatura.
Ela tem a vantagem de ser fléxivel em altas temperatura e ajudaria a dissipar o calor.
No meu Rustler eu não vou fazer isso, como tem espaço vou fazer uma caixinha só para proteger de pedriscos, lama e gotas.
No meu caso pretendo utilizar ventuinha no Mamba Max para garantir a circulação, e terá saida de ar na parte traseira, de cima à baixo.
O material para fazer a caixa será uma latinha de cerveja... material leve, fácil de trabalhar, e já vem praticamente toda lacrada, é só cortar no meio, e fazer uns cortes a mais para poder dobrar e parafusar.
Ai já fica pronta minha gambiarra...
Na verdade tudo isso é só mais uma desculpa para abrir outra latinha :drinks:
MensagemEnviado: Qua Dez 09, 2009 8:29 am
Da uma olhada na Towerhobbies. Não é tão caro, já passaram na minha mão dois desses, mas não gostei mesmo... rs
AXsouto escreveu:
sergipe escreveu:
Weight: 90 grams
BEC Voltage: 6.0V
Profile selection:
Sport Mode:
Race Mode:
Training Mode:
[]'s obrigado!!!
MensagemEnviado: Qua Dez 09, 2009 8:30 am
O esquema é tomar cuidado para selar bem e ao selar certificar que os transistores estão em contato com o dissipador, estando tudo ok pode mandar bala e selar.
Bill escreveu:
MensagemEnviado: Qua Dez 09, 2009 11:23 am
AXsouto escreveu:
[]'s obrigado!!!
Cara, comprei com o usuário fkot2006, ele importa!
Pode comprar tranquilo, cara gente boa e de confiança!
na época paguei R$:440,00 no combo(motor e esc) e não me arrependo, aqui não tem motor mais forte!!
e ainda ando na chuva/lama/pôça! até já brinquei de "barco" numa piscina..rs..rs..
Perfil do fkot2006 :arrow: memberlist.php?mode=viewprofile&u=852
faz um orçamento com ele via mp :wink:
valeu!!
MensagemEnviado: Qua Dez 09, 2009 11:53 am
sergipe escreveu:
AXsouto escreveu:
[]'s obrigado!!!
valeu!!
Obrigado cara....
Vou da uma olhada, mas como estou no inicio das modificaçoes, não sei seria o mais indicado neste momento, mas de qquer forma vou conferir....
Abraço e valeu demas!!!
ABRAÇOS!!
Xande Souto
